Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 495 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #14821 of 14825 Old 06-10-2017, 01:08 AM
k_lewis's Avatar
Quoted: 65 Post(s)
Liked: 48
Originally Posted by mikey94025 View Post
Uh, before calling us a-holes consider that we were not the ones doing the repair nor dealing with Sharp. I just got my board fixed, without knowing (or yes, frankly caring) how it was done or what electronics were replaced. You could try contacting the repair shop via the info I previously posted if you need more info.
My comment was not really meant towards you since you did try to post something helpful.
I did call that place you listed twice, left two messages, never got a call back. Local shops are not necessarily going to work with out of state customers. If you read up you'd see that I posted other repair shop info for So Cal folks. I also posted info so anyone in any state can have their local Sharp authorized repair center get the correct info from Sharp.
01010100 01101000 01100101 01110100 01100001 00100000 01000011 01000010 01001001 01010110 00101100 00100000 01010100 01101000 01100101 01110100 01100001 00100000 01100001 01101101 01110000 01110011 00101100 00100000 01101100 01101111 01110100 01110011 00100000 01101111 01100110 00100000 01100101 01111000 01100011 01100101 01110011 01110011 01101001 01110110 01100101 00100000 01100001 01110101 01100100 01101001 01101111 00100000 01100111 01100101 01100001 01110010 00101110
k_lewis is offline
post #14822 of 14825 Old 06-22-2017, 02:57 PM
k_lewis's Avatar
Quoted: 65 Post(s)
Liked: 48
Talking How to repair the sharp elite pro60 pro70 ir board if it stops working
UPDATE!!! This WORKS!!!! Fixed the PRO70 IR board today by replacing the two bad capacitors per the info I previously posted above - well actually only one capacitor was bad but I replaced both since they are next to each other. one of the caps was shorted internally- see the links below with basic info on how to use a simple multimeter to test for a faulty smd capacitor.
With the right solder iron (inexpensive hot air smd rework station) and low temp solder paste, fine tweezers and magnifying headset glasses, I had the board repaired in 15 minutes. it's not hard and I am not an electronics expert.
SEE PICS FOR CAPACITOR LOCATIONS! REPLACE THESE TWO SMALL CERAMIC CAPS (PARTS INFO IN MY PREVIOUS POST ABOVE).
SHARP WILL NOT TELL YOU THIS INFO- THEY ARE COMPLETE JERKS! AND ANY SHARP REPAIR CENTER WILL CHARGE YOU AT LEAST $200 FOR A "IR BOARD REPAIR KIT".
Also you do not need to take the entire panel off the back of TV. you can sneak the lower corner open and wedge it so you can remove or install the IR board. the board clips into place (clip is on inside / left side of board, move that to side then pull rearward on the left / inner side) and it has one small plug. see pics
If you feel more comfortable, pull the rear cover of TV to remove the IR board, reinstall the rear cover, then just sneak the corner open again later to reinstall the board.
TEXT FILE WITH ALL INFO ON THE FIX FOR YOUR SHARP ELITE PRO 70 / 60 IR BOARD:
http://www.808networks.com/pub/Sharp...epair info.txt
PICS!!
How to test for shorted capacitor with ohm meter:
or
TIP: Use the metal case of the ir emitter on the board as the ground for one of the meter probes
TIP: Buy some low temp solder paste and a hot air smd rework station from amazon,
https://www.amazon.com/Tek-Motion-Di.../dp/B01MR2IWBN
https://www.amazon.com/Clean-Tempera...dp/B017RSGPI8/
or, use a low temp fine tip solder iron about 300f.
For the hot air rework device you'll use 300f and air setting 4.
If you use a regular large solder iron it will crack the ceramic smd caps from too much heat.
markrubin, sjchmura and SHadoWFoX like this.
k_lewis is offline
post #14823 of 14825 Old 06-22-2017, 03:03 PM
Audiguy3's Avatar
Quoted: 135 Post(s)
Liked: 74
Congratulations well done
Audiguy3 is offline
post #14824 of 14825 Old 06-22-2017, 04:29 PM
sjchmura's Avatar
Quoted: 1505 Post(s)
Liked: 597
PICS!!
https://www.youtube.com/watch?v=lpRgRDbhOPI
or
https://www.youtube.com/watch?v=uBUEjeS5UmI
You shoukd make them to order. Can we send you our for a fee?
Any idea why there capacitors.keep exploding? Should we upgrade to higher quality??
DocACE911 on Steam, XBOX, PS4
"Kill Cancer or Die"
Custom Z9 Game Settings For SDR and HDR
Sony 75" Z9, Denon X4200, Definitive Technologies BP7002 + 9.1 ATMOS, PSV 18" sub
Loving Wife and 4 year old Son who tolerate this expense!
sjchmura is online now
post #14825 of 14825 Old 09-17-2017, 11:25 PM
rennwerkes's Avatar
I hope someone can help me with a part number.
I have the opportunity to buy a 70" Elite but it has no stand.
I'd rather use a stand than mount on a wall.
Could anyone tell me what the replacement part number is?
rennwerkes is offline
Reply LCD Flat Panel Displays
Sharp Elite Black 70inch Pro 70x5fd Flat Panel 3d Led Hdtv , Sharp Elite Pro 60x5fd 3d Led Hdtv
