Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 489 - AVS Forum | Home Theater Discussions And Reviews
Old 04-03-2015, 11:23 PM
AVS Club Gold
MitchMurray's Avatar
I received my new PRO-70X5 in Jan2012. It has been working great, except the remote stopped connecting with the TV about 6 months ago. I had purchased a spare genuine Elite PRO-70X5 remote, which I fired up, and it connects with the TV fine. So it appears that the original remote went bad. I decided to order another spare genuine Elite PRO-70X5 remote.
MitchMurray is offline
Old 04-04-2015, 04:36 AM
6athome's Avatar
Quoted: 133 Post(s)
Liked: 69
Has anyone news about the new Sharp TV'S? CES 2015 Sharp said it was coming out with a 80in WCG FALD. What was interesting, list posted at that time of six grand, if it is like the pro, look out Samsung someone is about to run you over! Samsung's 9500 is almost the same price of LG'S OLED"S.ARE THEY NUT"S?
6athome is offline
Old 04-05-2015, 09:41 AM
Liked: 1
Originally Posted by aprikh1 View Post
Not only does Steve has the TV that I want, but he is also geographically close. Sigh...
Are you still looking for the 70 elite?
cmascali is offline
Old 04-05-2015, 07:16 PM
NHHobie's Avatar
Originally Posted by Spidergames View Post
is there any owners out there who had the elite from day one and never had the IR remote problem.... Does anyone have the IR remote problem?
Hi:
Have a 60" Elite. Original owner, bought from Chris at Cleveland Plasma back in Dec 2011. No problem with the IR. Did buy a spare board a year back as a "just-in-case". Love this frigging thing. Have 17,000 hours on it. Yeah...that's a real ####. Between in-laws and...working different hours than my wife this puppy gets a real work out. Just got it calibrated last summer by Greg L. at Lion Audio Video Consultants Inc. Am very pleased with this set.
NHHobie is offline
Old 04-12-2015, 04:32 AM
obxdiver's Avatar
Liked: 42
I've had my Elite 70" since Nov 2011.
Never had one problem with remote or any thing else with the TV.
The TV continues to perform flawless.
I did not buy the extended warranty...never do.
Is there a TV out there for sale now that will surpass this Elite?
I have not been keeping up with TV's since I got the Elite.
Just wondering if anything 70"+ has it beat or equal in PQ.
obxdiver is offline
Old 04-13-2015, 08:24 PM
N3W813's Avatar
Quoted: 14 Post(s)
Liked: 46
Yup, LG 77" OLED, if you can afford it.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
Old 04-16-2015, 07:30 PM
mikey94025's Avatar
Infamous IR sensor failure strikes again
Darn! My PRO60X5FD IR sensor just went out, and it's also one month after the 1-year Sharp extended warranty. So it took 3+ years to fail.
I found quite a few IR sensor boards (part no. DUNTKF909FM01) for sale on Ebay so I'll try getting one of those and finding someone to install it. Manually turning on the TV via the power switch gets old really fast!
mikey94025 is offline
Old 04-22-2015, 05:44 PM
bekindrewind's Avatar
Quoted: 24 Post(s)
Liked: 25
I search Ebay everyday for the last month. No DUNTKF909FM01 boards listed on EBay that I can find.
So you found one?
Pls let me know what you put in as a search. I need one.
Anthem D2v, McIntosh MC205, Elite PRO-70X5FD, Oppo BDP-103, Richard Gray Power Company 400S, B&W Nautilus, JL audio Fathom f113, Harmony One, lighter wallet
bekindrewind is offline
Old 04-22-2015, 07:21 PM
mikey94025's Avatar
I searched (USA) Ebay for "DUNTKF494FM01" and found a lot of listings. Some of the circuit board pictures vary quite a bit, so I went with the one that looks like a narrrower version (i.e., hopefully a newer, simpler version of the same circuitry) board picture in the YouTube instructional video (look at time 4:54):
This is the Ebay item I purchased but I won't know if it works until I find someone to try and install it: http://www.ebay.com/itm/371011595753
Old 04-25-2015, 02:25 PM
svukelich's Avatar
Liked: 1
The remote on my 60X5 quit working. I contacted a Sharp repair man and he determined it was not the remote but the IR board in the TV that failed. He contacted Sharp and was informed that they do not make that IR board anymore, nor have any in stock. They did send him a repair procedure and the replacement chips that failed. He de-soldered the old chips and soldered the new ones. The two chips were each approx. 0.1 x 0.1 inch so to take on this job you have to be good at soldering; he finished the job in under an hour and it cost me $125.
mikey94025 likes this.
svukelich is offline
Old 04-27-2015, 04:41 PM
Quoted: 24 Post(s)
Liked: 25
I searched (USA) Ebay for "DUNTKF494FM01" and found a lot of listings. Some of the circuit board pictures vary quite a bit, so I went with the one that looks like a narrrower version (i.e., hopefully a newer, simpler version of the same circuitry) board picture in the YouTube instructional video (look at time 4:54): https://www.youtube.com/watch?v=aCJhNDz_VdQ
This is the Ebay item I purchased but http://www.ebay.com/itm/371011595753
The correct board is DUNTKF909FM01
You searched for DUNTKF494FM01....why?
I doubt the board you bought will fit or work. The board you bought is not the board the tv uses.
I've attached a photo of the correct one (1st photo) and the one you bought (2nd photo) Boards are not the same dimentions at all. Look at where the IR sensor is on both. Lengths, wrong, width wrong, sensor in wrong place, etc.
As far as..."I won't know if it works until I find someone to try and install it" you posted a link on Youtube where the guy shows you how to do it. The Video shows how simple it is. Only need one philips screwdriver for the entire job. How easy is that.
So, why are you not doing it?
Then you can let us know the outcome.
ID:	690081   Click image for larger version
Old 04-28-2015, 05:59 PM
mikey94025's Avatar
Yeah, it would be easy if you have the use of two hands. But I don't.
I did have someone come out today and as you predicted, my part did not work because the ribbon clip is a slightly different width. As you pointed out, I searched for the wrong part number. I didn't notice that the Ebay search results for "DUNTKF909FM01" returns many parts with the other part number.
The guy is going to check with his suppliers but I'm not hopeful. I'm afraid I won't be able to repair my IR unless someone out there with a spare IR board is willing to sell me theirs... PM me and I'll make it worth your while... :-)
Old 04-28-2015, 06:23 PM
Quoted: 24 Post(s)
Liked: 25
Hey neighbor! I live in San Leandro, you know across the bay bridge.
If anyone has an IR board they are willing to sell, I'll make it worth your while too, being I've been searching longer than mikey, lol.
Mikey, if you need any help, PM me. Always willing to help a fellow AV guy out if I can.
Cheers,
bekindrewind
Old 05-02-2015, 02:09 PM
Liked: 0
The ir board is bad on my Pro 60x5 also. The remote never worked well from day 1 on my set.
I can't find anyone in my area who will repair my original board and Sharp support is not being very helpful. svukelich can PM me the phone number of your repair man? He seems like the guy who can help me. Thanks
MrTuck is offline
Old 05-04-2015, 04:37 PM
svukelich's Avatar
Liked: 1
My repair was performed by MidAmerica Service, 328 Jungermann Road, St. Peters, MO 63376-5350
(636) 442-4786. Go to appliancerepair-stlouis for their web site.
Sorry, I cannot PM yet (not enough posts) so I am replying globally here.
Old 05-05-2015, 06:40 AM
mikey94025's Avatar
Thanks for posting that info globally. I'm desperate for a solution. Perhaps we can all send our broken IR boards to this St. Peters, MO repair shop and have them repaired... I'm serious!
Old 06-05-2015, 07:57 AM
Liked: 0
same green line problem
Originally Posted by leftyguitar1963 View Post
Here are a couple more. Just e-mailed Sharp with these & a few others per their request. I imagine there are no longer any replacements? Not willing to take comparably priced edge-lit 4k panel. Any hope for a refund?
Did Sharp help you fix this problem? I now have the same issue on the right side of screen.
urgentclock6 is offline
Old 06-15-2015, 10:39 AM
PepperOne's Avatar
I know this is a very old thread but I'd like some help with something with the Elite 60.
I remember reading the thread where someone was mentioning a Power button, and a Power Saving button on the Elite remote. I believe there were complaints about one of those buttons (I think it was the Power Saving one) that effected the quality of the Elite and to turn it off.
Would someone refresh my mind on what to do with the Power Saving button on the remote?
PepperOne is offline
Old 06-15-2015, 01:23 PM
dsinger's Avatar
Quoted: 266 Post(s)
Liked: 259
The bottom of the remote has a flip up panel. Under that you will find a button for power save so you can turn it off.
dsinger is offline
Old 06-16-2015, 07:23 PM
mikey94025's Avatar
Another place to repair your broken IR board!
My local San Francisco electronics shop was able to repair my broken board so my TV works again (remotely). It cost me a bit more because of two home visits (the first to try installing the wrong board I bought from eBay, the second to install my old board after they fixed it), but they estimate a $100 repair charge for any such boards mailed into and back out of their shop.
Here's their contact info if anyone else desperately needs a repair:
A-Plus Electronics
2111 Van Ness Avenue
San Francisco, CA 94109
415-474-2111
Michael Braude
aplus101 at earthlink dot net
Old 06-16-2015, 07:48 PM
Quoted: 24 Post(s)
Liked: 25
A-Plus Electronics
415-474-2111
Michael Braude
You the man mikey!
Thank you for sharing that, for the IR board is going bad in a lot of these one year wonder tv's and no more replacement boards to be had. Lucky for me, SF is right over the Bay Bridge. Yahoooooo!
Sharp Elite Black 70inch Pro 70x5fd Flat Panel 3d Led Hdtv , Sharp Elite Pro 60x5fd 3d Led Hdtv
