Official Samsung UNXXD7000 Owners' Thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3331 of 3341 Old 09-05-2015, 10:53 AM
schweich12's Avatar
Quoted: 44 Post(s)
Couldn't agree more!! Picture still looks fantastic and has a better black level than my neighbors new 4k Vizio. Like Droozy, my tv will move to the bedroom as soon as I upgrade to a UHD set (I'm waiting for the HDCP and HDMI standards to stabilize/finalize first, that and UHD disc players to hit the market).
schweich12 is offline
post #3332 of 3341 Old 09-08-2015, 09:36 AM
NickTheGreat's Avatar
Quoted: 434 Post(s)
Liked: 307
Mine is still my main viewing set. And I see no reason to change it.
The 55" is too large for my space. Maybe somewhere between the two and I'd entertain it . . .
NickTheGreat is offline
post #3333 of 3341 Old 03-01-2016, 08:30 AM
Guzo's Avatar
Liked: 5
That TV has been good to me, but I guess everything ends...
I have vertical lines appearing on the left when there is pure Red, Green or Blue on the screen in content.
I have tried a lot of things but it's always here.
If I turn colors to 0 i don't have any lines or any issues on the screen, as soon as I add colors back it's there.
Do you guys find any issues when playing the first green slide of a trailer (like on my screenshot) ?
Tried to contact Samsung but they pretty much laughed at my face !!
Oh well, time to change I guess!
Guzo is offline
post #3334 of 3341 Old 03-25-2016, 07:07 PM
hansol89's Avatar
i'm getting vertical lines on the right side of tv near the edge, can anything be done ?
hansol89 is offline
post #3335 of 3341 Old 03-27-2016, 12:07 PM
voxelman's Avatar
Although I have to admit that the new 65" UHD OLED sets from LG are turning my head I still love my Samsung UN60D7000.
A voxel is a three dimensional pixel!
voxelman is offline
post #3336 of 3341 Old 05-02-2016, 07:25 PM
Dr.Shankenstein's Avatar
Quoted: 517 Post(s)
Liked: 457
I wound a New in the Box UN46D7000 through a friend. He bought it online and decided to go with a 4K display instead. I notice a some smearing/trailing in the darker areas of Deadspace while playing. I haven't updated the display to the current firmware,so is this something that may be addressed through firmware. It is an H301 panel I believe?
Dr.Shankenstein is online now
post #3337 of 3341 Old 06-19-2016, 01:10 AM
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
In all the years I've had my UA55D7000 (Australian model) which is still going strong, can anyone give me any suggested Colour Space and White balance settings to save me going through the 3337 posts that are on this thread. It would be most appreciated.
Mattyo1612 is offline
post #3338 of 3341 Old 06-19-2016, 01:16 AM
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
I have the same issue but it is on the far right hand side of screen and also very faint lines in right half of screen about 2 inches wide that only shows after a couple of hours when the screen gets warm... I don't know whether there's an easy fix...
post #3339 of 3341 Old 02-03-2017, 04:29 PM
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
Update: Back in July of last year, the vertical lines got worse and was showing all the time, I couldn't take it anymore so I ended up claiming a warranty replacement through the store I bought it from and went to a Sony Bravia and couldn't be happier! Never again Samsung!
post #3340 of 3341 Old 06-11-2017, 08:43 PM
Liked: 0
I am probably asking a question that has been asked but I'm not searching all the threads.
I have had the Samsung un60d7000vf 65" for several years and I love this TV. A couple weeks ago it started having power cycling issues, I read about a fix on another site but that was only temporary for a few days. I had also read that changing out the power supply board will sometimes fix the issue, I bought and installed a new board but the cycling continues. The unit will continue to cycle after removing the power cord and the red power-on light will blink (2 quick blinks) for a total of 10 blinks for 2 sets.
I would like to know if there is any fix for this issue?
Darrell Dekiserre is offline
post #3341 of 3341 Old 06-12-2017, 06:46 AM
raistline's Avatar
Quoted: 99 Post(s)
Liked: 57
I don't know much about this issue but it sounds like you need to replace the main system board for the TV. Just make sure you have a the latest and correct firmware for your TV before you try this as you will likely need to install it after replacement using the TV's Service Mode during initial bootup. It is not likely a panel/screen issue from your description nor any other part.
raistline is offline
Reply LCD Flat Panel Displays
Samsung Un46d7000 46 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Un60d7000 60 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Pn51d7000 51 Inch 1080p 600hz 3d Plasma Hdtv With Pn51d7000 Bdd5500 3d Blu Ray Player 2 Ssg
