Panasonic DT30 impressions? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 434 Old 06-30-2011, 02:54 AM
jintekken's Avatar
I was told that the first models of the panasonic DT30 suffered in the lower right of too much light, it is true? if so, only the first models had this problem?
jintekken is offline
post #272 of 434 Old 06-30-2011, 03:21 AM
Dark_Planet's Avatar
Here are some updated photos of my dt30 setup.
I went to menards and bought a 6500k lightbulb to replace the wrong yellowish bulb that can be seen in the 1st pic. and mounted it behind the dt30.
I also put a piece of black tape over the red light on the front.
Note: The purple lights are the IR signals coming from the wii sensor.
Dark_Planet is offline
post #273 of 434 Old 06-30-2011, 03:32 AM
jintekken's Avatar
wow, the black of the tv looks great, I did not think ....
I do not see that the TV suffers from too much light at the right corner, right?
Therefore, the first models of the pana DT3, were defective?
post #274 of 434 Old 06-30-2011, 10:49 AM
jp0213x's Avatar
Originally Posted by Dark_Planet View Post
You must be seeing black and white almost with that color setting.
Here are my settings.
Backlight 50 for daytime viewing.......25 for nightime viewing.
Contrast 90.
Brightness 25.
Color 45.
Tint 0.
Sharpness 25.
AI on.
Color temp warm.
To me the colors look more natural at that setting, I don't like saturated colors. My back light settings are similar to yours.
jp0213x is offline
post #275 of 434 Old 06-30-2011, 07:21 PM - Thread Starter
CarmelRob's Avatar
I just bought my DT30 last week and I've noticed uneven backlighting on the bottom where its said the LED array is located.
I notice the backlight bleed on the bottom right corner only at certain times when the screen goes dark, but not always. It took a while for me to even notice it. It's not enough to really bother me.
Mark Hodgkinson's review of the DT30 at avforums.com has a good picture of it under the subtitle, "2D picture quality". The image is black with the words "DVD video" in the middle. If you magnify the image, you'll notice the glow on the bottom right corner.
Has anybody discovered any specific settings you can adjust to minimize the backlight bleed?
CarmelRob is offline
post #276 of 434 Old 06-30-2011, 07:56 PM
jintekken's Avatar
You can post the picture with some game or movie DVDs?
max 15 photo
thanks
post #277 of 434 Old 06-30-2011, 10:51 PM
jp0213x's Avatar
Try my settings, I have similar problem in the lower left hand corner.
jp0213x is offline
post #278 of 434 Old 07-01-2011, 02:26 AM
jintekken's Avatar
but all models suffer from it or just the first models?
post #279 of 434 Old 07-01-2011, 03:11 AM
JonStatt's Avatar
Quoted: 50 Post(s)
Liked: 48
I know everyone is comparing notes about when the screen is totally black and looking for light corners.
But has anyone looked when the whole screen is 100% white and seeing if the left and right sides of the image are the same? Mine is brighter on the left side than the right side of the picture. Has nobody else noticed the same?
JonStatt is offline
post #280 of 434 Old 07-01-2011, 07:35 AM
maxmal23's Avatar
32" or 37"?
maxmal23 is offline
post #281 of 434 Old 07-01-2011, 07:54 AM
jintekken's Avatar
post #282 of 434 Old 07-01-2011, 08:09 AM
Buy one for yourself and see.
post #283 of 434 Old 07-01-2011, 08:16 AM
jintekken's Avatar
You can take pictures with some PS3 games at close range? games especially with black ok?
thanks dark planet
post #284 of 434 Old 07-01-2011, 08:24 AM
maxmal23's Avatar
You're lucky!
Your panel according to the photos you've uploaded is perfect!
cheers ...
maxmal23 is offline
post #285 of 434 Old 07-01-2011, 08:50 AM
jintekken's Avatar
but you have purchased the just released DT30? or you bought it after a few months?
post #286 of 434 Old 07-01-2011, 10:42 AM
Mr Deap's Avatar
Before I tested the DT30, I started off with my parent's four year old 46'' Sony Bravia. I had always figured that the TV had about 50ms of lag and I was pretty much right about that. I tested the VGA input in Game mode ten times. This yielded (54, 48, 48, 48, 40, 48, 36, 36, 42, 60) This averages to 46ms.
I then tested the VGA input on the DT30 in Standard mode ten times. This yielded (24, 36, 48, 30, 36, 36, 24, 48, 24, 36). This averages to 34.2ms.
After that, I tested the VGA input on the DT30 in Game mode ten times. This yielded (12, 24, 36, 36, 12, 36, 36, 20, 36, 24). This averages to 27.2 ms.
What reallys seems strange is how most of the results are a factor of 12. This might have to do with my computer's performance issues with the stopwatch program. I'm really not sure. The best I can say is to take these input lag results with a grain of salt.
You have to take the worst number.
The result seem 45ms without game mode & 30ms in game mode(same as their plasma model but it doesn't goes higher than 30ms in HD). It is pretty good considering it is a LED & have 240hz feature. The plasma series does 45ms in SD.
I'm considering to get it in the way the number look, the problem is retailer here in montreal are very slow at getting the new model. The only way is to order online.
I've seen the E30 but it kind of look worst than my old LZ800. I hope the DT30 doesn't look worst than my my old display.
Mr Deap is offline
post #287 of 434 Old 07-01-2011, 02:08 PM
JonStatt's Avatar
Quoted: 50 Post(s)
Liked: 48
Originally Posted by maxmal23 View Post
32" or 37"?
Sorry I should have said...37"
JonStatt is offline
post #288 of 434 Old 07-01-2011, 04:38 PM - Thread Starter
CarmelRob's Avatar
I've found on my TV that the best way to test for backlight problems is by simply turning the TV on with no inputs playing in a pitch black room. That greyish box with the words, "No signal. Ensure that the external device is turned on and properly connected to the TV's input. Select the source by pressing [INPUT] on the remote." will dance around the screen highlighting problem areas if you have any. If the AI is turned on the area surrounding the box will light up while everything else will darken.(I guess the AI setting really is local dimming) This is where I notice the glow(flashlighting) on the bottom right corner and slight backlight bleed along the right edge.
(update) Turning AI off makes it easier to compare one area with the rest of the screen since it turns off local dimming.
By the way, the C.A.T.S. setting does eliminate the flashlighting but it's just too dark for me.
Frito mentioned in one of his earlier posts(#264) about adjusting the cabinet screws to fix the flashlighting. I'm going to give this a try either tomorrow or the next day. I tried slightly tapping the area but it had no effect.
post #289 of 434 Old 07-01-2011, 06:22 PM
maxmal23's Avatar
Somebody could answer me...
What has been the lowest prices the Panasonic TC-L37DT30 on Amazon?
that is normal?
maxmal23 is offline
post #290 of 434 Old 07-01-2011, 10:18 PM
jintekken's Avatar
that is normal?
this is a panasonic DT30 defect or a defect is only for the first production models?
post #291 of 434 Old 07-02-2011, 10:20 AM - Thread Starter
CarmelRob's Avatar
I got this email back from Panasonic after complaining about the backlight issues I've been experiencing.
"Thank you for your inquiry. Under the conditions you describe (no signal, black screen, darkened room), It is not unusual to see some back light on an LCD TV. Unless you are able to discern this condition with a signal under normal viewing conditions,, it would not be a serviceable issue."
I have to admit that under normal viewing conditions it's really not too noticable so I might just accept it as it is. Based on what a lot of people say, it seems most of these TVs have this problem to one degree or another.
Maxmal23 - Yes, on a screen with no signal the backlight bleed is more apparent to the eye.
Jintekken - I've never heard that only first production models of the DT30 only suffer from backlight issues. It sounds more like wishful thinking.
post #292 of 434 Old 07-02-2011, 11:35 AM
maxmal23's Avatar
This indicates that the problem is due to the manufacture of each panel
or assembly of the TV.
Then it's matter of luck a panel without bleeding
The most common is to have bleeding.
CarmelRob thx for answer!
jintekken stop thinking that!
That is false!
Dark_Planet Sell ​​me your tv
maxmal23 is offline
post #293 of 434 Old 07-02-2011, 02:38 PM
Chris100's Avatar
How do the black levels look, in daytime viewing? On Plasmas, they look gray in daytime. Thanks.
Chris100 is offline
post #294 of 434 Old 07-03-2011, 04:27 AM
HaRd2BeAr's Avatar
Liked: 36
jintekken
Instead of bumping threads and starting threads with the same question and private messaging me twice, why not read through the thread to see what
owners like Dark_Planet and Tigerriot have both said?
Dark_Planet thank you for the excellent pictures you posted and no jintekken i am not going to link you to them go look back through
this thread like i and everyone else has done.
Oh an stop doing the same to the Sony nx720 thread just do some reading and stop ruining this brilliant forum.
Rant over
Aaron
HaRd2BeAr is offline
post #295 of 434 Old 07-03-2011, 08:17 AM
HaRd2BeAr's Avatar
Liked: 36
Thanks Dark_Planet
The pictures you took are really selling this tv to me it looks a stunner
Just need to find one in a store near me to go see it (Im in the UK).
I was looking at the Panasonic E30 but this looks much nicer in my opinion.
The blacks look stunning only thing that bugs me is no separate backlight
control in uk version, its adjusted by the contrast setting. But i guess if out
the box its an accurate picture then it wont matter much.
Thanks again
Aaron
post #296 of 434 Old 07-03-2011, 08:23 AM
Super Moderator
markrubin's Avatar
Quoted: 1053 Post(s)
Liked: 2306
report: do not quote or reply
posts deleted: a member asked to leave the thread
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #297 of 434 Old 07-03-2011, 11:27 PM - Thread Starter
CarmelRob's Avatar
Good news, I managed to significantly reduce the backlight bleed on the bottom-right corner of my DT30 very similar to the image in post #289 by using just a phillips head screwdriver and some teamwork.
First, my dad and I loosened the bottom-right and middle-right screws along the right-side bezel of the TV. We then figured out that if we applied pressure and sort of bend/twisted the corner of the bottom right bezel(NOT the LCD screen ofcourse) we could either cause more or less backlighting in that general area. However once we relieved pressure, the backlight bleed came back the way it was before. So what we did was, my dad would apply pressure to the corner while I looked at it's effects on the screen. When it looked good to me, he then tightened the middle screw while maintaining the pressure. We then repeated the procedure again for the last corner screw. I'm very satisfied with the results but I just hope it lasts awhile. If not, we'll probably just work at it again.
By the way, I've also noticed that as the TV warms up, it becomes more uniform. Kind of strange but it's true.
post #298 of 434 Old 07-04-2011, 10:25 AM
maxmal23's Avatar
Nice!
could you please take a new picture?
to see the result ...
maxmal23 is offline
post #299 of 434 Old 07-04-2011, 02:19 PM
jubrany's Avatar
Just bought the 42" D30 version of this TV, can anyone tell me how to access the ISFccc settings? Or are the "Pro settings" what I am looking for?
EDIT: Pics added as per request. March 2011 build date.
Pretty darn good horizontal viewing angles as pictured (Vertical viewing angles are definitely not as good)
With the backlight on 100, you can see the bright corners are rather obvious.
My crappy camera does not show it, but in total darkness, you can still see bright corners at 50 backlight :
It is still there but is no longer bothersome for me at 25 backlight (sorry my camera sucks, I need a DSLR):
For those returning their TVs over this... I think it will be hard to get a "perfect" one. I didn't buy this TV looking for top picture quality. I needed a TV with good viewing angles, decent motion clarity, low input lag, and safe to use as a PC monitor. If you need better image quality, buy a plasma, or consider an overpriced full array LED-LCD with 256+ zone local dimming.
P.S. This TV surprised me. While obviously not lag-free, I was able to play timing-sensitive PS2 games with results better than any other HDTV I've tried (e.g. Beatmania IIDX and SFIII 3rd Strike were fairly playable... not suitable for tournament use or anything but still very playable.)
Another thing I noticed with this TV is while watching cable TV... Video seems ahead of audio. You need a keen eye to notice this, it is maybe only 2 frames off. Maybe because I am using component cables instead of HDMI? or is the audio delayed by the broadcasters to compensate for the average lag of todays TVs?
EDIT 2:
Okay, I tried again... I increased the ISO sensitivity to 200 to get these. They really exaggerate the backlight issue, but it helps show the uniformity...
25 backlight (very watchable at this lower backlight setting... this is one bright TV)
50 backlight
100 backlight
Took this at 100ISO, -1 exposure. TV in Cinema mode, 25 backlight I believe. This is what it looks like in practice. Pretty good picture quality. I will say though that this TV is extremely unforgiving with low quality sources.
jubrany is offline
post #300 of 434 Old 07-04-2011, 02:28 PM
maxmal23's Avatar
Congratulations on your purchase
I hope you enjoy it a lot!
could show a few pictures please!
Edit: thanks! jubrany
maxmal23 is offline
Reply LCD Flat Panel Displays
