Need help with my Olevia 232-T12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-01-2011, 10:33 PM - Thread Starter
Pixonova's Avatar
Hey guys, found avs forums through Google, and now I'm in a bind.
I was given an Olevia 232-T12 TV, and replaced my failing TV with it. I also have an Apple TV 2G for Netflix and audio streaming. However the ATV2 only allows HDMI use.
I tried to plug it into the Olevia, and all I get is invalid format. I looked into this, and it requires a firmware upgrade. A firmware upgrade that Olevia no longer supplies (Will not own another one of these TVs again!).
Would anyone happen to have this upgrade, and also a user manual for this TV?
I believe there are two types of the 232 as well. I'm not sure which mine is, though.
Pixonova is offline
post #2 of 5 Old 06-01-2011, 10:49 PM
primal_phil's Avatar
User Manual
Takes sometime to load...
primal_phil is offline
post #3 of 5 Old 06-01-2011, 10:53 PM - Thread Starter
Pixonova's Avatar
Thank you so much! Will this also tell me where to download firmware updates that aren't from Olevia's site?
Pixonova is offline
post #4 of 5 Old 06-01-2011, 10:58 PM
Can't really say didn't check the manual
post #5 of 5 Old 07-24-2011, 08:48 PM
tonykas's Avatar
Hey Guys, I need some help really bad! I have a Olevia 232 T12, FM1-037000EGO05. My problem just started about 1 week ago. The video just turns off, the screen goes black. I turn the power off for a minute or so and the TV turns back on. I am aware of this firmware update but I don't have a clue where to find it or if I need it. If anyone is having a similar problem or know where I can find this firmware update, please inform me. I would really appreciate it. I don't have a clue what else to do. The warranty is expired so I need some advice, Thanks a lot!!!
tonykas is offline
Reply LCD Flat Panel Displays
