Official Samsung LNxxD630 Owner's Thread - Page 21 - AVS Forum | Home Theater Discussions And Reviews
post #601 of 610 Old 07-21-2013, 04:35 PM
Justin Sullins's Avatar
Liked: 32
Originally Posted by pbarach View Post
As they say, "your mileage may vary." I have no banding or other screen artifacts whatsoever on my set, and the majority of people posting here about this set haven't had such complaints, either. I haven't dealt with Samsung's warranty service, but there is no reason to assume that a replacement panel will have the same problem, since there are panels from several manufacturers that were used for this model.
Glad your set is perfect. Have you tested your D630 for banding? I have it bad but don't see it unless I'm watching something with poor black levels, (SD Program), or panning shots with lighter colors. With that said, I only see the terrible banding 20% of the time. What panel version do you have? I should've mentioned the SQ01, which is a Samsung Panel, has flashlighting and banding issues but better overall PQ than other Samsung and Non-Samsung Panels for the D630. Maybe you have a different, non-Samsung Panel with better overall uniformity but bad viewing angle and weaker colors than the SQ01. I have dealt with Samsung's Warranty Service many times and was always dicked around and never did I have anything resolved. To each his own and I did recommend not calling Samsung but maybe OP should to see what the issue is since I don't know exactly what it is. My 1st Samsung had DSE and Banding and they replaced the Panel to no avail. They used a different type of Panel the 2nd time and made it worse. I later found out that most LCDs have DSE/Banding even expensive sets such as the HX950, regardless of what panel. As I said in my comment to the OP that Samsung might replace the Panel to appease but the issue won't go away unless it's a different panel type and even then it might be worse.
Justin Sullins is offline
post #602 of 610 Old 08-14-2013, 12:02 PM
retihsuhnt's Avatar
Quick question regarding the LN40D630's supported video formats. I am 99% sure, according to the documentation I have been able to locate, that all the following video formats are supported, but wanted to ask to be on the safe side:
1080p 30fps
1080p 24fps
1080i
720p
480p
480i
The reason I ask is because I have recently returned to the land of "cable" and am now using a Motorola DCX3501-m STB and want to use its "native" mode.
Thanks in advance for the assist.
retihsuhnt is offline
post #603 of 610 Old 09-02-2013, 07:51 PM
rescue119's Avatar
Hi all. I can't seem to find a solution to a problem with my tv. It started flickering, no matter what source, and then the screen goes black. It seems the c630 models had à quick fix by cutting a jumper on the power supply board. So I looked at it to see if maybe that was possible but the board looks to have been updated from the C model. I have a extended warranty on it, it's 1.5 years old, but it's my only tv so if there is a at home fix I can do instead of taking it in and waiting a couple of weeks for it to get fixed I would do it.
Thanks in advance
rescue119 is offline
post #604 of 610 Old 09-05-2013, 12:52 AM
snicker110's Avatar
Does anyone know good settings for a Samsung LN46D630 for gaming? Game mode isn't doing it for me:/? Help anyone?
snicker110 is offline
post #605 of 610 Old 09-20-2013, 05:58 PM
rescue119's Avatar
Tv got fixed today. Replaced power supply
post #606 of 610 Old 11-26-2013, 03:21 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
Can someone explain what these settings on the Samsung are for and how you calibrate them? (P.S. I have cross-posted this message to the forum for the Spears & Munsil HD calibration disk 2nd edition, which just arrived)
1. The TV offers Color Space options of Auto, Native, and Custom. If you turn on Custom, you get additional settings of each color (red blue, etc.), and under each color there are separate sliders for red, green, and blue.
2. Under White balance, there are settings for R-Offset, B-Offset, and G-offset, and R-Gain, B-Gain, and G-Gain. What are these settings for?
3. Finally, if I turn on 10p White Balance, there are additional settings like this:
Interval 1: Red 3, Green 3, Blue 3
Interval 2: Red 3, Green 3, Blue 2
Interval 3: Red -2, Green 0, Blue -2
Interval 4: Red 2, Green 0, Blue -2
Interval 5: Red 2, Green 2, Blue 3
Interval 6: Red -7, Green -6, Blue -9
Interval 7: Red -6, Green -5, Blue -6
Interval 8: Red -4, Green -3, Blue -3
Interval 9: Red -4, Green -3, Blue -2
Interval 10: Red -2, Green 0, Blue 3
Thanks for explaining
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #607 of 610 Old 08-16-2014, 12:26 PM
Liked: 0
My picture "jumps" every several seconds, but seemed only to happen when I used the blu-ray player, so I thought it was the player's fault. Just bought Apple TV, and the same thing is happening. I have never noticed it happening when I watch TV. I don't even know what to call this problem. Help?
hugocole is offline
post #608 of 610 Old 08-16-2014, 02:58 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
Do you have AutoMotion Plus turned on? If so, this is likely the culprit. I have gotten the best results (when the video skips) by changing the setting from STANDARD to CLEAR, or else just turning it off.
pbarach is offline
post #609 of 610 Old 02-05-2015, 10:16 AM
Toddo_69's Avatar
Can anyone confirm please which wifi dongle / wireless LAN adapter works with this model? and does a DLNA media server work with the wireless adapter?
Toddo_69 is offline
post #610 of 610 Old 07-25-2015, 08:35 AM
Liked: 0
Wobbly stand
Gents,
I have a LN46D630M3FXZC. It came with a stand, BN61-07454A #1 . Unfortunately when I was moving, I lost one of the two plastic washers/rings that came with the stand. Now upon assembly, the tv wobbles and I'm hesitant on using it. It is the inner ring that goes inside the base.
I called Samsungparts Canada, and they said they can help me out by selling me the entire base (not just 1 or 2 of the washers.) But then they came back with a ransom price of $130. So clearly I gave up on that. I found the manual online for the TV from samsung's site, but didn't even see a mention of the washers, or a part number or anything. Just said put the guide and base together and connect with four screws.
I even tried walking around Home Depot and finding a substitute/make do replacement but had no luck. I'm was about to give up on the stand and wall mount it but then I came across this forum. Anyone have any advice on where I can actually get this part (and that ships to Canada), or anything else I can replace it with?
symetirx is offline
Reply LCD Flat Panel Displays
Samsung Ln46d630 46 Inch 1080p Lcd Hdtv Black , Lcd Hdtv
