Official Samsung LNxxD630 Owner's Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 610 Old 01-14-2012, 09:39 AM
rta53's Avatar
With the component connection (RGB) you will probably get a little better quality than with the composite (Yellow) but not a huge improvement. I prefer connecting devices directly to the TV but either way would work with the Xbox. The Samsung has connections on the right side for composite which is pretty handy for gaming consoles.
rta53 is offline
post #272 of 610 Old 01-14-2012, 03:42 PM
audio/videoman's Avatar
Anyone done a side by side comparison of the samsung lnxxd550 with the lnxxd630?
How much does the 120 hz panel help?
What about amp?
Are these two features worth the difference in price?
audio/videoman is offline
post #273 of 610 Old 01-15-2012, 03:58 AM
vtpossum's Avatar
If you go back and read this thread or google AMP you will see that most do not like it.
vtpossum is offline
post #274 of 610 Old 01-15-2012, 03:59 AM
vtpossum's Avatar
On the Wii concept, that XBox Kinnect she has is currently attached to the front of the DVR/VHS recorder in AV2 with the red,yellow,white. Do you imagine with the new setup it would be better served with the what, red/blue/green component wiring directly into the new Samsung or is is more likely it'll still feed into the combo? Am I making this a lot harder than it probably will be when I put it together? Thanks.[/quote]
I have the wii hooked up through component and it is a much better picture than with the composite connection. A lot brighter and less fuzzy.
vtpossum is offline
post #275 of 610 Old 01-15-2012, 04:33 AM
Buckeye911's Avatar
What about amp?
I hate amp but the 630 just plain has a better picture than the 550. I've only seen the ln40d630 in the stores as I'm probably going to buy one for the bedroom but there's a ln37d550 at work that I get to see quite a bit of. I much prefer the 630.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #276 of 610 Old 01-15-2012, 11:59 AM
T-nm's Avatar
Isn't it common knowledge that component is better than composite?
T-nm is offline
post #277 of 610 Old 01-15-2012, 01:40 PM
pbarach's Avatar
Quoted: 370 Post(s)
Liked: 221
It's true but how common is it?
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #278 of 610 Old 01-15-2012, 06:24 PM
T-nm's Avatar
Well, since it's more modern than composite and takes 3 cables for video only compared to only one.
I don't want to sound like a douche though, there is so much in this industry that doesn't make any sense.
EDIT: I have the 46" model of this television, it's my first LCD ever. The television I was using before this was a 17 years old 33" (yes, 33) Hitachi CRT.
Anyways, I plugged my computer with a 35 foot long HDMI, works like a charm. It's plugged in the HDMI that's called "DVI to HDMI" in the manual. For some reason I can't put this signal in Game Mode. Not a real problem for me, I was just wondering why.
T-nm is offline
post #279 of 610 Old 01-15-2012, 06:26 PM
Rob_Chew's Avatar
Does anyone know for sure if the LN40D630 supports ARC (Audio Return Channel)? I want to get a soundbar and let it do the HDMI switching so I need to know for certain. I have Googled and searched for the answer including the product spec sheets, Samsung's knowledge base, etc. and cannot find the answer.
Rob_Chew is offline
post #280 of 610 Old 01-16-2012, 04:56 AM
Thanks. I had a chance to check out the 630 over the weekend. I can't really comment on overall picture quality, as the demo set was completely tweaked out--max contrast, brightness, color, you know how they do it.
I did demo the amp feature (via the split screen demo). If you are watching casually, and if there is little movement on-screen, it's hard to tell if it's on or off.
However, with (very) fast moving images, such as with sports, the difference in clarity is noticeable and appreciable. The same holds true with scrolling text.
I did not notice any strange artifacts with amp turned on. However, I was unable to verify the exact setting--aside from the fact that it was on "demo mode," whatever that may mean as far as specific amp settings are concerned.
Overall, I'd say it's a useful feature for sports, and more or less unobtrusive or just plain unnecessary with other sources.
The source material in no way resembled shoddy video material (i.e., the so-called soap opera effect) with amp on. Film still looked like film.
From my brief demo, it appears as if amp works pretty darn well--meaning it works when it's supposed to, and doesn't change image quality noticeably otherwise.
I must say I am still quite happy with my 60 hz tv, but this is a feature I'd be happy to shop for in the future.
post #281 of 610 Old 01-16-2012, 06:37 AM
pbarach's Avatar
Quoted: 370 Post(s)
Liked: 221
You can't judge the AMP effect fully unless you're watching a movie--i.e., filmed material, not sports. You will then see the "soap opera effect" in demo mode (which splits the screen vertically and shows AMP on half the picture) or in standard mode. It's very obvious. Movement looks overly smooth for film--I find it unnatural and distracting. Some people turn it off completely; for me, I find it unobtrusive at its "Clear" setting.
Before buying this set, you might want to go back to the store and ask them to let you play with the remote to see if you like what you get. I can tell you that I'm extremely happy with the picture quality of this set in every way. My only quibble with this TV is that the arrow keys on the remote, and the ENTER key in the middle of them, are quite flat, and it's too easy to push the wrong one. I have never used the internal speakers, so I have nothing to say about the sound quality.
pbarach is offline
post #282 of 610 Old 01-16-2012, 12:40 PM
Rob_Chew's Avatar
Nevermind. Called Samsung and they confirmed it supports ARC, but only on HDMI 2.
Rob_Chew is offline
post #283 of 610 Old 01-16-2012, 03:07 PM
coachkecz's Avatar
Originally Posted by Alpione View Post
Well this is interesting. I switched to 720p rather than 1080i on my U-Verse box and the stuttering pretty much went away...
Also - any drawbacks from going 720p over 1080i on the D630?
Adam
While it can be difficult to discern the difference in resolution (depending on screen size and viewing distance) do not underestimate the potential for SCALING artifacts. You want to minimize the amount of processing and scaling in general. If scaling is necessary then make sure that it is being done by the most competent piece of equipment you have. Usually the cable box is the worst at doing this.
coachkecz is offline
post #284 of 610 Old 01-16-2012, 03:22 PM
coachkecz's Avatar
I highly recommend bias lighting. If we're just flipping through the channels I'll usually just dim the lights a little, but if we're settling in for some quality viewing then the bias light comes on and the house lights go off. It reduces eye strain and gives just enough ambient light so you don't trip if you have to get up during a dark scene. It also seems to give the picture a little more "pop", perhaps because the black bars around the image seem even blacker with that little halo of light emanating from around the bezel.
post #285 of 610 Old 01-18-2012, 07:58 PM
drmax's Avatar
Originally Posted by Mr.interested View Post
I also have this TV connected via its Ethernet port into my home wired network. The TV only connects at 100 and not gigabit but thats ok as gigabit is not required. The built in media player is able to find my DLNA Twonky media server, that runs off my NAS with no issues. It plays all the .avi (divx/xvid) files i have, and only a few of the .mkv files i have.
The only real problem i have with this TV so far is that its built in media player is quite poor and does not play all my .mkv's. It does not make a whole lot of sense why, since my PBO media player and my WD media player ( on another TV) plays all my .mkv files fine. I was able to get some 720p and 1080p .mkv's to work on the samsung, but many of my other 720p .mkv videos do not play at all.
Hello. I am close to getting this TV. I am interested in the ethernet connection. I'm running 2 hdmi cables and 2 cat5 cables to my tv area to my basement pc, and using pc as a htpc. I can pump the avi movies off pc to tv via hdmi, but you mentioned you're able to do this over the ethernet. Is cat5 doing well at this? I'm even wondering why I need to run the hdmi's, other that the fact of having them routed through the wall now, instead of later. Please explain. Also advise if you still think the TV is worth the $$650 price tag. I like this set for the (less than) 39" width, as is what my cabinet is. My other choice would be LED samsung, but not sold on edge lighting quite yet. Anyone is welcome to advise on any of my concerns. DM
drmax is offline
post #286 of 610 Old 01-18-2012, 08:01 PM
T-nm's Avatar
Lan connection only works with DLNA, which is a mess. The TV reads files perfectly with a USB drive, even blu-ray quality videos, like a 10gb files...
T-nm is offline
post #287 of 610 Old 01-18-2012, 09:52 PM
drmax's Avatar
will be using good quality hdmi. my pc to tv is 50'. too long of run (for me) with usb. dnla seems like it'd work pretty good as well. will hook it up and give it a try. take care....dm
drmax is offline
post #288 of 610 Old 01-19-2012, 10:09 AM
rdevine27's Avatar
Can you confirm that it did indeed work? It's funny, I just picked up a soundbar last night for my 46D630, and after digging around on the internet for quite some time, I was disappointed that it didn't seem to support ARC. I remember reading that Samsung only added this feature to their 3D sets. I was resigned to rustling up some optical cables to make it all work. The ability to do HDMI switching is a really cool and tidy way to organize your system. I have the same soundbar hooked up in another spare bedroom to a Sony 909 which clearly was labled for ARC support.
I'm glad I came to this thread, but something tells me that Samsung is wrong here.
rdevine27 is offline
post #289 of 610 Old 01-19-2012, 10:55 AM
Rob_Chew's Avatar
I haven't tried it yet as I wanted to confirm that it did before I bought a soundbar (I'm leaning towards the Vizio VHT215 or the Sony HT-CT150).
I'm wondering if it supported it out of the box or in a later firmware update as I have not updated the firmware on my TV. There's also the possibility the person I talked to could have been misinformed, but I questioned her twice and she seemed positive it was supported on HDMI-2. I guess we won't know for sure until we give it a try.
Rob_Chew is offline
post #290 of 610 Old 01-19-2012, 11:34 AM
rdevine27's Avatar
Thanks for the follow-up Rob (My name is also Rob BTW...), and the soundbar that I just purchased for the D630 is indeed the Sony CT150. Best Buy has it on sale for $209.99 currently. In the store, it comes up $299, but online it's listed for the sale price. They matched their online price with absolutely no problem. It was nice to load it into my car and not have to worry about the thing being damaged during shipping. BB's price is actually cheaper than Amazon, which doesn't even have it in stock.
As for the 150, I initially purchased one for another TV, and I was absolutely impressed with the sound quality. I like it so much, that I just got the 2nd one. The reviews are certainly more than favorable, and it's a great little system for a bargain price of $210. It gets plenty loud, looks really sleek, and makes for a clean and simple setup. The D630 speakers are absolutely god-awful to my ears, and it's hard to even hear dialogue with the volume cranked up. This soundbar will surely add another dimension to the experience.
I'm going to hookup the soundbar tonight, and fingers crossed that it supports ARC. The manual makes no mention of it, and my Sony TV that does support ARC stamps it next to the appropriate HDMI input on the back of the set. The fact that it's missing on the Samsung leads me to believe we may be out of luck.
But we can certainly try! And you won't be disappointed in the Sony soundbar either. I have no experience with the Vizio unit. The 150 does a great job for its intended purpose. It's loud, quality sound, if not surround sound. But for most applications, it's perfect. And the subwoofer really does thump along...
post #291 of 610 Old 01-19-2012, 12:28 PM
Rob_Chew's Avatar
Thanks Rob and can't wait to hear how you make out tonight.
Rob_Chew is offline
post #292 of 610 Old 01-20-2012, 04:58 AM
rta53's Avatar
Did you get the sound bar installed? Are you mounting it to the TV? I'm thinking about getting one of these.
rta53 is offline
post #293 of 610 Old 01-21-2012, 08:58 AM
rta53's Avatar
I ended up buying one of these from Best Buy last night. Hope to get it set up today. From the reading I've done it seems the ARC only works with Sony TVs. My receiver doesn't have HDMI anyway so it's not an issue for me. Although this does sound like a neat feature.
rta53 is offline
post #294 of 610 Old 01-22-2012, 12:56 AM
T-nm's Avatar
Originally Posted by Dustxking View Post
I found this post and i am going to try this one out tomorrow after work see how i like it.
"Hey I have been messing with the picture settings here and there and this is what I use for my PS3/Blu-ray source on my LN40D630. I start at "movie mode" and this allows you to do minimum adjustments to calibrate it. Also I have Auto Motion Plus shut off, this is simply my preference, and some people like to go with "smooth" but I simply don't see the need. I didn't arrive at these settings using a calibration disk, I found a site that reviewed this TV and I made adjustments from their "professional" settings. Beauty is in the eye of the beholder and everyone's preference is different, so ultimately it is up to you, but here are mine if you are interested........
Color Temp: Warm 1
Backlight:7-10 depending on your lighting environment (basement or bright room)
Brightness:47
Contrast:95
Color:45
Sharpness:5
Tint:G49/R51
White Balance Settings:
Red Offset: 28
Green Offset: 25
Blue Offset: 16
Red Gain: 25
Green Gain: 25
Blue Gain: 21"
Just wanted to say that these settings work perfectly on my setup: 35ft long HDMI from my computer to the TV.
This TV has indeed too much back light and blue on default settings.
T-nm is offline
post #295 of 610 Old 01-22-2012, 07:06 AM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 260
"Beauty is in the eye of the beholder and everyone's preference is different, so ultimately it is up to you...."
Unfortunately this type of confusion persists, even in the AV Science Forum. This statement is patently false in the context of video performance. The world of video is governed by internationally recognized standards and recommended practices. People who produce video programs want their work to look (as much as possible) the same at the delivery end of the process as they conceived them, NOT some distorted version. When the hardware is misaligned (uncalibrated) it cannot deliver the program unaltered. To purposely alter the look of a program in order to appeal to an individual's preference is their choice, but simply not what was intended by the program's creator. Image fidelity is the fundamental goal of an image-based communications system.
As Joe Kane persists in saying: "It's all about the art." Individual audience members are not expected to change the way a movie appears in a commercial cinema, or an exhibit in an art museum, or a photo gallery. Where did we get the notion that such behavior should be encouraged in a home cinema?
'Display Calibration: Root Fundamentals'
http://www.avsforum.com/avs-vb/showthread.php?t=1021933
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
GeorgeAB is offline
post #296 of 610 Old 01-23-2012, 06:34 AM
paulman182's Avatar
I suppose the notion arises from the fact that I OWN the home cinema and have either PURCHASED or RENTED the movie and should be able to view it as I wish, in the same way that I am free to use my crayons on an Ansel Adams print that I OWN if I so desire.
My own preference is to view a properly-calibrated image but that is MY preference on MY equipment. I'm sorry, but elitism rubs some of us the wrong way.
paulman182 is offline
post #297 of 610 Old 01-23-2012, 07:43 AM
GeorgeAB's Avatar
Quoted: 152 Post(s)
Liked: 260
"Elitism," as you suggest, has nothing to do with the issue. It's far too often a matter of consumers not being taught video fundamentals. No one suggests you can't do what you will with your own property. No one prevents you from experimenting with any picture control on the display. What is at issue is the option of achieving fidelity or preferring something else. Recommending or enjoying an authentic image is never a threat to anyone's autonomy as a viewer. Fidelity simply offers the artist's original program, or as close to it as the format and/or equipment allow. "Picture quality" in video terms has a precise definition, based upon video industry standards and practices.
An apt analogy would be a song composed, arranged, performed, recorded, and then played back over a high fidelity sound system in a specific musical key. Some record players have offered the ability to alter the speed ever so slightly, to deviate from the 33 1/3 RPM recording industry standard. This would result in the music sounding off-key. This might be a preference for the owner of the record and record player, but a distortion in the view of the composer, or performer, or recording engineer, or most other listeners, etc. Excellence in the recording industry is understood as preserving and delivering a performance as true to the original as possible. The same goes for the video industry. Display system calibration is a means to that end.
GeorgeAB is offline
post #298 of 610 Old 01-23-2012, 05:00 PM
Maxivision's Avatar
Hi I'm a noob to this forum, what a find! I like my Samsung LN40D630 but when using it to display my laptop via an HDMI, the image is smaller than full screen and the picture size control won't help. It's a perfect image, just has a border around it and I can't get it to enlarge. I haven't messed with the laptop's graphics card , it is an Intel on a Toshiba satellite laptop. any hints to get the laptop's display to take up the full size on the Samsung? Thanks.
Maxivision is offline
post #299 of 610 Old 01-23-2012, 05:53 PM
Balazo's Avatar
Glad I could help some people out. I was the original poster of those settings (sorry I never get credit for them) and I haven't had to adjust them since I calibrated mine. The new LOTR Extended Blu Ray looks great with these settings, and there are absolutely no color issues (on this set at least). These settings can be a little dark during the day, especially in a bright room, but they should be perfect in a darker room or when the lights are off.
Earlier in the tread someone experienced this problem, and was able to resolve the issue by renaming the input to "PC" or "PC DVI". That allows the source to go up to 1920x1080 and should give you a better picture. Also you can try changing your laptop's resolution settings when you hook it up to the TV, but you may have to change it back every time you do it.
Balazo is offline
post #300 of 610 Old 01-24-2012, 02:31 PM
I'm interested in this tv primarily for it's amp feature. However, it seems like a significant percentage of owners are leaving it off. There are lots of complaints about jerky playback/momentary freezing. Is this issue as widespread as it seems from reading the first few pages of this thread, or is this problem largely solved by now?
Reply LCD Flat Panel Displays
Samsung Ln46d630 46 Inch 1080p Lcd Hdtv Black , Lcd Hdtv
