Samsung UN46D6000 Won't Save my Picture Settings! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-06-2011, 07:47 PM - Thread Starter
ieatbugs's Avatar
Hello All,
just picked up a 46" D6000. It defaults to Dynamic picture so I went ahead and set it to Standard and adjusted some settings, backlight, contrast, sharpness etc. After I turn the tv off and back on, it defaults back to Dynamic! What am i doing wrong?
thanks for help.
ieatbugs is offline
post #2 of 9 Old 04-07-2011, 07:15 AM
walford's Avatar
After changing the Standard settings what did you do to save them before you turned the TV off to insure that Standard Mode with your new settings was the default mode for the port you are using?
walford is offline
post #3 of 9 Old 04-07-2011, 09:37 AM
djams's Avatar
Many tv's behave like this when running in 'demo mode' (for in-store display)
djams is offline
post #4 of 9 Old 04-07-2011, 02:47 PM
Steve S's Avatar
Liked: 46
Originally Posted by ieatbugs View Post
Hello All,
thanks for help.
It's in Store Mode. If you have the manual or if the set has an onscreen manual feature go to troubleshooting and scroll down to the item that says "picture settings change after 30 minutes" or something like that. If you don't have the manual try this--with the input button select TV, then enter the menu go to system or setup, select "plug & Play" and you should be able to put it in "Home" mode.
Steve S.
Steve S is offline
post #5 of 9 Old 08-27-2012, 08:22 PM
Timmy B's Avatar
Answered my question too! Thanks!
Timmy B is offline
post #6 of 9 Old 09-28-2012, 11:51 AM
mkrodhd's Avatar
Wow, a week-long headache just went away. Started using a Samsung 32" LCD TV that had been in storage for a while, and got that black screen every ten minutes and Standard settings wiped out. Was unaware of the Plug and Play sequence to change to Home mode. Gotta love AVS forum!biggrin.gif
mkrodhd is offline
post #7 of 9 Old 08-16-2013, 06:02 PM
Robert Potinteu's Avatar
Robert Potinteu is offline
post #8 of 9 Old 03-13-2014, 12:45 PM
SoulFinder's Avatar
Just had to sign up to say a massive thank you. You have saved my ears from being bent by my elderly father... he was getting frustrated at having to reset his picture settings every time he switch on. Your post here was the answer.... Thank you
SoulFinder is offline
post #9 of 9 Old 03-02-2015, 02:56 PM
Liked: 0
i also had to set up an account to thank you so much it just saved me hours and days of frustration your the best!! worked perfect and even the screen retention finally went away it seemed when locked in store mode it kept a faint image of the demo screen but now gone!! yaaaaahhhoooo!!!!!!!!!!!
luckytvguy is offline
Reply LCD Flat Panel Displays
Samsung Un46d6000 46 Inch 1080p 120 Hz Led Hdtv Black , Led Hdtv
