Toshiba 55G310U fast video playback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-09-2011, 05:40 PM - Thread Starter
Mugenstylus1's Avatar
I recently just bought a Toshiba 55G310U, as the title says and am using a WDTV in playing back the video it seamed as it was sped up. I messed around with some of the options and fixed it. But I'm not sure which option I changed to fix the problem.
If anyone can help me out so I know which option I changed to fix this and why it happens I'd appreciate it. Thank You.
Mugenstylus1 is offline
post #2 of 3 Old 10-09-2011, 10:25 PM
FadedMaster's Avatar
The option was probably something to do with a motion smoothing setting. Not sure what Toshiba calls it though. But it usually has the word "motion" on a lot of TVs. It might also have 120hz or 240hz in the setting.
Smile. :)
FadedMaster is offline
post #3 of 3 Old 10-10-2011, 05:46 AM - Thread Starter
Thank you. I did change a motion smoothing option, glad I know what I am looking for next time.
Reply LCD Flat Panel Displays
Toshiba 55g310u 55 Inch 1080p 120 Hz Lcd Hdtv Black
