Official Sony NX720 Owner's thread (KDL60NX720, KDL55NX720, KDL46NX720) - Page 115 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #3421 of 3473 Old 01-21-2014, 08:45 PM
tboo's Avatar
Ive had my nx720 now for a little over two years and love it. Ive been very happy with the picture quality. Before I got the Sony, I probably had 10 TVs in a span of 10 years. I just couldnt find one with picture quality that satisfied me. That changed when I got the nx720. Im still amazed at the black levels it produces for an edge lit set.
tboo is offline
post #3422 of 3473 Old 01-22-2014, 07:43 PM
koan00's Avatar
The only problems with this set seem to be software related. On the plus side, its nice its still getting firmware updates. On the minus side the thing still randomly reboots.
koan00 is offline
post #3423 of 3473 Old 02-21-2014, 09:10 AM
sexydude's Avatar
Hey guys,
I have been reading this forum for a long time. Got one issue with my own tv, so thought of asking experts here.
I have a sony NX720. There was an issue previously with the tv and it got dead with red blinking lights. I got it fixed from a mechanic who change the led driver board. But since then i saw half of the screen darker than other half. It was not not too much previously but now it has become more darker so i am not sure what may be the cause. It may be due to that led driver board replacement? should i again contact that mechanic if thats the case? I already spent 250 bucks on it and dont want to keep spending more of it if this is a different issue.
sexydude is offline
post #3424 of 3473 Old 02-21-2014, 09:20 AM
randys1's Avatar
mine still shuts off by itself once in a while and i have the presence thing off
the energy saver button on the side of the tv is very confusing, first i dont know if pushing the top of it is on or off, literally dont know which way to push button to turn it on or off
then i dont know what it is doing, what I want is for the tv to NEVER shut off unless I shut it off
randys1 is offline
post #3425 of 3473 Old 04-17-2014, 05:58 PM
teasip's Avatar
I've had one of these units (55") for several years now and thus far no issues. I have a somewhat large traditional RS antenna in a one-story attic, with both VHF/UHF elements, making an approximate 50' run of coax to this TV for backup access to OTA channels (use Verizon FiOS/TiVO DVR for primary viewing). Several weeks back I placed a dedicated Winegard FreeVision FVHD30H antenna behind (to the north) of the south facing RS antenna to use as a dedicated antenna to an inherited Toshiba HDTV in my master bedroom with surprisingly excellent results. I am picking up HOT TV and Retro TV with the much smaller antenna but am not finding it when scanning with the larger antenna running to the Sony set. The question is where is the issue? Sony TV ATSC tuner? Shorter run of coax though from a smaller antenna going to the Toshiba set allowing these channels to be found? Any suggestions? Towers are approximately 30-35 mi. to the south but that should be irrelevant here since the much smaller antenna is pulling in the two channels.
teasip is offline
post #3426 of 3473 Old 04-21-2014, 07:11 PM
naved777's Avatar
Guys suddenly my 40" NX720 started showing horizontal lines
the TV is now 3 years old and is out of warranty.Ant suggestion what to do ?
naved777 is offline
post #3427 of 3473 Old 04-22-2014, 04:35 PM
jedclampit's Avatar
As simple as this may seem , have you tried unplugging the set for a few minutes and the restarting it? There also may be some way to do a factory reset. I see if I can find how and post if I find it.
BTW is this from any input or one with something connected?
jedclampit is offline
post #3428 of 3473 Old 04-22-2014, 07:33 PM
EscapeVelocity's Avatar
Quoted: 492 Post(s)
Liked: 264
Did these sets have a lot of issues and break downs?
Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 Plasma / Panasonic P50ST60 Plasma / Sony 50W700B LCD / Vizio VP322 Plasma
Sony S790 BD / Panasonic BDT-220 / Roku 2 XS & Roku 2 (Ver. 3)
Panasonic S97 / Panasonic RP-91
Aiwa MX100 Multi-region VCR / JVC S7600 S-VHS
EscapeVelocity is offline
post #3429 of 3473 Old 04-22-2014, 07:35 PM
Quoted: 492 Post(s)
Liked: 264
Sounds like an issue with one of the video processing boards. Sony service center can probably fix it.
post #3430 of 3473 Old 07-02-2014, 09:55 AM
I was watching TV last night and my KDL46NX720 randomly shut off. When it shut off, I heard the "click" normally heard 3-4 seconds after hitting the power button. Immediately after hearing the click, the red standby light began to blink twice and has been doing so since last night. I've tried to hard reset the TV by unplugging it from the power source and waiting a minute along with plugging it into different outlets. The TV was plugged into a surge protector and everything else connected to that surge protector still functions. Has anybody had an experience similar to this?
gerald67 likes this.
takeuptime is offline
post #3431 of 3473 Old 09-15-2014, 05:27 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Information for the record for others to use if needed.
My KDL-55NX720 started acting up a few days ago. No LED trouble codes were seen. TV came on, but there was video only on the bottom 5% of the screen. The rest of the screen was a faint gray. Menus could not be seen either. Audio was fine. Remote control worked as far as power off and on were concerned.
I did the power off routine, the TV reset routine and the unplug overnight routine. It sort of worked in that I got back a full screen picture, but there were extreme brightness flashes and poor images. Sometimes the images were frozen. Obviously things were not close to being right.
The cure was to use the power button on the TV rather than on the remote control. With the use of the on TV power switch there is a green LED setting for on, a red LED setting for off, and a no LED setting for off. The no LED off position must be used, and that setting is not available from the remote control power button. Then I set the TV master power switch to the off position, and left the TV unplugged overnight. I also unplugged all HDMI cables and all other cables.
The TV was back to normal in the morning. I checked for a software update, and there was one available. I did the software update.
Note that I am not sure if the TV reset routine had to be done. The TV reset routine did not help with the problem. Not a big deal one way or the other, just a pain to scan the TV channels, setup the wireless router and update Rovi again.
J_Palmer_Cass is offline
post #3432 of 3473 Old 10-10-2014, 01:08 PM
Liked: 0
@takeuptime
I had a similar issue 2 nights ago. Most advice seem to say the TV is dead. How did you fix yours? Thx
gerald67 is offline
post #3433 of 3473 Old 11-14-2014, 02:39 PM
I never did.....it's boxed up in a store room, waiting for me to fix it. I went out and bought a Vizio M-Series and a 5 year warranty.
I did a bunch of research and it seems like 2 red flashes signal the problem is a bad power board. I found a service manual online and figured out the part # is 1-474-301-11 and is called the "G5 Board" (40" G4, 46" G5, 55" G6). I was only able to find "refurbished" versions online from third party sellers for around $130. If you end up fixing yours, let me know.
post #3434 of 3473 Old 11-18-2014, 06:04 PM
Liked: 0
I'm having this issue with my sony KDL-55NX720 TV.
The TV turns on but turns itself off after like 5 seconds.
Then the LED power light blinks 4 times.
Right before turns itself off, i can see that there is a small section at the bottom dims.
Maybe couple of the LED is out.
Has anyone experienced similar issues?
Has anyone gotten repaired and how much was it?
I would appreciate if someone can share their experience.
lionjts is offline
post #3435 of 3473 Old 11-19-2014, 06:54 AM
Quoted: 393 Post(s)
Liked: 118
I have the same model TV, but I have no trouble codes. My LCD panel is going bad (intermittent connection, but my back light assembly and all boards are good. I am kind of ticked off at a bad LCD screen after only 2 1/2 years of use.
The back light assembly is part of the main chassis and is not repairable. A bad LCD panel can be separated from the back light assembly / chassis, but a lot of time and two people are required to do that. Then again, there are no LCD panels or back light assemblies are available for sale so that about ends the repair discussion.
I am going to watch out for a bad KDL-55NX720 on E-bay if a local one is available that has the correct defect. Then maybe I can make 1 set out of 2.
Anyhow, here is some information from one of the Sony manuals.
ID:	373930   Click image for larger version
post #3436 of 3473 Old 11-21-2014, 11:58 AM
Liked: 0
LED repair
I found someone who was able to replace just the LED strip from another forum thread.
I can't post the url link duo to my account limit but you can search below title.
Sony KDL-60NX720 Failed after 1 1/2 years! 4 LED Blinks
It isn't the exact same model but close enough.
Seems like the panel is made by samsung and LED light strips are around $10 each from China.
I'm gonna try to disassemble my TV over the the holiday when i have time.
This is the second Sony TV I had that failed on me.
Both occasions, Sony just offered discount on new models.
Since day one, My TV has this weird random restart and when I contacted Sony, they just said software update will fix the issue, which it didn't.
My TV must had less than 100 hours.
I can't believe there are so many people who are having similar issues and sony isn't doing anything about it.
This will be the last sony product i'll own and will not buy or recommend sony product in future.
[QUOTE=J_Palmer_Cass;29163090]I have the same model TV, but I have no trouble codes. My LCD panel is going bad (intermittent connection, but my back light assembly and all boards are good. I am kind of ticked off at a bad LCD screen after only 2 1/2 years of use.
ID:	378441   Click image for larger version
lionjts is offline
post #3437 of 3473 Old 11-21-2014, 10:13 PM
Quoted: 393 Post(s)
Liked: 118
The person who repaired the TV had a 40" model. I could not find the correct LED assembly for the KDL-55NX720 when I looked a while back. I know for sure that the LED assemblies are a bear to get to. You have to separate the LCD display from the main chassis / LED backlight assembly, and then move the LCD screen to a safe place without bending the screen. If you flex the screen, then you will most likely break some internal connections in the LCD panel and not know it until you get the TV back together. You also have to keep the chassis grounded so static electricity does not damage anything.
In addition, there is a surface coating on the LCD screen. When you disassemble the TV, you have to place the TV face down to work on it. If you are not careful placing the TV down flat on a clean surface you will scratch the LCD screen. If you flex the screen you can also ruin the internal connections in the LCD panel.
Once the LCD panel is separated from the main chassis, edge trim and the wiring harness, the LED's are hidden behind a white screen. I only separated the LCD screen from the main chassis by 6 inches or so so I could place some rubber pads in the LCD screen corner.
No dogs or cats can be around either. I even get "dust" from the blankets and sheets that I had the screen lying down on. Easy to get that "dust" between the LCD panel and the LED back light / main frame assembly
Just as a note, my LCD screen has an intermittent internal panel connection in the upper right corner. I have performed a small repair to the LCD panel (AKA rubber pad) to keep some pressure on the bad corner, but I am not sure if the repair will last. I still have the TV taken apart. The repair has worked for 5 days now after three pad placements.
You can get the KDL-55NX720 service manuals in the site mentioned in the link below. I downloaded my manuals from that site. The manuals tell you how to remove the rear cover. More screws have to be removed than you realize. You also have to document where the screws go as you remove them. You will not remember where they go after the fact.
As far as time is concerned, 6 hours minimum to take the TV apart.
http://elektrotanya.com/sony_kdl-40n.../download.html
Here is a link to the thread that you mentioned.
LED Failure Thread click here.
If you can not find the replacement part before hand, it is a waste of time taking the TV apart. I am ticked off that I can not buy a new LCD screen at any price from Sony. It is cheaper to buy a new TV set anyway going by the old price replacement LCD panel price sheets. Then again, those were assembled LCD panel and LED back light / main chassis assemblies complete as a unit.
The random restart probably is caused by the main BATL board. They are hard to come by, and must be purchased used. A couple of them have sold on E-bay for around $130 including shipping.
Funny how you need a LED chassis assembly and probably a new BATL board, and I need a new LCD screen. Between us we probably have a good TV.
Keep this thread updated on what you are planning to do or if you have any questions. If my temporary panel "repair" keeps working, I will assemble my KDL-55NX720 TV next week.
post #3438 of 3473 Old 12-02-2014, 03:20 AM
Liked: 0
I had purchased a Sony KDL HX 720 46 inches LED TV 2 and a half years back with a 2 years warranty..
I had purchased it from Belgium and brought it to my home in India..
exactly 2 years after the purchase the TV started showing a black horizontal line across ...After a few months there is one more line...
Now there are 2 Lines and many small black lines as well..
When asked, Sony says the cost of changing the LED Panel will be around 1200 Dollars which is almost as much as the current market price of the TV..
I 'WAS' a big fan and a loyal customer of Sony...but this time I m highly disappointed...
Firstly because my TV is spoilt in 2 years' time which shouldnt have happened
and Secondly coz the repairing cost by Sony is way too high ...Its crazy..
I dont think I will buy any Sony products in Future
Companies like LG/Samsung can provide better products at a cheaper price and with really good quality..
If sony doesnt listen up...It will surely start losing a big part of their customer base..like it happened with Sony Computers and Mobiles..
Ankit Mehta is offline
post #3439 of 3473 Old 12-09-2014, 12:14 AM
Pottypotsworth's Avatar
Quoted: 60 Post(s)
Anyone know what the new software update today was for?
I'm in Asia by the way
Pottypotsworth is offline
post #3440 of 3473 Old 01-02-2015, 10:16 AM
clev1's Avatar
WiFi issue
I've had the 60NX720 for about 2 years and love the it------except for the WiFi. I have it hung on the wall in my bedroom and my wireless AC router is in the next room. Whenever I attempt to watch the built in Netflix, sometimes it works great, but about 75% of the time, it rebuffers a lot. My laptop connects at 866 Mbps sitting right beside the TV, so I know the signal is strong. Is there any way to upgrade the wifi adapter, or perhaps use a usb adapter?
clev1 is offline
post #3441 of 3473 Old 01-08-2015, 12:38 PM
CATYPH202's Avatar
-Just use Ethernet port, my 55NX720 also had on Wi-Fi much slower connection than on Ethernet. -Love my TV, btw.
CATYPH202 is offline
post #3442 of 3473 Old 01-08-2015, 12:49 PM
clev1's Avatar
You did read where my router is in the other room; right?
clev1 is offline
post #3443 of 3473 Old 01-11-2015, 09:57 AM
Liked: 0
I love my NX720 tv. Have had it for 2 years. I am getting ready to disconnect from my satellite service. I plan to use Netflix,hulu, amazon prime etc. Can anyone recommend a better controller or something else, to make the search function better? I can't stand pushing the numbers for the alphabet......... I have a samsung s4. Is the phone app the best way to go? Would I gain anything by using a Chromecast or Amazon firestick dongle?
jonlem is offline
post #3444 of 3473 Old 01-30-2015, 10:17 AM
Liked: 0
I need the component dongle in my NX720 to use the RCA connection because my cable box doesn't have an HDMI connection. Where I can buy this accessories? I really need this, please help me. Thank you
Benjvella is offline
post #3445 of 3473 Old 01-31-2015, 03:52 PM
neverfaithful's Avatar
Try Radio Shack.
neverfaithful is offline
post #3446 of 3473 Old 01-31-2015, 04:20 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Mine is still going strong .... hours everyday of kids using Xbox and WiiU and Hockey at night - plus Netflix ... TV is great for an LED.
RicFlair is offline
post #3447 of 3473 Old 02-04-2015, 05:17 PM
Liked: 0
I'm been trying contacting sony for couple of times now but they are keep giving me run arounds telling me to contact online support and online support is telling me to contact phone support and when i call phone support, they told me to contact online support.
Sony has worst support i have ever seen from big company.
Still no luck on fixing my TV.
lionjts is offline
post #3448 of 3473 Old 02-04-2015, 07:28 PM
AMartin56's Avatar
Quoted: 894 Post(s)
Liked: 361
Try hitting them up on Facebook. You'll often reach a higher level of support.
My 60NX720 purchased in Feb of 2012 is still going strong. 12k hours according to the service menu. Has always had some light bleed in the corners on single color fields but uniformity is pretty good otherwise with local dimming engaged. Most importantly letter boxes are nice and black. I wish it had better viewing angles but I have a swivel mount so I can point it at where I'm sitting.
RicFlair likes this.
Home Theater: Sony 40ES, Panamorph Phoenix, Yamaha RX-V673, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S5500, Lumagen Radiance Mini 3D, Darbee Darblet and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Epson 2040 , Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #3449 of 3473 Old 02-12-2015, 12:24 PM
CATYPH202's Avatar
If you find some chinese speaking friend maybe this could help you -
http://item.taobao.com/item.htm?id=37513331344
post #3450 of 3473 Old 02-22-2015, 01:51 AM
whatuppa's Avatar
Had my 55NX720 2yrs still have a yr left Sony E wrnty!y!
I got mine for a good price from Sony as part of their Grand Wega melting issue, I also purchased a three year extended warranty from them (it is a refurbish) So far no problems and I have almost another year left of warranty. I noticed that the paperwork on the extended warranty does not list my model, only that it is for $1500 to $2000 retail set. Thought that a bit strange. Anyone else buy the extended warranty and notice this?
whatuppa is offline
Reply LCD Flat Panel Displays
Sony , Displays , Sony Bravia Kdl46nx720 46 Inch 1080p Wifi 3d Led Hdtv , 3d Hdtv , Component Receivers , Sony Bravia Kdl55nx720 55 Inch 1080p 3d Led Hdtv
