Official Sony HX929 Settings & Calibrations Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 273 Old 06-13-2011, 06:49 AM - Thread Starter
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
Please try to keep things limited to settings and calibrations posts. Please refer to the owners thread for discussion.
http://www.avsforum.com/avs-vb/showthread.php?t=1318875
CNET
Home menu>Settings>Picture & Display
--Picture Adjustments menu--
Setting Memory: [any]
Picture Mode: Custom
Backlight: 1
Picture: 90
Brightness: 52
Color: 50
Hue: 0
Color Temperature: Warm 2
Sharpness: 50
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot noise reduction: Off
Reality Creation: Off
Smooth Gradation: Low
Motionflow: Off
CineMotion: Off
-Advanced Settings submenu-
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: +1
LED Dynamic Control: Standard
Auto Light Limiter: Off
Clear White: Off
Live Color: Off
White Balance: [see below]
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturalizer: Off [grayed out]
i/p Conversion Preference: Quality [grayed out]
-White Balance submenu-
R-Gain: -5
G-Gain: -1
B-Gain: -6
R-Bias: 0
G-Bias: 0
B-Bias: 0
Ambient Sensor: Off
--Screen menu--
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Auto Display Area: Off
Display Area: Full Pixel
Screen Position: [grayed out]
Vertical Size: 0 [grayed out]
--Pro Picture Setup menu--
[all settings default/Auto]
--Home Menu>Settings>Preferences--
--Scene Select menu--
General
--Eco menu--
Power Saving: Off
FlatpanelsHD
After calibration
Picture mode: Cinema/Theatre
Backlight 7
Contrast 84
Brightness: 50
Colour: 50
Hue: 0
Sharpness: 0
Colour temperature Warm2
Noise reduction Off
Mpeg noise reduction Off
Dot Noise Reduction Off
Reality Creation Off
Smooth Gradation Off
Motionflow Clear Plus
Film-mode Auto 1/Auto 2
Black corrector Off
Adv. Contrast Enhancer Off
Gamma +1
LED Dynamic Control Standard
Auto Light Limiter Off
Clear White Off
Live Colour Off
Detail/Edge/ enha. Off
R Gain -3
G Gain -6
B Gain 0
R Bias -2
G Bias 0
B Bias +1
75X850C l 65B6P l P55-C1 l SB4551-D5 l XB1 S l PS4 Pro l LIVE:BPMURR l PSN:BPMURR
bpmurr is offline
post #2 of 273 Old 06-13-2011, 07:01 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Very good. Let's get this thread rolling.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #3 of 273 Old 06-13-2011, 07:22 AM - Thread Starter
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
Here are my settings for both light and dark environments. Ambient adjusts backlighting.
Backlight: Min but I have the sensor on so it doesn't matter
Picture: Max
Brightness: 49
Color: 51
Hue: 0
Color Temp: Warm 2
Sharpness: 50
MPEG NR: Off
Dot NR: Off
Smooth Gradation: Off
Cinemotion: Auto 2
Advanced Settings:
Gamma: 0
Auto Light Limitier: Off
Clear White: Off
Live Color: Off
White Balance - Defaults
Detail Enhancer - Off
Edge Enhancer - Off
Ambient Sensor: On
Pro Picture Setup
SBM: Off
Picture Mode: Game-Original
Picture: Max
Brightness: 49
Color: 51
Hue: 0
Color Temp: Warm 2
Sharpness: Min
Advanced Settings:
Gamma: 0
Clear White: Off
Live Color: Off
Edge Enhancer - Off
i/p Coversion Preference: Speed
Ambient Sensor: On
Pro Picture Setup
SBM: Off
bpmurr is offline
post #4 of 273 Old 06-13-2011, 07:55 AM
Digital lab's Avatar
Just a thought could you add the type of room the settings are used in (dark room or bright room)
Digital lab is offline
post #5 of 273 Old 06-13-2011, 07:58 AM - Thread Starter
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
Well since I'm using the Ambient Light Sensor it works in both.
bpmurr is offline
post #6 of 273 Old 06-13-2011, 08:13 AM
rclams's Avatar
Originally Posted by bpmurr View Post
Reserved for review settings & Calibrations
Should there be "classification" of Settings offered?
==> ROOM LIGHTING (Fully controlled vs. Some control vs. Bright daylight)
==> SOURCE (BluRay vs. HDTV vs. Streaming, etc.)
Waiting for the All-Digital, 3D HDMI, No Artifacts, No Burn In Monitor... Did I mention cheap? ;^)
rclams is offline
post #7 of 273 Old 06-13-2011, 08:14 AM
Fordlightning's Avatar
Picture mode : Standard
Backlight : 6
Picture : 89
Brightness : 45
Color : 54
Hue : R1
Color temp : Warm 2
Sharpness : 66
Noise reduction : Auto
Mpeg Noise Red : Auto
Dot Noise Red : Auto
Reality Creation : Auto
Smooth Gradation : Low
Motionflow : Clear
Cinemotion : Auto 1
Black Corrector : High
Adv Contrast Enc : Low
Gamma : -1
Led Control : Standard
Auto Light Limiter : Medium
Clear White : Off
Live Color : Off
Detail Enhancer : Medium
Edge Enhancer : Off
Ambient Sensor : On
Full Pixel
3D
Led Control : Standard (have to change this, its set to off, and makes difference in blacks)
Glasses : High
XBR55HX929/HT-CT550W, LN46A750/HT-WS1R, PS3 60g(now 320g WDblack), Xbox 360 60g, Wii, Gaming PC. Xbox Live:Fordlighting, PSN:Gatorsnack.
Fordlightning is offline
post #8 of 273 Old 06-13-2011, 08:20 AM - Thread Starter
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
Well for me it's not source dependent as all my sources run through the same receiver. However, those who run direct to the TV might have different settings.
bpmurr is offline
post #9 of 273 Old 06-13-2011, 08:55 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Originally Posted by ratherb1 View Post
should we do this
we probably all go back and forth between threads (owners/settings thread) so it would be great to try to keep the thread just settings only so we dont have to go through a hundred pages trying to find someones settings maybe we can quote/comment in the owners thread instead idk if so i will delete this or we can post something like this at the beginning to try to keep the clutter down
Specific calibration threads have long been a common approach to separation of calibration issues from other ownership information. However, we should seek to limit comment in this thread to calibration posts only, so that it stands as a quick reference for members to review what settings other members are running.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #10 of 273 Old 06-14-2011, 06:51 AM
ratherb1's Avatar
my settings for dark viewing with ambient light behind tv
source: verizon fios
Scene: Cinema
Picture Mode: Cinema 1
Backlight: 8
Picture: 88
Brightness: 45
Color: 53
Hue: 0
Sharpness: 44
Noise Reduction: auto
MPEG Noise Reduction: auto
Reality Creation: auto
Smooth Gradation: low
Motionflow: Clear plus
CineMotion: Auto 1
Black Corrector: med
Gamma: 0
Auto Light Limiter: med
Clear White: Off
Live Color: Off
White Balance: Default
Edge Enhancer: Off
Ambient Sensor: On
ratherb1 is offline
post #11 of 273 Old 06-20-2011, 12:45 PM
ejb2227's Avatar
Was there a post in the main owners thread with chad b's settings, or did I dream that up.
ejb2227 is offline
post #12 of 273 Old 06-20-2011, 12:48 PM - Thread Starter
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
No he did not provide settings.
bpmurr is offline
post #13 of 273 Old 06-23-2011, 02:49 PM
Trojita's Avatar
Quoted: 29 Post(s)
I'm hoping that the OP of the owners thread can put a link to this thread in it.
Trojita is offline
post #14 of 273 Old 06-23-2011, 11:37 PM
Tyrindor's Avatar
Quoted: 1317 Post(s)
Liked: 651
Updated settings here.
Tyrindor is offline
post #15 of 273 Old 06-23-2011, 11:50 PM
chs4000's Avatar
What would you recommend if I favor Clear and Auto 1?
chs4000 is offline
post #16 of 273 Old 06-24-2011, 07:23 PM
Bump
post #17 of 273 Old 06-25-2011, 05:44 AM
InsidiousFix's Avatar
Picture: Max
Brightness: 49
Color: 51
Hue: 0
Color Temp: Warm 2
Sharpness: 50
MPEG NR: Off
Dot NR: Off
Cinemotion: Auto 2
Advanced Settings:
Gamma: 0
Clear White: Off
Live Color: Off
Edge Enhancer - Off
Ambient Sensor: On
Pro Picture Setup
SBM: Off
Picture: Max
Brightness: 49
Color: 51
Hue: 0
Color Temp: Warm 2
Sharpness: Min
Advanced Settings:
Gamma: 0
Clear White: Off
Live Color: Off
Edge Enhancer - Off
Ambient Sensor: On
Pro Picture Setup
SBM: Off
Motionflow off?
InsidiousFix is offline
post #18 of 273 Old 06-25-2011, 04:20 PM
MUGEN's Avatar
Quoted: 40 Post(s)
Liked: 29
I've spent a lot of time removing the red tint that comes with Warm 2 for PC use and now I'm not getting a red or blue tint on anything white.
My settings for CATV, PC(Nvidia with default display settings), PS3 and PS4.
Scene: General for CATV, Graphics for PC, Game for PS3/PS4 and Cinema for Blu-ray
Picture Mode: Custom, Graphics, Game-original and Cinema 1
Backlight: 1
Picture: 97
Brightness: 50
Color: 48 (RGB/Y Pb/Cb Pr/Cr full source) 55(RGB/Y Pb/Cb Pr/Cr limited source)
Hue: 0
Color Temp: Warm 2
Sharpness: 55 for Video (65 for PC/PS3/PS4)
Noise Reduction: Auto (for CATV only, otherwise Off)
MPEG NR: Off
Dot NR: Off
Motionflow: Off
CineMotion: OFF (still needs testing/most use Auto 2)
Advanced Settings:
Gamma: +1
Clear White: High
Live Color: Off
White Balance: R-Gain -3 , rest 0
Edge Enhancer: Off
i/p Conversion Preference: Speed (Quality for for 480i/1080i)
Ambient Sensor: Off
All other sensors: Off
Pro Picture Setup
SBM: On
HDMI Dynamic range:Auto
Video source notes.
1. PC set to 1080p@60hz and RGB Full.
2. PS3 set to1080p, RGB FUll, Y Pb / Cb Pr / Cr Super-White ON and Deep Color/Colour Output Automatic.
3. PS4 set to 1080p RGB FUll and Y Pb/Cb Pr/Cr Full.
MUGEN is offline
post #19 of 273 Old 06-26-2011, 07:13 PM
Tyrindor's Avatar
Liked: 651
Turn the backlight down a notch or two if using Clear with my settings. Technically you could leave it at 8, but blooming will be slightly more if that sort of thing bothers you.
Tyrindor is offline
post #20 of 273 Old 06-27-2011, 01:26 AM
Trojita's Avatar
Quoted: 29 Post(s)
Do you guys use custom mostly in a very dark room?
Trojita is offline
post #21 of 273 Old 06-30-2011, 12:09 AM
Typhoon859's Avatar
Warm 2, Warm 2, Warm 2, Warm 2... Really? Well, attached here is an alternative for those that like their picture to look less.. (to avoid any negative connotation) orange - instead more realistic/generally pleasant.
The look is very similar to that of the settings I made for my LG 42LH90 (also posted in its dedicated thread) from what I can tell. I never saw them side by side nor did I intentionally try to replicate this. It's just, like when calibrating the LG, I was drawn to the same things to go for, except this time I had even more experience and less to deal with TBH. As I mentioned in the Owner's Thread of this TV, there isn't too extensive of settings to modify. I had to go with the default preset (with my relative settings at the time) which had the best color accuracy. The biggest problem is that there is no standard to which the settings are based on/how they're different. "Cinema 2" under the "Cinema" scene seemed to be the most accurate. Nothing too extensive I would probably end up additionally changing if I had more specific PQ options anyway... On "Cinema 2", by default the colors are pretty accurate as is.
Optimal SONY LED HDTV xxHX929 Picture Settings for General Content All-Inclusive.pdf 293.7548828125k . file
Typhoon859 is offline
post #22 of 273 Old 06-30-2011, 10:11 AM
Tyrindor's Avatar
Liked: 651
Warm 2 is the only setting you should be using on this set.. for all content. It provides the most accurate color, your settings do not. Any professional ISF calibrator will use Warm 2.
If you think Warm 2 looks "orange" then your eyes are trained/use to seeing things incorrectly, and it will take you a few days to adjust to Warm 2. Your settings are dramatically pushing blue gain, and you probably cannot see it because you are use to it. Your colors are also far too saturated, also a sign that you are coming from a previous TV that was calibrated for the masses, and not for accuracy. You also have some major black crush. Even on Warm 2, this set still pushed a little bit to much blue gain.
There is a reason why everyone is using Warm 2. It's not preference, you just need to switch it and give it a few days. After you adjust, and you go back to neutral, you will see just how bad it is. No offense but your settings are far from accurate. However, if you like them.. then hey, don't let me tell you how to watch your TV.
Tyrindor is offline
post #23 of 273 Old 06-30-2011, 10:24 AM
Typhoon859's Avatar
If you think Warm 2 looks "orange" then your eyes are trained/use to seeing things incorrectly, and it will take you a few days to adjust to Warm 2. Your settings are dramatically pushing blue gain, and you probably cannot see it because you are use to it. Your colors are also far too saturated, also a sign that you are coming from a previous TV that was calibrated for the masses, and not for accuracy. Even on Warm 2, this set still pushed a little bit to much blue gain.
Ok, well I disagree. I've made many posts in the past saying why. The LG I was talking about had settings I made on my own as well. There were many people that seemed to really like them. We can have this debate but don't mislead people reading through these settings that mine are "wrong", nevermind "bad". They are in fact neither. I've heard every perspective about this you can imagine already and I disagree. "Warm" is the most disgusting thing anyone can do to a TV, in my opinion. I won't tell you it's wrong, and maybe it's even "right" by the standard which you will tell me things are based on. I've given this approach so many chances in the past only to wildly prove to myself more and more that it's ridiculous, once again, in my opinion.
I can explain in detail but I've posted settings for multiple TV's before and I have gotten a decent following behind them. That wouldn't really be necessary to prove anything but it did happen and it must say something at the very least... I've grown tired explaining every time.
I know you're just trying to help but I don't need to be taught, trust me. If you want to stick to what's "right" over going for a "window effect" then that's fine. Just ignore my post then. If you're curious on the other hand, I'd be more than happy to explain. I just don't want to argue.
post #24 of 273 Old 06-30-2011, 01:48 PM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Please note there others out here in HT land that also appreciate white balance color temps other than a perfect 6500.
My only caveat would be, it's just as important to have a flat grayscale track at a higher color temp because the higher color temps may tend to be even less "flat" than the traditional 6500 reference color temp track. Higher color temps can be too blue/green and can benefit from some tweaking for a flat response thru the 0-100 IRE range range.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #25 of 273 Old 06-30-2011, 01:56 PM
Typhoon859's Avatar
I 100% agree with you. That is what I've worked on for a very long time on my LG LH90. This TV doesn't provide these options. I don't want to sacrifice everything else for minor adjustments in that department. With the limited settings on this TV, using meters and trying to get it technically perfectly calibrated I feel will just destroy any of it's appeal. I would've been more mad about this had the set not been able to pull it off without it, as it's pretty accurate in that department by default. Would you have any recommendations in approaching this if there actually is something I'm missing in regards to this? I'm completely open to suggestions whilst keeping things in relative terms.
post #26 of 273 Old 06-30-2011, 02:07 PM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Post calibration settings from a recent hx929 review:
After calibration
Backlight 7
Contrast 84
Brightness: 50
Colour: 50
Hue: 0
Sharpness: 0
Noise reduction Off
Black corrector Off
Gamma +1
Clear White Off
Live Colour Off
R Gain -3
G Gain -6
B Gain 0
R Bias -2
G Bias 0
B Bias +1
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #27 of 273 Old 06-30-2011, 05:44 PM
MUGEN's Avatar
Quoted: 40 Post(s)
Liked: 29
Coming from the 55" to the 46" I notice a big difference in color settings. On the 55" I had to set it to warm 2 to get rid of the blue whites but then I got the orange/yellow whites even with clear white: high and R gain -3. With the 46" now warm 1 with clear white: low looks perfect and close to my 46XBR3's warm 1. I also prefer this setting even though I can see warm 2 is better in color band images I have.
MUGEN is offline
post #28 of 273 Old 06-30-2011, 08:39 PM
Robonaut's Avatar
Is anyone else having issues setting the contrast (i.e. picture)?
I'm using the Advanced Contrast Test from the WOW disc and it says "the display's full dynamic range is utilized when the 'Ideal White' elements just become fully visible".
Based on the above, I would expect that I should be able increase Picture to the point where the "Ideal White" elements blend into the background and then decrease Picture down to where the "Ideal White" elements just become visible.
However, even with Picture cranked to MAX, I can't get the "Ideal White" elements to disappear into the background.
Is anyone else experiencing this? If so, what does it mean? The whites on screen certainly don't seem "dirty" or "dull" in any way.
Robonaut is offline
post #29 of 273 Old 06-30-2011, 09:11 PM
I have that too. I can only get the stars to disappear into the background at 4% and I'm using a ps3.
My friend has the dame set and is using a theta and can make them go away with the theta processor.
post #30 of 273 Old 07-01-2011, 08:42 AM
Tyrindor's Avatar
Liked: 651
If you can see all bars with Max contrast, and they aren't tinted pinkish then you can set it to max. If they are tinted pink, then lower it until they aren't.
With this set, Max contrast (or picture) is possible without hurting the overall picture. However, it is quite bright.
So in short - set picture to what you want it to be. The contrast on this set is so good it comes down to preference.
After calibration
Backlight 7
Contrast 84
Brightness: 50
Colour: 50
Hue: 0
Sharpness: 0
Noise reduction Off
Black corrector Off
Gamma +1
Clear White Off
Live Colour Off
R Gain -3
G Gain -6
B Gain 0
R Bias -2
G Bias 0
B Bias +1
Any idea if they had Ambient Sensor on or off?
Tyrindor is offline
Reply LCD Flat Panel Displays
Sony Bravia Xbr65hx929 65 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wifi Black , Sony Bravia Xbr55hx929 55 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wi Fi Black , Sony Bravia Xbr46hx929 46 Inch 3d Local Dimming Led Hdtv
