Official Samsung UNXXD7000 Owners' Thread - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 3341 Old 03-16-2011, 04:20 PM - Thread Starter
Droozy's Avatar
Quoted: 39 Post(s)
2011 Samsung D 7000 series is now available.... and boy does the spec sheet show some muscle.
7000 Series
60",55",46"
Edge-lit LED/LCD TV
1080p
15,000,000:1 Dynamic Contrast Ratio
Real 240Hz Refresh Rate
SRS TheaterSound
15Watts x 2 Audio Channels
Built-in Bottom Speakers
Built-in Wifi
Blutooth emitter
Features:
Smart TV with Samsung Apps and Internet Browser
2D & 3D in Full HD 1080p
AllShare
Wide Color Enhancer Plus
Ultra Clear Panel
ConnectShare
BD Wise
Game Mode
Anynet+
1 Tuner PIP
Clock & On/Off Timer
HDTV Tuner
Micro Dimming
4 HDMI Including a PC HDMI, and a ARC audio return HDMI
1 Component Inputs (Rear)
2 Composite
3 USB 2.0 Ports
1 Optical Digital Audio Output
1 Audio Out Mini Jack
1 DVI Audio Input
Dimensions
1.2" Depth
0.5" bezel
Weight
35.5 lbs. Without Stand
41.0 lbs. With Stand
QWERTY Remote voucher, or with depending on date of manufacter.
Out of the box, this thing is super slick, ultra sexy, wicked looks to it. The screen sucks up most reflective light. After turning it on.... well the magic begins. As some of you know this replaces my 55C7000 TV that had major banding issues and pixilated Blacks with horrible digital noise. And Right off the bat this D7000 doesnt show any of the Flashlighting, or clouding in this TV that was ever so present in the C series.
It did have a Blue push that needs correcting, and the backlight was super high out of the box. Here is just a quick uncalibrated settings from human eye in a dimly lit room.
Pics:
WINNING
updated: tv settings
Picture Mode: Movie
For more true to life color:
Backlight: Changed to 10
Contrast: 98
Brightness 46
Sharpness: Changed to 13
Color: Changed to 50
Tint G 50/R50
Advanced:
Black Tone: Dark
Dynamic Contrast: off
Shadow Detail: 2
Gamma : 0
Expert Pattern off
RGB only mode: off
Color Space: Custom
Red (58-2-0)
Green (0-58-9)
Blue (7-0-54)
Yellow (48-53-7)
Cyan (0-54-58)
Magenta (56-4-45)
White Balance:
R-Offset 20
G-Offset 24
B-Offset 24
R-Gain 19
G-Gain 26
B-Gain 25
10p Whitebalance
Itvl R G B
1 5 1 -2
2 2 0 -1
3 0 0 -1
4 -2 -3 -3
5 0 -2 -3
6 1 1 -4
7 2 3 0
8 1 2 0
9 -1 2 2
10 0 1 1
Fleshtone: -1
Edge enhancement: off
Motion ligting: off
xvYCC: off
LED Motion Plus: off
Picture Options:
Color Tone: Warm2
DNF: off
Mpeg NF: off
Automotion plus : Clear
Standard Mode Settings for more color pop:
Picture Mode: Standard
Backlight: 11
Contrast: 98
Brightness: 42
Sharpness: 11
Color: 50
Tint: G50/R50
Advance Settings
Black Tone: Dark
Dynamic Contrast off
Shadow Detail: 0
Gamma: 0
Color Space: Custom
Red (58-2-0)
Green (0-58-9)
Blue (7-0-54)
Yellow (48-53-7)
Cyan (0-54-58)
Magenta (56-4-45)
White Balance:
R-Offset 20
G-Offset 24
B-Offset 24
R-Gain 19
G-Gain 26
B-Gain 25
10p Whitebalance
Itvl R G B
1 5 1 -2
2 2 0 -1
3 0 0 -1
4 -2 -3 -3
5 0 -2 -3
6 1 1 -4
7 2 3 0
8 1 2 0
9 -1 2 2
10 0 1 1
Flesh Tone: 0
Edge Enhancement: Off
Motion Lighting: Off
LED Motion Plus: Off
Picture Options
Color Tone: Standard
Digital Noise Filter: low
MPEG Noise Filter: Auto
HDMI Black Level: Low
Auto Motion Plus: clear
ISF Calibrated Set
(for use with a 303 panel)
Movie mode
Backlight 10
Contrast 80
Brightness 45
Sharpness 15
Color 47
Tint 50/50
Advanced Settings
Black Tone off
Shadow Detail 0
Gamma 0
Expert Pat off
RGB off
Color space Custom
Red
Red 53
Green 0
Blue 0
Green
Red 0
Green 64
Blue 0
Blue
Red 1
Green 2
Blue 85
Yellow
Red 52
Green 52
Blue 0
Cyan
Red 0
Green 55
Blue 55
Magenta
Red 47
Green 0
Blue 65
White Balance
R-Offset 25
G-Offset 25
B-Offset 24
R-Gain 12
G-Gain 25
B-Gain 31
10p White Balance off
Flesh Tone 0
Edge Enhancement off
Motion Lighting off
LED Motion Plus off
Picture Options
Color Tone Warm2
Digital Noise Filter Auto
MPEG Noise Filter Auto
HDMI Black Level (Greyed Out) Normal
Film Mode (Greyed out) off
Auto Motion Plus Standard
Droozy is offline
post #2 of 3341 Old 03-16-2011, 05:32 PM
jlluna's Avatar
U just picked this tv, Just set it up, will post picks tomorrow, I have been noticing light bleeding on the bottom edges not sure if thats normal, almost like flashlight affect
jlluna is offline
post #3 of 3341 Old 03-16-2011, 05:52 PM
jlluna's Avatar
Here is a picture, sorry for the low quality
jlluna is offline
post #4 of 3341 Old 03-16-2011, 05:54 PM
red98v6's Avatar
I had the 46 last week and returned it for the 55. The 55 was delivered today and so far I'm loving it. The 46 came with a regular remote with the voucher for the qwerty. I was disappointed that the 55 came with the qwerty because I liked the size of the regular remote. The batteries that came with the tv sucks. Not even 2 min passed and they exploded in the remote :/. I had to clean it out and replace the batteries. Btw change the black tone to dark or darkest setting and that should get rid of that "flashlight" effect
red98v6 is offline
post #5 of 3341 Old 03-16-2011, 06:15 PM
jlluna's Avatar
I will try that red98v6, Thanks!
jlluna is offline
post #6 of 3341 Old 03-16-2011, 06:23 PM - Thread Starter
Droozy's Avatar
Quoted: 39 Post(s)
55" here and no qwerty. My manuf. Date is feburary 28th
Droozy is offline
post #7 of 3341 Old 03-16-2011, 06:27 PM
red98v6's Avatar
Where do I find that date?
red98v6 is offline
post #8 of 3341 Old 03-16-2011, 06:37 PM - Thread Starter
Droozy's Avatar
Quoted: 39 Post(s)
The month is posted on your sn plate on the back of the tv, but when you register the tv online on the samsung site for the extra 3 month warrenty, it wil display the exact date.
Droozy is offline
post #9 of 3341 Old 03-16-2011, 06:43 PM
MaXPL's Avatar
you satisfied or you gonna return it?
that's worse than it is on the c8000 imo.
MaXPL is offline
post #10 of 3341 Old 03-16-2011, 06:48 PM
jlluna's Avatar
Well, I just got this tv set up, I'm watching shrek4 3D right now, the picture looks fantastic, this tv replaced my 55" vizio led, I think I have to do some more picture adjustments, I will give it a few days or so, and see how it goes, I never noticed the edge lighting so much on my vizio, but I do notice it on this set, I will keep playing with the settings, and see how it goes.
jlluna is offline
post #11 of 3341 Old 03-16-2011, 06:51 PM
MaXPL's Avatar
oh ok. didnt realize you just got it.
thought that based on just posting that one photo, you weren't too happy.
i also find it weird that theres bleed towards the center of the black bar considering the led's are on the right.
MaXPL is offline
post #12 of 3341 Old 03-16-2011, 06:55 PM
red98v6's Avatar
My manf date is also February. I guess it was luck that mine had the qwerty. But at least you'll have both remotes
red98v6 is offline
post #13 of 3341 Old 03-16-2011, 07:06 PM
jlluna's Avatar
Here are some more dark picks.
jlluna is offline
post #14 of 3341 Old 03-16-2011, 07:08 PM
Rivers112's Avatar
Picked mine up a few days ago, loving everything about the t.v coming from a old 32' lcd vizio it's a pretty big leap. I'm not a big AV guy so I think the t.v is pretty damn good for the value
Rivers112 is offline
post #15 of 3341 Old 03-16-2011, 07:10 PM - Thread Starter
Droozy's Avatar
Quoted: 39 Post(s)
There was flashlighting on my set, about 20% of what my c7000 showed after the 1/4 turn panel screw mod, but honestly, out of the box, the d7000 had a backlight of 17, and a brightness of 60. This was way too bright and with my posted quick setting, eliminated the light bleed.
Droozy is offline
post #16 of 3341 Old 03-16-2011, 07:14 PM
jlluna's Avatar
The basketball game looks Great, i am just concerned about the flashlight affect, Just wondering if it is something with my tv. ????
jlluna is offline
post #17 of 3341 Old 03-16-2011, 07:16 PM
jlluna's Avatar
I have my backlight set to 10, and my brightness 55.
jlluna is offline
post #18 of 3341 Old 03-16-2011, 07:24 PM
red98v6's Avatar
red98v6 is offline
post #19 of 3341 Old 03-16-2011, 07:30 PM
Rivers112's Avatar
Looks great on the ps3
post #20 of 3341 Old 03-16-2011, 07:38 PM - Thread Starter
Droozy's Avatar
Quoted: 39 Post(s)
Yea my tv looks like reds..... I do not have the flashlight bleed your experiancing.
River send me a psn fr request. My psn is the same as my tag here. *thumbsup
Droozy is offline
post #21 of 3341 Old 03-16-2011, 07:39 PM
jlluna's Avatar
Very nice!
jlluna is offline
post #22 of 3341 Old 03-16-2011, 07:42 PM
Rivers112's Avatar
Very nice!
It's even nicer in motion, I was concerned about the blur but I hardly even notice it
post #23 of 3341 Old 03-16-2011, 07:43 PM
Rivers112's Avatar
I also recorded a video of it
http://www.youtube.com/watch?v=kJmlHo3jpmA
post #24 of 3341 Old 03-16-2011, 08:18 PM
khoop's Avatar
looks like nice black levels.
khoop is offline
post #25 of 3341 Old 03-16-2011, 08:30 PM
red98v6's Avatar
I don't know maybe its my eyes playing tricks on me but the "46 had a very noticeable "soap opera" effect when watching a blu ray but the "55 does not. I really haven't played with the settings too much either
red98v6 is offline
post #26 of 3341 Old 03-16-2011, 11:07 PM
eneyman's Avatar
Hey do you D7000 owners have much lag on your Samsung 7000 when playing PS3/Xbox 360? I know past models like 650 and 750 series I played on had huge delay..
If anybody can try out some shooters and rpg's/adventure type games and comment on lag that would be helpful. OR if you guys can even run the lag test like in the input lag thread.
eneyman is offline
post #27 of 3341 Old 03-16-2011, 11:24 PM
felsi's Avatar
This TV is just awesome. Want to have it right now
At all owners: Congrats to this fantastic set. Please take some more pics. Can please anybody take some pics from the back, the QWERTY and the stand?
Thx a lot
felsi is offline
post #28 of 3341 Old 03-17-2011, 12:41 AM
jbdawson's Avatar
Quoted: 37 Post(s)
I take it from reading the multiple threads here you just gotta live with flashlighting on the D6000/7000/8000 sets prob LED's in general? I know the 2010 C series seemed to be really bad w/ people returning set after set hopefully these new models arent as bad.
jbdawson is offline
post #29 of 3341 Old 03-17-2011, 01:50 AM
toxic1988's Avatar
To all D7000 owners: what´s your panel version??
toxic1988 is offline
post #30 of 3341 Old 03-17-2011, 03:20 AM
Rivers112's Avatar
Ill try to record a test with killzone 3
Reply LCD Flat Panel Displays
Samsung Un46d7000 46 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Un60d7000 60 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Pn51d7000 51 Inch 1080p 600hz 3d Plasma Hdtv With Pn51d7000 Bdd5500 3d Blu Ray Player 2 Ssg
