Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 433 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #12961 of 14814 Old 04-19-2013, 08:46 AM
mrcarnut's Avatar
Quoted: 26 Post(s)
Originally Posted by sshah3 View Post
Thank a lot Man, It was a killer deal that I could not pass up at all.
Was wondering if anyone knows someone in Austin that could professionally calibrate it and what is a good price for calibration?
I use Newbies settings and they're great. Haven't needed to have it calibrated after using these. Here's the last ones he posted for a pre Nov. 2012 build set which is what I believe you have. Go to page 384 post #11511 to get his settings. Enjoy.
mrcarnut is offline
post #12962 of 14814 Old 04-19-2013, 09:13 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
+1
I was shocked by how good Newbie's settings look. Couldn't be happier.
gweempose is offline
post #12963 of 14814 Old 04-19-2013, 11:48 AM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
What is considered s "good" build date? Month/year? Also, now I am reading about people getting this set for between 4k and $4800. Am I paying too much at $5250, sounds like it doesn't it? At least I have a 15 day return window if they don't want to budge on price anymore for me. That's a $1250 difference :/
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
post #12964 of 14814 Old 04-19-2013, 12:21 PM
kdog750's Avatar
Quoted: 128 Post(s)
Liked: 79
Well, I called Sharp back and they said they will NOT fix my TV(dead remote sensor) and just get a return authorization from Best Buy. I thought the Elite was discontinued? I asked them this and they said that it was not.
kdog750 is offline
post #12965 of 14814 Old 04-19-2013, 01:18 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Whoever you spoke to was flat out wrong. The Elite is most definitely discontinued.
post #12966 of 14814 Old 04-19-2013, 01:24 PM
AnotherDude's Avatar
Quoted: 36 Post(s)
Liked: 52
Originally Posted by gweempose View Post
Discrete code problem solved ....
Once I realized that the discrete "ON" command will work for a few seconds after the set is turned off, it dawned on me that I could create a 100% reliable macro using a combination of both the power toggle and the discrete "ON" command. You simply send a power toggle command immediately followed by the discrete power "ON" command. If the TV is off, even if it is in full standby mode, the macro will turn it on. If the TV is already on, the set will shut off and then instantly turn back on again. I tested it, and it functions perfectly. I'm lucky that this works on the Elite. Many TV's do not have the same kind of delay before going into standby. I still wish I knew why the discrete "ON" command doesn't work on my set, but this is a perfectly acceptable workaround. smile.gif
Very clever workaround!
AnotherDude is offline
post #12967 of 14814 Old 04-19-2013, 01:30 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Originally Posted by octavian View Post
I also checked for the close out on the 3D glasses. No close out deals for the Best Buys near me. They still want $59.
It's very possible that they haven't changed the prices on the sales floor, but they are definitely on closeout for $29.99. I just got back from Best Buy about fifteen minutes ago, and I bought out the last four pairs they had in stock. I figure I might as well grab some extras while I can, and this is by far the best price I've seen them for anywhere. The ones I'm talking about come in a box that looks like this:
post #12968 of 14814 Old 04-19-2013, 02:15 PM
kdog750's Avatar
Quoted: 128 Post(s)
Liked: 79
Well that representative was clueless. She actually laughed and said that it was never discontinued. The second one I spoke with said there they had no official word as to whether it is discontinued but that they had none in their warehouses. But, after speaking to Best Buy, they basically said that Elite was wrong and that they would not authorize a return 3 months after a purchase and they had no idea why they told me that. Best Buy did say they would see if they could help me out by finding a tech that could fix it but they doubted it since they had no Elite authorized dealers in the area either.
Elite did say they would give a Return Authorization Number to Best Buy if they could not fix it so I will see. But if I had ordered it through one of the vendors here, I would be completely out of luck. Let that be a lesson to anyone thinking about buying from one of these vendors that are not supported by Elite on warranty. I would have had a $6000 brick sitting in my living room of no value.
kdog750 is offline
post #12969 of 14814 Old 04-19-2013, 02:45 PM
octavian's Avatar
They would rather have you return the TV instead of fixing the IR sensor? That isn't very encouraging. I guess they don't plan on fixing the Elite TV's anymore. Very nervous about the demo TV I just bought.
octavian is offline
post #12970 of 14814 Old 04-19-2013, 03:33 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
It definitely makes one think twice before ponying up for the extended warranty.
post #12971 of 14814 Old 04-19-2013, 03:41 PM
Quoted: 36 Post(s)
Liked: 52
Who do you mean by "those vendors here"? If you mean Cleveland Plasma, they are fully supported by Sharp - that's who I got mine from and am fully registered with Sharp warranty and otherwise.
post #12972 of 14814 Old 04-19-2013, 06:21 PM
kdog750's Avatar
Quoted: 128 Post(s)
Liked: 79
That's exactly what I thought. Both Elite representatives tell me they have no techs in the area so the only solution is to get my money back. I am 2.5 hours east of Houston Texas though. I would probably be willing to pay half the bill if they would bring someone in. But I'm not sure they will even agree to that.
kdog750 is offline
post #12973 of 14814 Old 04-19-2013, 09:05 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
How can you tell what the date of manufacture is on the 70" elite?
post #12974 of 14814 Old 04-20-2013, 12:24 AM
kamiraa's Avatar
Liked: 31
Side note for everyone looking for an elite.
Sharp pulled the Elites with reason of EOL (end of life) from Best Buy Magnolia's data base.
So all Magnolia's are authorized to sell their display models for really cheap considering (around 45-50% off).
Picked up a somewhat new 70" tonight for $4200 (new store, been open only 6 months).
Figured not that bad. Hope this isn't against the AVS rules pointing people in a direction of a deal.
kamiraa is offline
post #12975 of 14814 Old 04-20-2013, 07:52 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Is this a very recent thing? When I bought mine just under two weeks ago, my store refused to go any less than 40% off.
post #12976 of 14814 Old 04-20-2013, 10:57 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Question. I registered my 70" on the Elite site:
http://elitelcdtv.com/
Do I also have to register it on Sharp's regular site?
post #12977 of 14814 Old 04-20-2013, 10:58 AM
gtbdevs's Avatar
Quoted: 17 Post(s)
What is your serial number on the set, that will tell you.
gtbdevs is offline
post #12978 of 14814 Old 04-20-2013, 12:02 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Which part of the serial is the month/year? My serial is 108811323 .Is mine considered a good month/year?Which tv wall bracket do you guys suggest? link would be great! How do I test for deal pixels/banding and stuff like that? Do I need color slides? if so where do I get these at?
post #12979 of 14814 Old 04-20-2013, 02:52 PM
gtbdevs's Avatar
Quoted: 17 Post(s)
That is an August 2011, same as mine.
There are slides that you can download from AVS, sorry don't have the link.
A Disney WOW disk is a good investment.
gtbdevs is offline
post #12980 of 14814 Old 04-20-2013, 03:30 PM
mikek753's Avatar
this is "good" serial.
Try not to look for defects.
If TV looks good for you just calibrate it to your liking.
for dead / stuck pixels use solid color R,G,B. http://www.checkpixels.com/
If you have PC connect to the TV it will even more easy to test and calibrate
http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/0_100
and check for those if you don't want to some else calibrate your TV
http://www.avsforum.com/t/1283669/links-to-this-forums-popular-threads/0_100
enjoy
mikek753 is offline
post #12981 of 14814 Old 04-20-2013, 04:28 PM
kamiraa's Avatar
Liked: 31
Yup, I think happened on Thursday this week
kamiraa is offline
post #12982 of 14814 Old 04-20-2013, 04:33 PM
kamiraa's Avatar
Liked: 31
enjoy
Good post, I used checkpixels last night before you posted this up and it worked great in full screen mode.
I used a monoprice swivel mount with my Kuro previously, it worked great with this one. It works out great to move the tv away from the wall for adjustments, and then push it back flat against the wall otherwise.
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
What is a good serial vs. bad?
2018169XX is mine (xx because I didn't want to post the whole thing here).
kamiraa is offline
post #12983 of 14814 Old 04-20-2013, 06:15 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Mikek753, how do you know which is the month and year in the serial #. Also is this considered a LED or LCD?
post #12984 of 14814 Old 04-20-2013, 06:38 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Is this considered a LED or LCD?
It's an LED backlit LCD TV. Most importantly, it's a full array set, not edge lit. Here's a great article that explains all the different types of backlighting found on LCD TVs:
http://reviews.cnet.com/8301-33199_7-57572740-221/led-lcd-backlights-explained/
post #12985 of 14814 Old 04-20-2013, 10:52 PM
Speakerphile's Avatar
Quoted: 51 Post(s)
Liked: 165
Sharp has not officially discontinued the Elite, for what that's worth.
Best Buy did recently provide instruction to the stores to begin selling their displays though as long as their warehouses were out of inventory. This is in anticipation of it's planogram location being used for a different model. Also, the stores will adjust the display pricing at their own discretion. Corporate does not dictate what to set them at.
Though I am an employee of Magnolia Home Theater, the views and opinions I express on this forum are those of my own and not my employer.
Speakerphile is offline
post #12986 of 14814 Old 04-21-2013, 12:31 AM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
How do you know all this?
post #12987 of 14814 Old 04-21-2013, 03:24 PM
Quoted: 51 Post(s)
Liked: 165
I work for Best Buy.
post #12988 of 14814 Old 04-21-2013, 06:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 935 Post(s)
Liked: 2078
Like you, there are several BB employees who are active in the display threads, and we appreciate the insight that you bring. smile.gif
htwaits is offline
post #12989 of 14814 Old 04-21-2013, 09:02 PM
kdog750's Avatar
Quoted: 128 Post(s)
Liked: 79
I wonder if the people I spoke to at Elite are really clueless about the line being discontinued or are they are being lied to by the company to keep them from quitting too soon. Or possibly they are instructed to lie to the public when they call.
kdog750 is offline
post #12990 of 14814 Old 04-21-2013, 09:18 PM
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
What are the vertical lines some people see called? I swear I see them on grey/white or dark screens. They look like they are about 2" apart and pretty even with each other. Is this normal for this tv? Or should I have concern? Im using newbies settings. I'm still within my return window. How do I test to get a better idea of how much is actually there? Thanks in advance.
Reply LCD Flat Panel Displays
Sharp Elite Black 70inch Pro 70x5fd Flat Panel 3d Led Hdtv , Sharp Elite Pro 60x5fd 3d Led Hdtv
