Official Sony NX720 Owner's thread (KDL60NX720, KDL55NX720, KDL46NX720) - Page 116 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 02-24-2015, 03:41 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Anyone get a solid GREEN line down the middle ?? I get this on DTV genie playback of DVR ...any idea?
Anyone have the Cust svc number?? I keep getting hung up on??WTF
RicFlair is offline
Old 03-12-2015, 06:28 PM
sharat6669's Avatar
Broken - Sony KDL46 NX 720
Folks - help me save my TV!!
Issue : 46inch Bravia front impact , see attached pictures.No external damage.
Any one selling the TV for parts so i can get the display out of it?
Any options?
Where to buy a display in case i can?
sharat6669 is offline
Old 03-12-2015, 06:30 PM
lemketron's Avatar
Ouch! Even with Gorilla Glass that still happened?
Good luck finding a new panel (and replacing it). I would bet you may end up just having to replace the whole TV...
lemketron is offline
Old 03-12-2015, 06:35 PM
sharat6669's Avatar
I have no idea about the parts. Do you think the panel needs to be replaced? or may be some part other than the screen?
Old 03-13-2015, 09:23 AM
sharat6669's Avatar
any one wants to buy the TV at least for part? Let me know
Old 04-14-2015, 03:57 PM
Liked: 0
I wonder if people really use there brains, no offence i really do love gorilla glass and have several products with it Cellphone Dell streak, nx720 40inch.
please dont get this wrong and stop spreading semi lies. gorilla glass has nothing to do with the lcd screen itself it is the glass(plate/screen) thats mostly glued or placed after the lcd(pixel)screen itself.behind the lcd screen there is a backlight(which can be ccfl gasfilledtubes, Led, or no backlight when it is Oled, when the backlight is the lcd screen itself) when gorilla glass gets a impact the screen will bend a bit and then the lcd screen will also have a impact since the gorilla glass will show almost no scratch or big scratch the pixel screen itself is broken. mine dell streak fillep out my hand when i was drunk. Nothing to see, the glass screen still crisp and sharp but unfortatly the lcd screen behind the gorilla glass is made out of monkey material. gorilla glass is a nice gimmick feature and the glassplate on the nx series is really premium looking but dont think it will save ur lcd screen on a major impact.
cryptojunkie is offline
Old 04-28-2015, 04:21 PM
Liked: 0
hello, who can me sell the led backlight strip for sony bravia kdl55nx720?
thank you very much
fabio schianchi is offline
Old 05-20-2015, 05:41 AM
Gridson's Avatar
Hurray!
As of the 20th of April 2015, Google's YouTube app will no longer be supported on certain Sony products.
Hej, guess what.... Also my Panasonic Home Cinema is using the same app.
Outdated devices after some 3 years and a bit.
Thank you Google!
Gridson is offline
Old 10-24-2015, 10:23 AM
Pottypotsworth's Avatar
Quoted: 123 Post(s)
I guess not many people come into this thread now as this series is getting a little old, but I am posting in the hope that someone can help.
My 55NX720 has always had a bit of an issue with 3D ghosting, especially in the background (and i don't just mean a little bit of blur) but now it seems to have got to the point that it actually spoils watching 3D movies. Is there anything I can do about this? Or is it just a problem that I have to live with?
Any advice is appreciated, thanks.
Pottypotsworth is offline
Old 11-28-2015, 11:06 AM
intermediatic's Avatar
Turkey Day
Well my NX720 60" laid a big egg on Turkey Day. It went belly up blinking 4 lights. Off it went to the dump.
I was so angry with Sony for a TV failing so quickly that I got a Vizio 70" M Class. It's much, much better.
intermediatic is offline
Old 01-17-2016, 11:03 AM
teasip's Avatar
Curious to know if anyone else here has ever experienced an issue with the F-connector (antenna)/ATSC tuner having difficulty tuning only one hi-VHF channel? I can connect my antenna to my TiVoHD and have full reception of my local ABC affiliate however signal reception is intermittent when connected directly from antenna to set using same cable and is altered by degree of screwing on coax connector (less tight allows for intermittent signal reception). This has not been an issue previously and I don't attribute source as being due to signal reflection. I've tried separate coax cables. UHF channel reception does not appear to be impacted.
teasip is online now
Old 01-17-2016, 12:13 PM
jedclampit's Avatar
I'd screw a set of "rabbit ears" on there and see what you are able to scan and find, digital and analog.
UHF/VHF as in non digital signals?
I have not had that problem ever, it sounds as either you are acting as part of the antennae or you have a poor connection. Possibly the center of coax cable is of small diameter and not making a solid connection?
jedclampit is offline
Old 01-17-2016, 12:18 PM
teasip's Avatar
Nope. Digital only, and one of only a couple VHF stations still transmitting (others are steady). When coax "jiggling" impacts signal it makes me suspect the attached antenna connection to the set and not cables since it happens with two separate cables and same cable attached to antenna in on TiVo picks up signal smooth as silk.
Old 01-19-2016, 07:19 AM
teasip's Avatar
Follow up, I've now lost the other two VHF channels transmitting locally so it now appears to be a VHF issue on the antenna coax side. UHF channels through same input are fine. Anyone know if RF connector is on control board or can it be replaced?
Old 02-25-2016, 10:35 AM
de_runner's Avatar
I have a Sony KDL-60NX720 that I got on 7/8/2011. Recently the screen went blank and the red light on lower left hand corner blinks 4 times in a repeating pattern. After researching the problem I contacted Sony and they told me I should call Sears for a service call. Sears charged me $149 to diagnose the problem which would be applied to repair. The technician managed to get a picture of the screen which briefly comes up after unplugging the unit and powering back up. His diagnosis of the problem is a bad panel as evidenced by a shadow on the lower part of the screen. He said Sony offers no part replacement for this bad panel.
I recontacted Sony after that by email and then again by phone today. The phone conversation was with someone who had a heavy accent and it was difficult to clearly communicate. They indicate there is nothing they can due including no offer of any discount on a new TV to replace the now defunct KDL-60NX720 I have. My guess is the problem is a bad led light or lights internal to the panel that could likely be repaired assuming someone had the right parts, skills, tools, and knowledge. I don't have these so I'm left with a useless large TV.
Anyone know of any special contact at Sony, such as a customer relations group, that might be more willing to help? Contacting Sony support and trying communicate with people in India or wherever has not helped.
de_runner is offline
Old 02-25-2016, 10:51 AM
rollcage's Avatar
My KDL60NX720 started exhibiting darkness in the upper center of the screen. TV still turns on and works ... no blinking red lights at this time. I'm presuming an LED strip replacement is in my future. Any advice? Any luck finding parts?
Raleigh, NC
Samsung 65JS8500
TWC 9865HDC
rollcage is offline
Old 03-20-2016, 07:05 PM
BTGRE's Avatar
If you search youll find 4 blinks mean
4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground
BTGRE is offline
Old 11-13-2016, 10:34 PM
cindyh's Avatar
Quoted: 20 Post(s)
Question sony nx55729 problem can't read words on the left side of screen???
yes it has probably always done it at least for as long as i can remember but I haven't used the tv much and now its driving me crazy. On the left side of the screen the words can only be half read. I can't tell where its zoomed anywhere. any idea what settings i can check please .. Costco is having some really good tv sales and even though this is like new I'm going to abandon it if i can't fix it..
thanks in advance.
cindyh is offline
Old 11-14-2016, 05:13 AM - Thread Starter
Redoryx's Avatar
Quoted: 28 Post(s)
Liked: 39
So,
Here goes, What would a worthy replacement for this TV be. (I have the 60")
How would the X850D or the 940D stand up to this, thinking of the 75"
Redoryx is offline
Old 11-19-2016, 06:51 PM
teasip's Avatar
Just wanted to say that mine is still going strong after all this time. No issues thus far (knocks on wood). Sorry for some of the difficulties others are having (post not meant to gloat, I just haven't seen action in the thread in a long time). I even found out that what I thought was a bad VHF decoder was just a bad antenna placement apparently. I use the built-in tuner for bad weather emergencies in case Frontier FiOS goes out.
Old 11-19-2016, 08:28 PM
phantom203r's Avatar
After 5 year my 60in developed a black vertical line down the middle of the screen. Luckily my 5yr warrrenty is up on Dec. 1st. Pcrichards came today to take a look at it and will replace it with a new tv. This tv was great no clouding great blacks looked great on or off. I hope I could find a worthy replacement...
phantom203r is offline
Old 12-05-2016, 08:42 AM - Thread Starter
Redoryx's Avatar
Quoted: 28 Post(s)
Liked: 39
Keep us posted
Redoryx is offline
Old 12-05-2016, 10:19 AM
Originally Posted by Redoryx View Post
Keep us posted
Well I was able to exchange it for Samsung 65KS8000. It's a pretty awesome upgrade from my Sony, better in every way. I know I paid for the warranty but after 5 years I feel like a got a new free tv.
Old Today, 07:24 AM
teasip's Avatar
I'm sorry to have to post about this but my darn set just keeps working, and working, and working. I thought I'd messed up the ATSC VHF tuner a year ago but unfortunately that wasn't the case. Just like my old Sony Blu-Ray DVD player the darn thing just keeps on working. Why can't I buy a new toy, mommy?
Sony , Displays , Sony Bravia Kdl46nx720 46 Inch 1080p Wifi 3d Led Hdtv , 3d Hdtv , Component Receivers , Sony Bravia Kdl55nx720 55 Inch 1080p 3d Led Hdtv
