NANO LG LV9500 Official Owner's thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 1756 Old 08-02-2011, 12:32 AM
arkasi55's Avatar
OK, so I went to my local store today and picked up a pair of AG-S250 active glasses, which are designed for the 2011 plasma range, and according to Crutchfield and Amazon sites, the original LW9500.
Charged them up, got the green light. But unfortunately they don't seem to sync to the screen. I tried holding the button for 8 secs until the led flashes green and powers off, then power on which should re-sync, but i get no shuttering from the glasses.
Am i doing something wrong? Any ideas?
In any case, at least it will prove one way or another whether the 3D can be enabled.
arkasi55 is offline
post #62 of 1756 Old 08-02-2011, 12:46 AM
jvolkman's Avatar
Any idea what medium the TV is supposed to use to sync with the glasses? If it's infrared, you might be able to use an electronic view finder (from a digital camera or something) to look for an IR transmitter on the TV.
jvolkman is offline
post #63 of 1756 Old 08-02-2011, 12:55 AM - Thread Starter
Dianabol5mg's Avatar
Quoted: 374 Post(s)
Liked: 294
That blows, i'm thinking there's no emitter. It's sort of like the Sony HX909. You have this really nice tv and 3D, but no emitter, purchase separately. But in this case I don't think LG makes them.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
Sony BDP-S5200 Multi-Region
Dianabol5mg is offline
post #64 of 1756 Old 08-02-2011, 01:09 AM
arkasi55's Avatar
Judgng by this table http://lgknowledgebase.com/kb/index....y&EntryID=6488 I'm guessing it's RF like the other 2011 active screens.
I googled the ag-s250 part and found references from Amazon and Crutchfield that the glasses were supported by the LW9500 (original active spec), so i'm pretty sure they're correct. A good look at the screen only shows the gap for the remote ir sensor.
So unless there's another option in the EZ Adjust or InStart menus that i'm yet to enable, i'm thinking Dianabol5mg is right - no rf emitter
arkasi55 is offline
post #65 of 1756 Old 08-02-2011, 01:10 AM
arkasi55's Avatar
Interesting to note too, it looks like LG have changed/removed the 3D menu in the newer firmware just released. When I first tested this, I had the 3D as a menu option in Quick Menu (a small pop up menu). Now, to enable 3D I have to go to Setup and enable it via the display menu
arkasi55 is offline
post #66 of 1756 Old 08-02-2011, 02:31 AM
arkasi55's Avatar
OK, scratch that. Had a special moment there, the menu only comes up if using the magic motion remote. I use a pronto for normal use, so didn't see it.
arkasi55 is offline
post #67 of 1756 Old 08-02-2011, 03:52 AM - Thread Starter
Quoted: 374 Post(s)
Liked: 294
Arkasi, go to the LG2011 lineup thread and hit the gizmodo link Thorin78 has up. Its the same tv, but LG is saying its passive and not active. Its a different model number, but it is the same television.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
post #68 of 1756 Old 08-02-2011, 04:15 AM
p5browne's Avatar
Quoted: 3104 Post(s)
Liked: 2418
The 55LV9500 isn't listed. When you enter the model # in the search Window, nothing comes up. My friend and I both have passive glasses and will checkout once the sets arrive. I'm going to hold off on the FW upgrade, in case LG has decided to kill the 3D option. This would mean everyone will get the cheaper 55LV9500, activate the 3D and bypass the more expensive 55LW9800. Of course, it may enable, but actually not have any 3D at all available. If you've got a set of passive glasses we'll know sooner.
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is offline
post #69 of 1756 Old 08-02-2011, 04:16 AM
arkasi55's Avatar
Yeah, the LW980S/T LW9800 is the updated panel incorporating the FPR panel to provide the passive Cinema3D. I've spent some time with the LW6500 passive panel, and it's very easy to see the difference (back lines separating the 2 images) that don't exist on my screen.
I'm sure nony will have the FCC data for the 2 panels?
arkasi55 is offline
post #70 of 1756 Old 08-02-2011, 06:49 AM
jvolkman's Avatar
Is it worth noting that the manual lists the 55LW9800 and the 55LV9500 as the exact same weight? It seems that if the 9800 has an extra filter the weights would be different. Of course the manual could just be imprecise.
jvolkman is offline
post #71 of 1756 Old 08-02-2011, 06:57 AM
jvolkman's Avatar
Anyone else get this email from HSN?
We're sorry, due to a product shortage, we've been unable to ship your order for 1 LG 55" 480Hz Full-Array LED Smart HDTV with Built-In Wi-Fi.
We hope to have the item in stock within a few weeks and will ship it to you as soon as possible. We will continue to work to fulfill your order for 30 days.
If we are unable to get this item back in stock by Sep 01, 2011, we will cancel the order for you and send you an email notification. If you'd like to cancel the order now, please contact Customer Service at 1.800.933.2887 (8 am-1 am ET).
Your credit card will be charged when the order ships.
Thank you for your patience and understanding. We apologize for the inconvenience.
Hopefully this is just a case of an automatic email that is sent when an order can't be shipped immediately.
jvolkman is offline
post #72 of 1756 Old 08-02-2011, 07:38 AM
cubsoxbullbears's Avatar
I didn't receive one, I ordered mine online, when they said about 4800 were sold. I believe they sold out at 5500.
cubsoxbullbears is offline
post #73 of 1756 Old 08-02-2011, 07:41 AM
hughh's Avatar
Quoted: 97 Post(s)
Liked: 56
LG Korea just announced that it will start shipping two new HDTVs with the 47-inch 47LW9800 and 55-inch 55LW9800.
http://www.avsforum.com/avs-vb/showthread.php?t=1349775
hughh is offline
post #74 of 1756 Old 08-02-2011, 08:26 AM
jvolkman's Avatar
I don't recall what the count was when I ordered, but it was definitely hours before they sold out.
jvolkman is offline
post #75 of 1756 Old 08-02-2011, 09:31 AM
Schlar01's Avatar
Nope, but there were 'only' about 2500 sold when I ordered mine.
Schlar01 is offline
post #76 of 1756 Old 08-02-2011, 11:02 AM
Tim Hess's Avatar
I've not gotten the mail either, I ordered when 3500 or so had been sold.
Tim Hess is offline
post #77 of 1756 Old 08-02-2011, 11:08 AM
jvolkman's Avatar
Interesting. A guy over at slickdeals (http://slickdeals.net/forums/showthr...4#post41451544) said he also got the email and he ordered at around 2700 units shipped. Another guy there said he got an email that said his order has shipped, but the estimated delivery date is 8/22.
Some confusion at HSN..
jvolkman is offline
post #78 of 1756 Old 08-02-2011, 11:36 AM - Thread Starter
Quoted: 374 Post(s)
Liked: 294
Man that sucks, I really hope we all get our tv's. I mean jeeze, why would they try to sell that many units if they don't have them? Thats a crappy thing to do, if you know you only have a certain amount of units to sell. Mine was ordered as soon as I had seen it Saturday morning. I was scouring the shopping channels' websites hoping for something, cause I had just sold my 50" plasma. So every day I was on the prowl looking for an awesome tv with easy pays. The LHX has a 3 payment deal over at QVC(it was at 6 for 24hrs last week), but i couldn't pull trigger. Something was telling me to wait. This deal came up saturday morning and I promised myself I wasn't going to lose out, like I did on the KRP500 that was on shopnbc 2 years ago. I simply didn't buy it because of my kids. Knowing what would've happened to it, ate me up. And I didn't want to feel the pain of it getting whacked and written on, so I passed. I told my wife i'm not passing on a good opportunity this time. Now, i'm hoping my dilligency paid off and I don't get any bad news. Good luck to everyone.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
post #79 of 1756 Old 08-02-2011, 11:38 AM
Well I hope everyone that ordered the TV ends up getting one.
I wonder if these are even built yet, or is that the reason for the 08/22 date ?
Still no email, and I just checked HSN and mine doesn't show shipped. I did notice I have a pending charge from them from my CC company, so that's good news.
post #80 of 1756 Old 08-02-2011, 12:30 PM
p5browne's Avatar
Liked: 2418
The Service Manual shows only 2D for Max Luminance for the 55LV9500
Next page: 3D Crosstalk - 1.8% - (V6) 55LW9500-NAUA, 55LV9500-UA and 55LW9600-UA.
Nothing mentioned about THX being hidden, and having to be activated from the Service Remote. Nothing mentioned in the User Manual either. I guess it's a wait and see deal!
Put in a dealer request to LG about some things missing in the Service Manual, about the Local Dimming and THX.
p5browne is offline
post #81 of 1756 Old 08-02-2011, 02:38 PM
jvolkman's Avatar
HSN just called and said the email (or automated phone call, whichever one may have received) that said the TV was out of stock was an error and that the order would be processed within 48 hours.
jvolkman is offline
post #82 of 1756 Old 08-02-2011, 04:33 PM
jvolkman's Avatar
HSN is no longer listing this TV as sold out on their site. They now list it for $1599 (was $1499 on Saturday/Sunday). Might be a mistake considering all the confusion going on around stock of this item.
http://www.hsn.com/cnt/prod/default.aspx?pfid=139813
jvolkman is offline
post #83 of 1756 Old 08-02-2011, 04:47 PM
6athome's Avatar
Quoted: 521 Post(s)
Liked: 157
I just ordered the lv9500 and my wife is going to kill me.
I have a 40in samsung 85 model with local diming on sale it was grand and when I saw the lv 9500 with nano led and that means local dimming.well i going to die what the heck.
6athome is offline
post #84 of 1756 Old 08-02-2011, 04:49 PM
Now there calling it their event price, so it seems they only gave us an extra 5% for the so called today's special value.
Well as long as I'm happy with the TV, I won't complain.
post #85 of 1756 Old 08-02-2011, 06:06 PM
Turrican4D's Avatar
Quoted: 739 Post(s)
Liked: 433
When I was a kid, I would never got the idea to throw things in my fathers TV.
Maybe you should lock up the living room?
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #86 of 1756 Old 08-02-2011, 06:45 PM
Tim Hess's Avatar
Status
07/31/2011
xxxxxxxxx
Not yet shipped
Estimated Delivery
08/22/2011
Nothing in the way of a negative e-mail yet!
With the 'new' price up it doesn't really seem that much of a bargain does it? Still have to wait a month-ish. My TVs dying the White Dot syndrom so the less I use it the better (one dot and trying to sell it).
Tim Hess is offline
post #87 of 1756 Old 08-02-2011, 06:52 PM
ETERNIA FOREVER's Avatar
I was fortunate that HSN must have changed where they charge tax. I was able to get 6 payments for $250 a month. I had to tell the wife I will lower my alcohol consumption for 6 months to compensate for the monthly payment.
lol att what you told your wife and yeah i am talking bout the deal they have goin now, and they this time are only offering four payment this go around and when i put it in the computer just too see iff they were charging tax in my area they sure were.. i am not sure but i believe they are based in florida the state in which i am living
ETERNIA FOREVER is offline
post #88 of 1756 Old 08-03-2011, 06:23 AM
6athome's Avatar
Quoted: 521 Post(s)
Liked: 157
did anyone get the lv 9500 from hsn yet? what is it and is it local dimming?
6athome is offline
post #89 of 1756 Old 08-03-2011, 06:28 AM
slothy's Avatar
ordered mine - should be a nice upgrade from my 46" 60hz
Order Date: Aug 02, 2011
Estimated Delivery Date: Aug 23, 2011*
slothy is offline
post #90 of 1756 Old 08-03-2011, 06:35 AM
jvolkman's Avatar
Estimated arrival dates aren't until around August 22nd. It is local dimming.
jvolkman is offline
Reply LCD Flat Panel Displays
Lg , 3d Hdtv , Displays , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Sharp
