Sharp IP Control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-05-2011, 09:59 PM - Thread Starter
Crazy Canuk's Avatar
HI Everyone
I have a requirement where I could really use "IP Control" that Sharp offers on some of their TV's. The manual tells you what the commands are, but does not tell you how to send them. Does anyone know what software you would use to do this? Is there a disk that comes with the television that provides this or do you send it form a DOS prompt or a Telnet session?
Any help is appreciated. I called Sharp tech support and after initially telling me it wouldn't work over IP, I read them what it it said in the manual and they indicated I was the first one to call with such a question and they did not have an answer.
Crazy Canuk is offline
post #2 of 7 Old 06-16-2011, 10:21 PM
cafftab's Avatar
I used Hyperterminal using TCP/IP. and the command in the table worked fine
cafftab is offline
post #3 of 7 Old 10-13-2011, 01:02 PM
rbh123456789's Avatar
+1
execute hypertrm from your run dialog box.
-name your connection (eg TV)
-select the icon you want to use
-enter the IP of the TVs mac address
-change the connection to TCP/IP
-enter port 10002, which is the default that Sharp uses
-enter the username and password you setup on the TV
now its just a matter of sending the commands to the TV, which are in your manual.
rbh123456789 is offline
post #4 of 7 Old 11-12-2011, 05:49 AM
13lade's Avatar
I found an iOS app which works for controlling my sharp tv for $4.99...called "pTerm". Very simple to set up and send the commands in the same fashion as hyoerterminal.
I just wish I could build a browser page to execute these commands in a more wife-friendly fashion.
13lade is offline
post #5 of 7 Old 11-12-2011, 04:44 PM
blkicevic's Avatar
Quoted: 54 Post(s)
Liked: 35
irule has the codes for the new sharps but i believe the nics on the sharp itself have issues. i cannot get the tv to respond to power on commands when the unit is turned off.
I do not condone what i do, but i will not deny myself the pleasure!
blkicevic is offline
post #6 of 7 Old 12-22-2012, 10:26 AM
Bloup's Avatar
@blkicevic
In case someone else looks this up. You have to send the following command to allow Power On via IP: RSPW2
Putty or Hyperterminal can be used to send commands to the TV. The manual has good info on it.
Bloup is offline
post #7 of 7 Old 04-20-2014, 10:21 AM
cvidal's Avatar
I know this is an old thread, but...
Has anyone succeeded in getting a response on the following commands:
Device Name TVNM1___
Model Name MNRD1___
Software Version SWVN1___
IP Protocol Version IPPV1___
Although I don't get an error response, nothing is displayed on the TV.
cvidal is offline
Reply LCD Flat Panel Displays
