Panasonic DT30 impressions? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 434 Old 09-08-2011, 09:41 AM
Leo King's Avatar
You can connect a soundbar to the TV via the HDMI port or optical output but you cannot control the volume with the TV volume control. Maybe a Panny soundbar will work with the TV's volume control but I am not sure. I'm not using a soundbar, BTW.
Leo King is offline
post #362 of 434 Old 09-13-2011, 07:23 PM
Snyxxx's Avatar
I just added the panasonic soundbar and have it connected via HDMI (ARC). By using the Tv remote (or satellite remote) the soundbar volume is controlled by the TV. Nice!
Much better sound as well, but $170.00 is quite high for the soundbar along with $50.00 brackets to mount the soundbar on top.
Snyxxx is offline
post #363 of 434 Old 09-13-2011, 07:26 PM
iamloco724's Avatar
Quoted: 16 Post(s)
for this sound bar do you need a receiver or can it be used alone and how exactly do you set up arc whats the process
iamloco724 is offline
post #364 of 434 Old 09-13-2011, 07:31 PM
Leo King's Avatar
You do not need a receiver as the sound bar has its own amplifiers. You need to connect the HDMI (ARC) on the sb to the HDMI (ARC) on the TV.
Leo King is offline
post #365 of 434 Old 09-13-2011, 07:57 PM
iamloco724's Avatar
Quoted: 16 Post(s)
sorry to sound dumb but im new to this what exactly is arc how is it diff then reg hdmi connection?
and how would i connect it to multiple sources i have cable box ,ps3 and popcorn hour
post #366 of 434 Old 09-13-2011, 08:04 PM
Leo King's Avatar
The HDMI (ARC) should have a label ARC next to it. The TV has 4 HDMI ports and I believe the HDMI 1 port is HDMI (ARC).
Leo King is offline
post #367 of 434 Old 09-13-2011, 08:07 PM
Leo King's Avatar
I forgot to say ARC is Audio Return Channel.
Leo King is offline
post #368 of 434 Old 09-13-2011, 08:08 PM
iamloco724's Avatar
Quoted: 16 Post(s)
and how would i connect it to multiple sources i have cable box ,ps3 and popcorn hour can i do that?
post #369 of 434 Old 09-13-2011, 08:24 PM
Leo King's Avatar
HDMI (ARC) on TV to HDMI (ARC) OUT on soundbar
HDMI on BD player to HDMI IN on soundbar
Other devices connected to the TV will output their sounds thru the sb.
Leo King is offline
post #370 of 434 Old 09-13-2011, 08:26 PM
iamloco724's Avatar
Quoted: 16 Post(s)
so doing it this way then connecting popcorn hour and cable to the tv everything will come out from the soundbar and my tv remote or fios remote can control the vol?
post #371 of 434 Old 09-13-2011, 08:31 PM
Leo King's Avatar
Yep, provided the two (soundbar & TV) have HDMI ARC ports.
Leo King is offline
post #372 of 434 Old 09-13-2011, 08:42 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Exactly...
CaTaSTrOphiK is offline
post #373 of 434 Old 09-13-2011, 08:59 PM
Leo King's Avatar
Since the 32"/37" DT30 has 4 HDMI ports, you can also connect the BD player directly to the TV.
Leo King is offline
post #374 of 434 Old 09-14-2011, 05:04 AM
Snyxxx's Avatar
Yes, this is what I did. Only one single HDMI cable between TV and soundbar. All other sources into the TV.
Snyxxx is offline
post #375 of 434 Old 09-16-2011, 12:40 PM
iamloco724's Avatar
Quoted: 16 Post(s)
just hooking up my new tv and from the middle to the bottom right straight across at the bottom of the screen theres like this black shadow box anyone help is there a way to fix this or is mine screwed up
post #376 of 434 Old 09-16-2011, 12:52 PM
post #377 of 434 Old 09-16-2011, 08:14 PM
iamloco724's Avatar
Quoted: 16 Post(s)
had to return it to amazon after getting off the phone with panasonic when i order the next one hopefully no problems
post #378 of 434 Old 09-20-2011, 04:52 PM
iamloco724's Avatar
Quoted: 16 Post(s)
i just got a working version of this tv..i applied some of dark planets settings seems a little washed out to me anyone else have setting suggestions?
post #379 of 434 Old 09-21-2011, 04:04 AM
Maledictus's Avatar
He doesn't have the color setting set high enough IMO. I set mine to 40. Also I don't understand why the hell everyone sets their color temperature to Warm, it makes the whites not white at all, on my set at least.
Maledictus is offline
post #380 of 434 Old 09-21-2011, 09:08 AM
wedouglas's Avatar
I just took delivery of it. Will check it out soon.
I felt it was kinda overpriced, but what sold me was that it was a 37in TV that was less than 36in wide. We had a small cabinet to put it in and I thought 32 would be way to small and 42 just wouldnt fit.
wedouglas is offline
post #381 of 434 Old 09-21-2011, 11:11 AM
iamloco724's Avatar
Quoted: 16 Post(s)
do you set color temp to anything other then warm?
post #382 of 434 Old 09-21-2011, 12:00 PM
iamloco724's Avatar
Quoted: 16 Post(s)
these are my settings some taken from dark planets setup..seems a little off to me maybe a little washed out
im not good at this kind of thing and this is my first hdtv so any help greatly appreciated
backlight 50
contrast 50
brightness 50
color 40
tint 0
sharpness 60
color temp warm
color mgt off
ai pic on
motion picture 5 off
post #383 of 434 Old 09-22-2011, 04:35 AM
Maledictus's Avatar
I set mine to normal color temp
post #384 of 434 Old 09-23-2011, 11:28 PM
albertoenciso's Avatar
Hi.
I have 42D30, also i will buy 37DT.
When pressing "Viera tools", i see icons:
1) Viera connect
2) media player
3) DLNA
4) VIERA Link
5) Game mode
6) ECO
Question is:
¿Where is the netflix app icon?
albertoenciso is offline
post #385 of 434 Old 10-08-2011, 12:18 AM
iamloco724's Avatar
Quoted: 16 Post(s)
I am having an issue with my popcorn hour player and its been suggested to me to turn off overscan and Intelligent Frame Creation..i dont see where these settings are so i can do this..any help?
post #386 of 434 Old 10-11-2011, 06:46 PM
B. Wong's Avatar
Has anyone tried the Netgear WNDA3100 on this TV? Apparently it works on other panasonic TV's but the DT30/D30 aren't on netflix's list of certified compatible TV's. I hate to spend 80 bucks on Panasonic Wireless dongle when this one costs 1/4 the price and could work just as well
B. Wong is offline
post #387 of 434 Old 10-11-2011, 06:47 PM
iamloco724's Avatar
Quoted: 16 Post(s)
didnt you get the wireless dongle with the tv?
post #388 of 434 Old 10-12-2011, 10:38 PM
I have purchased 42D30 last august, it came without dongle. I bought it together with 50GT30 of a friend, that plasma came with the dongle but no 3D glasses.
I am waiting for 37DT30, no dongle and a pair of 3D glasses as accesories.
post #389 of 434 Old 10-20-2011, 12:15 PM
Kelendral's Avatar
Format: Full
Menu > Advanced Picture > Motion Picture Pro: Off
Kelendral is offline
post #390 of 434 Old 10-26-2011, 10:58 PM
iamloco724's Avatar
Quoted: 16 Post(s)
It seems this tv has been discontinued..anyone know why?..that concerns me since ive had this tv for a month now
Reply LCD Flat Panel Displays
