Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 231 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
Old 02-05-2012, 10:31 AM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
Originally Posted by Nuke76 View Post
Best pun since cyanara. Keep 'em coming
What? Are you trying to start a new branch of American Cyan Language?
Now I must leave and give you a cyan wave.
taichi4 is offline
Old 02-05-2012, 04:36 PM
Nuke76's Avatar
Sigh an a scion cyans on.
And now, the Super Bowl is on the best tv ever......
Nuke76 is offline
Old 02-05-2012, 04:43 PM
hhtatum's Avatar
Are the Patriots wearing purples jerseys?
Just kidding. Looks unbelievable.
hhtatum is offline
Old 02-05-2012, 05:14 PM
taichi4's Avatar
Quoted: 322 Post(s)
Liked: 153
Why? Did you see a New Jersey Cyan on the way to the game?
taichi4 is offline
Old 02-05-2012, 05:41 PM
tory40's Avatar
Hey can one of you guys check if you have this problem that effects the Sharp LE835u? The quickest way to check is to load up a menu and look at a horizontal line. If you see little "teeth", then you've got a pretty major image quality problem if you sit close to your TV, if not, its more of a minor thing, but i'd be pissed myself. If you do have it, I believe i have evidence that proves it can be solved via an update.
"We did find that the subpixel structure that Sharp uses on its LCD panels (or the way in which the subpixels are addressed) looked unusual at first. Almost every LCD HDTV we review has its red, green and blue sub-pixels arranged in vertical stripes on the panel. Sharp’s LCD panels appear to use a triangular arrangement (or something similar to it), which results in straight lines (and fine details) appearing a little bit zig-zagged if a very observant user sits very close to the screen. This does affect how fine details are perceived, and for this reason, we don’t recommend that anyone tries to use a Sharp LCD TV as a large computer monitor."
Source
If you do have it you should know that it completely obliterated the small details in my desktop background photos on an LE835u. This was tested comparing it to a Sony of the same size. It was also tested sitting a meter away, so its not as bad sitting farther way, but it will be worth contacting Sharp for to get a fix going for it as its not trivial in the slightest (if Elites have it of course).
tory40 is offline
Old 02-05-2012, 06:05 PM
Nuke76's Avatar
"We did find that the subpixel structure that Sharp uses on its LCD panels (or the way in which the subpixels are addressed) looked unusual at first. Almost every LCD HDTV we review has its red, green and blue sub-pixels arranged in vertical stripes on the panel. Sharp's LCD panels appear to use a triangular arrangement (or something similar to it), which results in straight lines (and fine details) appearing a little bit zig-zagged if a very observant user sits very close to the screen. This does affect how fine details are perceived, and for this reason, we don't recommend that anyone tries to use a Sharp LCD TV as a large computer monitor."
Source
I can't imagine trying to watch a tv from 3 feet. The closest I can comfortably watch the tv is 8 to 9 feet (and that's in 3D mode). I've played around with some of the AVIA disk test patterns and haven't seen any teeth on horizontal lines at normal viewing distances. I'm sure that if I get close enough the orbital electrons would become distracting.
Nuke76 is offline
Old 02-05-2012, 07:46 PM
AnotherDude's Avatar
Quoted: 25 Post(s)
Liked: 36
Actually if you turn on Precision Color Plus it will make some pixel-based resolution patterns look weird, but that's becuse it's doing its thing. OTOH, it's meant to improve diagonal resolution, so normal viewing might be improved, or not - you be the judge ...
Sharp Elite PRO70X5FD
Lumagen Radiance 2143
OPPO BDP-105D
AnotherDude is online now
Old 02-05-2012, 09:03 PM
Ken Ross's Avatar
Quoted: 5705 Post(s)
Liked: 6071
Oh c'mon, don't we need a new controversy? Isn't that what this all about?
The gyrations we go through to find issues, any issues.
Ken Ross is offline
Old 02-05-2012, 09:06 PM
gary cornell's Avatar
Ken, isn't it obvious? we're waiting for next Elite
gary cornell is offline
Old 02-05-2012, 10:28 PM
electronleaker's Avatar
Guys, I'm not sure I can hold off for a new set much longer. The elite2 is just not in my time table. I've been running on a sharp 46d62u for going on 6 years now and my tax return is burning a hole in my wallet.
Has anyone bought the 60 or 70 from either robert or chris, had it shipped to their home (out of state, I live in AR), needed to have sharp replace/repair it due to clouding or any other issues and ran into any warranty problems? I'm a little worried that I may get a bunk set, either chris or robert won't/can't replace it and sharp won't honor the warranty cause I had it shipped out of state. This is my only hang up on ordering a new 60.
Any insight would be GREATLY appreciated, thank you kindly.
Aaron
electronleaker is offline
Old 02-06-2012, 12:37 AM
specuvestor's Avatar
Source
Major image quality problem compared with 4:4:4 vs 4:2:0??
specuvestor is offline
Old 02-06-2012, 05:33 AM
Ken Ross's Avatar
Liked: 6071
And if there is a next one, you'll be looking for the one after that within a week.
Ken Ross is offline
Old 02-06-2012, 06:03 AM
I want a Virtual Reality TV.
http://we-make-money-not-art.com/arc...-to-realiz.php
Old 02-06-2012, 08:04 AM
AZREOSpecialist's Avatar
I haven't looked at the RGB+Y pattern, but I can tell you that my 70" Elite resolves more detail than I've ever known was possible in my Dish Network HD feed. I have absolutely no concern about resolution on the Elite - it is the best I have ever seen on any TV. Period.
Source
AZREOSpecialist is offline
Old 02-06-2012, 09:11 AM
Nibis's Avatar
Man, I really want one of these TV's, but the boss says no, LOL. Hopefully the price will start to come down. I'd like to get the 60". I have a plasma right now, tried other LCD's but I am sensitive to judder. Has anyone noticed judder on these TV's?
When I go to BB at look at the TV, they always have Lord Of The Rings playing, I'd like to see something else.
Jim
Nibis is offline
Old 02-06-2012, 09:21 AM
akopperl's Avatar
Quoted: 34 Post(s)
I am considering the 70" Elite. I currently own a 60" Kuro (9G) and although I still think it is a phenomenal display - the larger size and 3D make the Elite an attractive option.
My only concerns are the pulsing and cyan issues I have read about. Are the pulsing issues limited to certain displays - in other words a defect or is it inherent in all of the displays? Is it fixable?
I believe that I have read that they plan on releasing a firmware fix for the Cyan issue. Is there a projected release date for the Cyan fix? Sometimes companies say they will fix issues with new firmware and it just never happens.
My only other issue is how do I sell a Kuro without the original box? I have no idea how to ship it safely to a buyer.
akopperl is offline
Old 02-06-2012, 10:09 AM
siucity's Avatar
Aaron
I didn't buy from either, and I don't have any issues with my 70", but I don't see how the fact that you're going to have it shipped would cause warranty issues? I think you're safe there.
siucity is offline
Old 02-06-2012, 10:33 AM
tory40's Avatar
I would say so. I watched a Blu-ray movie on the LE835 and some SD content and i definitely noticed it. This problem would mean you have little hacksaw sized teeth running along every singe horizontal line or line formed by any color difference (which is all a line is obviously).
If you look on your TV, horizontal lines should be flat while looking from about 2 feet, it will be obvious if there are teeth.
Here is a photo I took at a store the other day of the LE835u using a phone.
Attachment 236390
I had the LE835u hooked up to my computer running Nvidia's 3D software. When i would enable 3D, and set the desktop resolution to 1080p/24 the problem went away and all the detail returned to my photos. Enabling 3D btw doesn't make the desktop 3D, it just gets the computer ready to display some 3D content. So the problem isn't the pixel structure itself, its the way it is processed.
Thus, if you have it, it should be able to be solved by an update.
tory40 is offline
Old 02-06-2012, 01:07 PM
jeffs2's Avatar
Unfortunately I don't think we have a firm answer on either of those questions. Given the number of people that have had their sets replaced and had the problem persist, I'd say its inherent in all sets. Given that a flickering set was shipped to another person that didn't see the flickering, and the number of people that never see it, I'd say there are external triggers amplifying/triggering the problem.
They only recently claimed to be able to replicate the flickering problem, so I think we are a ways from a fix. My gut feel is that they can fix the problem however.
Sounds like they are having issues creating the cyan patch.
jeffs2 is offline
Old 02-06-2012, 02:00 PM
Quoted: 25 Post(s)
Liked: 36
Aaron
I got mine from Chris and have had nothing but great service from him. I haven't made any warranty claims on my Elite, so can't attest to what Sharp will do, other than people who have made warranty claims seem to have had very good response based on their postings.
I also got an LG 55LE8500 from Chris for which I did make a warranty panel replacement due to banding, and LG was very responsive, so I don't think you could go wrong with either Chris or Robert.
OPPO BDP-105D
Old 02-06-2012, 02:24 PM
trcnet's Avatar
Hi akopperi,
I wouldn't worry about those issues. Even with the issues believe me this set is worth it. If they fix them great, if they don't I seriously doubt you'll be disappointed. Best of luck trying to sell your Kuro ... cause' your gonna' need it with this thing around
enjoy,
Tom
trcnet is offline
Old 02-06-2012, 03:57 PM
rogo's Avatar
Quoted: 1595 Post(s)
Liked: 1791
Try to arrange a local sale first. Then you wouldn't need a box.
If you need to ship it, there are specialty shippers that can arrange for such a thing. It won't be cheap to ship either way, adding an extra $100-200 for packaging ought not kill the deal.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
Old 02-06-2012, 04:31 PM
Originally Posted by trcnet View Post
Hi akopperi,
enjoy,
Tom
You should have no problem selling it if it's in excellent condition and low mileage. I purchased the 60" recently from a dealer with only 4,600 hours. My 50" Kuro, also from Sept 2007 has 12,500 hrs., still a great display.
Old 02-06-2012, 05:11 PM
trcnet's Avatar
Hello Gary,
No offence meant. Only in jest.
enjoy,
Tom
trcnet is offline
Old 02-06-2012, 05:18 PM
Hello Gary,
enjoy,
Tom
None taken, just remember, Kuro means black
Old 02-06-2012, 09:03 PM
Quoted: 25 Post(s)
Liked: 36
^^^ Hai!
OPPO BDP-105D
Old 02-07-2012, 10:35 AM
Sharp claims they are working on the issue and corresponding firmware update. The issue is inherent in all Elite displays currently, to varying degrees.
Old 02-07-2012, 11:06 AM
GeneWildersHair's Avatar
Quoted: 426 Post(s)
Liked: 376
I also believe this to be true, however I also would like to add that I think that there are some folks who just don't notice the issue at all, and some to a lesser degree than others. I've seen this issue in both magnolia sets near me, and mine also has it. I also don't see them to be any more or less noticeable in the 3, I've compared. at one Magnolia location, the employee definitely saw it right away, but only after I had pointed it out, using the Dark Knight blu ray I brought with me, and at the other store, the employee said he could not see it, even tho it was clearly there.
GeneWildersHair is offline
Old 02-07-2012, 05:23 PM
ad10ad's Avatar
Forgive me if this was posted earlier but what scene(s) from the Dark Knight trigger the pulsing issue for you?
ad10ad is offline
Old 02-07-2012, 06:52 PM
Gord S's Avatar
I'm curious as to what scene as well. I'm planning to audition the TV again tomorrow and would like to see this flicker in person.
Gord S is offline
Sharp Elite Black 70inch Pro 70x5fd Flat Panel 3d Led Hdtv , Sharp Elite Pro 60x5fd 3d Led Hdtv
