AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   LCD Flat Panel Displays (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/)
-   -   Technical Issue with HDTV screen (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1371144-technical-issue-hdtv-screen.html)
kebaslane 11-05-2011 05:02 PM
I'll have to edit this later when I have a picture of my tv, but basically it looks like a normal screen with colorful lines on the side that stay there and do not move, fade or anything else. It also has what looks like something hit it and cracked the glass, but there is no crack that I can feel so it might be internal. What can I do? Do I have to fix the logic board and what it says on the youtube comments? It's a Westinghouse 40" 1080 HDTV that I bought 1 yr. ago.
DrDon 11-06-2011 07:26 AM
9 Attachment(s)
Thread moved to proper display forum.
mes444 11-06-2011 08:32 AM
Look at the link, about 3/4 down. If that's what your screen looks like they say its caused by a defective tab.
http://www.lcdparts.net/howto/symptom.aspx
kebaslane 11-06-2011 10:13 AM
Very similar, but I also have shorter, rainbow colored lines. Hopefully you can see this:
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
