Annoying judder on Samsung LCD TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-12-2011, 07:40 AM - Thread Starter
Bloopie's Avatar
Hey,
I have a Toshiba Regza 32" LCD TV that I bought a few years ago. It is connected to my PC and the screen resolution is set to 1980x1050, 25 Hertz, Interlaced.
No matter the video I try to play, the picture quality is excellent and the movement is smooth, without any noticeable judder whatsoever.
A few days ago, I bought a Samsung LA37C530 37" LCD TV with a built-in media player for my living room. I immediately noticed that although the picture quality is fine, playback of any sort of video, avis or mkvs, just isn't smooth.
I've tried tweaking the settings and also tried connecting my PC (the one I use for my Toshiba LCD TV) and trying different screen resolutions, including the 1920x1080, 25 Hertz, Interlaced that works so well on the other TV, but I just can't achieve the same non-judder feel I get on my old LCD TV.
Any speculations as to why this is and what I can try to do?
Thanks in advance!
Bloopie is offline
post #2 of 7 Old 08-12-2011, 07:47 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
The C530 is a 60hz TV rather than 120hz, so it doesn't have the built-in AMP (Automated Motion Processing) to smooth the judder.
As you have witnessed, the major use for a motion processing feature is when you are playing movies and other "non-TV" programs. AMP is also useful for sports and can be turned off or adjusted as needed. However, you need to have a Samsung Series 6 TV or higher to have this feature included.
Sorry.
BoilerJim is offline
post #3 of 7 Old 08-12-2011, 07:54 AM - Thread Starter
Bloopie's Avatar
Sorry.
The Toshiba LCD TV also isn't 120hz, though...
Bloopie is offline
post #4 of 7 Old 08-12-2011, 08:05 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Guess I don't have a better answer then. Sorry.
post #5 of 7 Old 08-12-2011, 07:51 PM - Thread Starter
Bloopie's Avatar
Anyone?
Bloopie is offline
post #6 of 7 Old 08-12-2011, 08:08 PM
Emerick99's Avatar
Is there the same judder during television shows or playback of DVDs?
Emerick99 is offline
post #7 of 7 Old 08-14-2011, 07:21 AM - Thread Starter
Bloopie's Avatar
I don't have a DVD player to check that with... any other ideas?
Bloopie is offline
Reply LCD Flat Panel Displays
