Toshiba 55SV670U Screen Problem - AVS Forum | Home Theater Discussions And Reviews
Old 03-09-2011, 10:56 AM - Thread Starter
CPotato's Avatar
The screen on my Toshiba 55SV670U does not display a picture on ANY input but just vertical, random colored lines across the entire screen. I'm looking for troubleshooting advice and/or recommendations for which board is the likely culprit. Already removed/replaced all connectors to see if it helped, but it didn't. Set was mfg'd in September 2009 - < 18 months old. Any advice appreciated.
Attachment 204731
CPotato is offline
Toshiba Regza Cinema Series 55sv670u 55 Inch 1080p Lcd Hdtv With Led Backlight And Clearscan 240 Bla
