NANO LG LV9500 Official Owner's thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 08-29-2011, 09:54 PM
videkid's Avatar
Finally, 100% 3D support, The EDID reset on the AC3 followed by an instop worked. It might not show up right away. It seems once your set tell you that the software update #2 or #3 is available you have 100% 3D playback and the best deal in Home Theater for 2011.
Thank you lg, Life in my 3D world is good and thank you HSN for putting out the best deal in HomeTheater of 2011 and making it affordable to most by providing 6 no interest payments and free delivery.
Thank you Nony and all the others who helped us on the LV9500 achieve 100 % full 3D playback.
I am using a Samsung BD-D5500C 3D player and am able to watch 3D, the
PS3 or forced playback players are no longer needed.
videkid is offline
Old 08-29-2011, 10:10 PM
JKTS's Avatar
Originally Posted by p5browne View Post
It appears the LG Internet connection searches for it's own connection?
Should we be going into the FW and disabling the Wireless to prevent the FW updating? Of course, all the apps go with it!
.....what makes you say such a thing?
JKTS is offline
Old 08-29-2011, 11:58 PM
KONICA TECH's Avatar
Quoted: 25 Post(s)
Liked: 54
Originally Posted by VoidbioV View Post
Go to MENU-SUPPORT-SOFTWARE UPDATE-turn it off
That's odd though because mine is telling me that I have the latest update. See above posts
Thanks for the tip, I missed that before
KONICA TECH is offline
Old 08-30-2011, 12:47 AM
jvolkman's Avatar
You're all geniuses. I picked up the 3D glasses at Fry's tonight and went through the steps and all I can say is wow! My Panasonic DMP-BDT210 3D player connected through my Onkyo TX-NR809 receiver has no problems with 3D after enabling the options, doing the In-Stop and running the EDID D/L. The 3D performance of this TV far surpasses that of the Vizio XVT3d474SV I had for a few weeks. I may actually be a 3D believer now!
Now my only issues with this TV are:
* Lip sync (still tweaking)
* The bright spots around the edges when dimming is off or nearby zones are lit
* Specs of dust under the glass -- some large enough to obscure pixels at close distance.
All-in-all, a great value at $1499
jvolkman is offline
Old 08-30-2011, 04:11 AM
nony's Avatar
Quoted: 13 Post(s)
Then you probably have the latest production build for your locale. (Whereas, the Vegas boys are being offered the latest engineering builds, which you probably don't want.)
-nony
nony is offline
Old 08-30-2011, 04:28 AM
nony's Avatar
Quoted: 13 Post(s)
This poses both a privacy and theft of service problem, if the set is configured out-of-the-box to go out and connect to your neighbor's (or any arbitrary) unsecured router without your knowledge or consent.
-nony
nony is offline
Old 08-30-2011, 08:21 AM
wbob's Avatar
I have been following the 3D trials/tribulations and joys and I want to thank all of you for "pioneering" this endeavor. Manipulating the service menus in a new $1,500.00 TV shows that you have more guts that I do! Your efforts are truly appreciated! I have my service remote in hand and the glasses should arrive in a day or two. Although it is not directly related to this thread, some of you may be more knowledgeable than myself regarding my cabling dilemma. When my house was being built, I ran 7.1 speaker cables and an HDMI cable inside the walls (the TV is above a fireplace). I spent too much time and effort to achieve a"clean" setup and do not want visible cables running up and down the walls. For the TV I used "Rapidshare" cables (mfg #: 40859 - 15' runner) terminated with HDMI "Flying Leads." As I installed this system in 2008, my best guess is that they are HDMI 1.1.
Last year I purchased a left-over and heavily discounted Denon 4310(HDMI 1.3) receiver because I was made to believe that the cables must be 1.4 in order to be 3D compliant and 2D was the best I could do. The people that answered the phone at "Rapidshare" just told me that the cables are not certified 1.4 compliant. I will be buying a 3D Blu-ray player shortly. Before I go out and also purchase a 1.4 receiver, I am trying to verify their answer regarding these cables as there have been conflicting posts(not in this thread). My question: Is anyone out there getting 3D using older HDMI cables in a pass through configuration from their receiver to the TV? If yes, are you giving anything up?
I love the 55lv9500 as my main TV (family room) for broadcast, streaming, and movies. That's what I bought it for. However, I do have a smaller room that is wired for 5.1 sound and I can use the 9500 to replace the Panasonic plasma that is there now. Fortunately, the TV is on a stand and the HDMI cable is not buried in a wall. One way or another, I will be enabling the 3D!!!!
wbob is offline
Old 08-30-2011, 10:37 AM
Quoted: 25 Post(s)
Liked: 54
-nony
This did not happen out-of the box, it happened after I did the wired up-date to 4.00.18 and disconnected the wired connection, I left on the update option. It is off now.
Old 08-30-2011, 11:44 AM
orangedawg's Avatar
I'm curious about the remote that comes with this. In the picture on HSN of the remote, it shows the 3d button. I note that some (maybe all?) in this thread have mentioned it comes with a different remote. Has anyone who received this set have the remote with the 3D button? Just curious.
orangedawg is offline
Old 08-30-2011, 01:14 PM
p5browne's Avatar
Quoted: 2793 Post(s)
Liked: 2110
http://www.avsforum.com/avs-vb/showt...php?p=20829651 #278
You can purchase the remote from www.NewRemoteControl.com
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
Old 08-30-2011, 01:29 PM
nony's Avatar
Quoted: 13 Post(s)
Turning off updates has no bearing on your wifi connectivity. You really want to check your network status:
1. with wired connected
2. with wired disconnected
-nony
nony is offline
Old 08-30-2011, 02:22 PM
cashxx's Avatar
Now that 3D seems to be figured out can you guys post a thread with the complete instructions so others can find the instructions in one spot instead of having to go back through the pages to figure it out.?
Also vidkid and others so have we found out that all LV9500 are 3D capable or just the Y models?
cashxx is offline
Old 08-30-2011, 02:54 PM
jvolkman's Avatar
I don't think we need a new thread. arkasi55 posted most of the steps but left out the part about EDID D/L (not sure if it was known at the point of his post): http://www.avsforum.com/avs-vb/showp...&postcount=473
I have a W panel and 3D works fine.
jvolkman is offline
Old 08-30-2011, 03:39 PM
arkasi55's Avatar
You may want to ask them whether the cables are HDMI high speed. Cables themselves do not carry a certified version, it's the devices that have to meet that criteria based on the software functions they support. I used a 5 year old Belkin HDMI cable to do some of my testing as my cabling is also in wall, but my Marantz amp is HDMI 1.3. Worked no problems and after re-downloading the EDID data, the the BR player was able to correctly detect 3D capability in the TV using that cable.
arkasi55 is offline
Old 08-30-2011, 03:47 PM
arkasi55's Avatar
Updated to include the EDID download instructions Thanks for the reminder!
arkasi55 is offline
Old 08-30-2011, 03:59 PM
jvolkman's Avatar
Cool. Dianabol5mg, perhaps you could link to this post from the first post?
jvolkman is offline
Old 08-30-2011, 04:41 PM
diamondgirl0017's Avatar
Do we need the AUS model 3D glasses specifically or will the AG-250 3D glasses from Amazon work as well?
diamondgirl0017 is offline
Old 08-30-2011, 05:25 PM
p5browne's Avatar
Liked: 2110
Almost Sold Out
p5browne is offline
Old 08-30-2011, 05:30 PM - Thread Starter
Dianabol5mg's Avatar
Quoted: 305 Post(s)
Liked: 233
DONE!!!!!
I really hope everyone enjoys this TV. Mine will be picked up tomorrow. I do need a favor from some owners......I was screwing around with my little 32LD550 this morning when I got home from work. I put in Halloween just to check some cadence issues that this tv also has. The cadence issues are very similar to the LV9500 when Trumotion is engaged. Cadence is terrible when off and terribly smooth and artifact ridden when engaged. I started screwing around and I want someone to use these settings on a movie that has extensive pans and camera movement(not editing).
Engage Real Cinema and turn blur to 10 and judder to 0 and tell me what happens. I am now getting the proper judder during pans on my LD550. Please let me know if this works on LV9500...there should be no artifacting whatsoever, if its working. If you are an owner of this fine film please play the first ten minutes. And if your a novice cinematographer, you will learn what perfect panning is. Thanks all
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
Sony BDP-S5200 Multi-Region
Dianabol5mg is online now
Old 08-30-2011, 05:32 PM - Thread Starter
Quoted: 305 Post(s)
Liked: 233
Almost Sold Out
Again.......they just went back up today.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
Old 08-30-2011, 05:57 PM
Quoted: 25 Post(s)
Liked: 54
All I know is the S250/AUS glasses work, I have not seen any other S250 glasses to try for you, what is the complete part number so we can check?
Old 08-30-2011, 06:00 PM
Quoted: 25 Post(s)
Liked: 54
-nony
Thanks Nony, I will check that and post back.
Old 08-30-2011, 06:04 PM
wbob's Avatar
Thank you for your reply!!! It did occur to me that my 1.3 receiver might work. I browsed the AVS "Denon 4310" posts but didn't find anything. Only people that weren't interested in it because the receiver wasn't 1.4. There is nothing to lose - I'll give it a try!
wbob is offline
Old 08-30-2011, 06:57 PM
cubsoxbullbears's Avatar
Well I guess I must be a complete idiot. I tried updating my Logitech Harmony One remote, and I can't even figure that piece out. I did the ir codes and everything, but everything seems the same. Oh well congrats to all of you that are alot more technical than me. It's good to hear that many of you, are enjoying the 3d on this TV. I still think the 2d picture is great on this set.
Anyhow a big Thanks to everyone for all the great information that is posted here, I know you spend alot of time to try and help everyone out, and I greatly appreciate it.
cubsoxbullbears is offline
Old 08-30-2011, 09:04 PM
it's the same model number with the letters AG instead of AUS. You can see them on Amazon. Konica do you know where I can order the AUS glasses?
Old 08-30-2011, 10:11 PM
videkid's Avatar
Frys Electronics web page
videkid is offline
Old 08-30-2011, 10:12 PM
videkid's Avatar
The Logitech remotes are difficult for some to program, this is why I recommend the service remote.
videkid is offline
Old 08-30-2011, 10:14 PM
jvolkman's Avatar
They're even cheaper at overstock.com
jvolkman is offline
Old 08-30-2011, 11:30 PM
Quoted: 25 Post(s)
Liked: 54
I got one pair at Best Buy and one at Fry's
Both pricematched the Amazon price I had.
Both are model AG-S250/AUS
Both bought in the store.
Old 08-31-2011, 12:35 AM
videkid's Avatar
I took the chance and downloaded the software update # 04.01.29 and all is still well, 3D is working. I believe the blacks might even be a little darker but who know it might be in my head. The early software updates are usually important so I took the gamble and am still good
videkid is offline
Lg , 3d Hdtv , Displays , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Sharp
