SONY LCD TV banding problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-22-2011, 10:27 PM - Thread Starter
houston7700's Avatar
Bought SONY LCD TV model KDL-46V5100 on June 9th 2009, and started having banding problem Feb 2011, out of manufacture warranty (only 1 y).
There are red / blue vertical bars on screen, at first they will go away if I switch channels, now its kind of persistent.
Not sure what exactly is the problem, I think its banding problem?
Is there a easy fix for it or should I trash it and buy a new one?
Thanks !
houston7700 is offline
post #2 of 5 Old 04-22-2011, 10:56 PM
redgtxdi's Avatar
Wow! Don't need a discerning eye to see that one, eh?
I honestly don't know what that is. Amazing that it's doing it in colors.
Hope you can find a solution.
redgtxdi is offline
post #3 of 5 Old 04-22-2011, 11:11 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Thats a faulty tab.
Do-It-Yourself is offline
post #4 of 5 Old 04-23-2011, 02:28 AM
Extreme_Boky's Avatar
Ditto, it's manufacturing flaw, demand a replacement from Sony
Boky
Extreme_Boky is offline
post #5 of 5 Old 04-25-2011, 11:17 AM
SonyListens's Avatar
Hello Houston7700,
My name is Evelyn from Sony electronics the SonyListens team. Please e-mail the information in your previous posting and your contact information so that we can further assist you. Either I or one of my SonyListens team members will contact you shortly. Thank you.
Best Regards,
Evelyn Perez
SonyListens@am.sony.com
SonyListens is offline
Reply LCD Flat Panel Displays
