LG 37LF2510 Home cinema connection problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-12-2011, 12:17 PM - Thread Starter
mattinker's Avatar
Hi,
I couldn't find anything on my problem, so a new thread!
I have an LG 37LF2510 for which I naively bought a Sony DAV-TZ230 Home cinema, thinking it would be plug and play!
My problem is that the only way to get the sound "out" of the television is through the phone jack (and no control over the quality of the sound!)! Into the the DAV-TZ230 through a synch RCA in adapter! Everything else has no output from the television, neither HDMI, synch nor RCA jacks!
There must be a way of doing this!
Regards, Matthew
mattinker is offline
post #2 of 5 Old 09-12-2011, 01:04 PM
mes444's Avatar
Your tv should have a optical audio output. Plug an optical cable from it into the sound system and you'll get sound.
mes444 is offline
post #3 of 5 Old 09-12-2011, 04:13 PM - Thread Starter
mattinker's Avatar
My TV has an optical output, but the HC has only Scart and HDMI
I'm looking for a hidden menu or something of that kind.
Regards, Matthew
post #4 of 5 Old 09-12-2011, 05:06 PM
mes444's Avatar
If you are using a cable or satellite box (or whatever type box you have over there) you can run audio cables straight out of the box into your sound system if they have matching audio type cable output and input. Usually HDMI from the box into the sound system then HDMI from the sound system into the tv.
mes444 is offline
post #5 of 5 Old 09-13-2011, 08:25 AM - Thread Starter
mattinker's Avatar
So obvious when it's done, but nothing in the instructions to tell you!
Regards, Matthew
Reply LCD Flat Panel Displays
