Is tthere something wrong with my UN46D6000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-22-2011, 09:13 PM - Thread Starter
techgeek78's Avatar
It looks weird like a Soap Opera? Like fake video I dont really know who to explain this? Anyways is there something I am missing? Or is this the way the TV is? Thanks
techgeek78 is offline
post #2 of 9 Old 03-22-2011, 09:16 PM
prawn_sandwich's Avatar
Turn off AMP (auto motion plus) under picture settings->advanced.
Congrats on the new TV. Can you post some pictures on the D6000 owners thread?
Samsung UN55D6400, Comcast HD DVR, Infinity TSS-1200 speakers, Pioneer VSX-1120k
prawn_sandwich is offline
post #3 of 9 Old 03-22-2011, 09:23 PM - Thread Starter
techgeek78's Avatar
Yeah thanks for the fast reply!! I just checked the settings and AMP is turned off??
post #4 of 9 Old 03-22-2011, 09:37 PM
texasrattler's Avatar
Just set auto motion to off. That is what gives you the soap opera effect. You can set it to clear which will give u a little motion but also gives you a little better picture rather than going with off. You can always use custom too, make your own motion settings to your liking.
texasrattler is offline
post #5 of 9 Old 03-22-2011, 10:10 PM - Thread Starter
techgeek78's Avatar
It wont let me enable AMP? It wont let me select it?
post #6 of 9 Old 03-22-2011, 10:17 PM
Hit menu on your remote,go to picture,use arrows keys move down to picture settings,go down to auto motion and choose off or whatever you want.
Make sure you don't have game mode or any eco/energy settings turned on. If so turn them off.
post #7 of 9 Old 03-23-2011, 06:54 AM
dm145's Avatar
Quoted: 78 Post(s)
Liked: 44
here is the pwners thread for your model:
http://www.avsforum.com/avs-vb/showt...ighlight=d6000
may find what you need there
dm145 is offline
post #8 of 9 Old 03-24-2011, 05:11 PM - Thread Starter
techgeek78's Avatar
Ok I figured it out Thanks
post #9 of 9 Old 03-28-2011, 08:39 AM
nanhuad898's Avatar
i think do like this.
but not sure u can go to here!!
http://www.cheaptvtelevisions.com/samsung-un46d6000-led-hdtv.html
nanhuad898 is offline
Reply LCD Flat Panel Displays
Samsung Un46d6000 46 Inch 1080p 120 Hz Led Hdtv Black
