Physical clouding on my LCD and it never disapper - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 11-14-2011, 11:42 AM - Thread Starter
crunchor's Avatar
This is a long story. First my thinkpad T60 notebook LCD start to not able to have backlight once I turn the light level to maximum. I tried to use a new inverter and it doesn't work. I did a lot of research and found out it should be the CCFL get old then using too much voltage problem. Changing CCFL is complicated so I ask nearby store and it requires around $65 US dollars to do so, while second hand market is just around 3 times of this price for my notebook, then I decide just to use lower light level.
After light can set at maximum level, I clean my LCD as usual with a cleaner for monitor, then somehow some "clouding" looking on the screen. I thought this would disappear after days, but even after 2 weeks, it is still there. I bought a 3M screen cleaner and try to clean it up, but it doesn't. The clouding is almost 80% of the screen now with all at the middle and just spread out but not touching the edges yet.
Any solution for this? Could this be just some of the LCD panel chemical have been changed after the CCFL had too high voltage and heat for too long time before finally cannot turn on maximum light level? Or just the panel is too old (5 to 6 years old) then just it is time for the chemical decay!?
I just took and pic and update this post with it!
crunchor is online now
post #2 of 38 Old 11-14-2011, 12:43 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
It's hard to see any clouding because of that obnoxious flash at the lower right of the screen.
If your problem is caused by a screen cleaner, it would not surprise me. What I CAN see looks like possibly permanent streaks (not clouding) on the screen. That's why I just use water and a microfiber cloth for my computers and my TVs.
BoilerJim is offline
post #3 of 38 Old 11-14-2011, 09:54 PM - Thread Starter
crunchor's Avatar
Permanent streaks are what happening, and actually it is like 80% of the whole screen area now, from middle spread out, but somehow around the edge there aren't.
It only happened after my backlight has problem and cannot turn on the maximum level of light for more than 10 seconds, so now I only use very low level light now. After this and I clean the screen as usual, this happens! I always use that cleaner for years without any problem. So I am pretty sure it is related to the backlight.....
post #4 of 38 Old 11-15-2011, 01:10 AM - Thread Starter
crunchor's Avatar
I hope someone would know what is going on...
post #5 of 38 Old 11-16-2011, 01:44 AM - Thread Starter
crunchor's Avatar
seem like this is a very rarely happen special case..almost no people have idea..
post #6 of 38 Old 11-16-2011, 07:37 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
nope
pay for repair or buy new laptop
dm145 is offline
post #7 of 38 Old 11-16-2011, 09:34 AM - Thread Starter
crunchor's Avatar
Originally Posted by dm145 View Post
nope
The light bulb gets old is common, but the screen become like this is uncommon right? If I replace my whole LCD, pretty sure more expensive than the price I can sell the whole laptop in second hand.
post #8 of 38 Old 11-16-2011, 10:38 AM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
I would agree with BoilerJim. It looks like streaking from use of a "screen cleaner". Probably a combination of both issues. LCD panels (or any computer/tv panel for that matter) should only be cleaned with a clean micofiber cloth and warm distilled water. Turning the backlight to maximum is never a good idea anyway (including tv's) so you're probably s.o.l. on this one and will either have to deal with the workaround, pay for repairs, or better yet, just buy a new one. A laptop that is 5 or 6 years old is getting long in the tooth.
Otto Pylot is offline
post #9 of 38 Old 11-16-2011, 11:05 AM - Thread Starter
crunchor's Avatar
Yes I used screen cleaner and this happened. But before the backlight has problem, I alays used the same cleaner to clean this laptop monitor for at least 3 years without any problem. Now after having the backlight problem, I tried to clean the lcd then this happend. So still have no idea what is that. If I see from the side, look like some oil streaking.
post #10 of 38 Old 11-16-2011, 12:26 PM
Otto Pylot's Avatar
Liked: 852
Maybe the streaking was there all along due to the cleaner and you never noticed it until you started having backlight problems. Now you have two problems, flaky backlighting highlighting a streaked screen.
post #11 of 38 Old 11-16-2011, 01:13 PM
WaldorfSalad's Avatar
As someone who repairs laptops for a living I think I can safely say that you need a new lcd screen. I don't even try to replace backlights, its too easy to do more damage, get dirt inside the panel, uneven lighting, etc. A new screen replacement will likely set you back around $50-75 plus 1 hour labor. Be warned though that T60 screen assemblies are delicate and its real easy to damage the fragile ribbon cables. As for the streaking you probably damaged the front polarizing layer.
WaldorfSalad is offline
post #12 of 38 Old 11-16-2011, 09:15 PM - Thread Starter
crunchor's Avatar
front polarizing layer..is it that easy to get damaged? I thought replacing the panel is so expensive...
post #13 of 38 Old 11-16-2011, 09:16 PM - Thread Starter
crunchor's Avatar
May be..but I think the screen didn't have this problem...I always check out the screen like once a month as a habit...
post #14 of 38 Old 11-16-2011, 09:27 PM - Thread Starter
crunchor's Avatar
I have an idea that if the light blub is fixed and work as normal, the light level would heat up the stuff in the panel..then these streaks would vapor and disappear.....just I guess this is possible.
post #15 of 38 Old 11-16-2011, 11:22 PM - Thread Starter
crunchor's Avatar
I will try to take a new photo with the whole screen to show you guys how it looks like.
post #16 of 38 Old 11-17-2011, 09:35 AM - Thread Starter
crunchor's Avatar
I just took some photos but too hard to see any of these on the photos.....
post #17 of 38 Old 11-17-2011, 12:01 PM - Thread Starter
crunchor's Avatar
No one has new idea..then I sleep first..
post #18 of 38 Old 11-17-2011, 12:06 PM
Otto Pylot's Avatar
Liked: 852
You have been given some good advice so I'd suggest you follow it. One, use only a microfiber cloth and warm, distilled water to clean your screen because it sounds like over time you have damaged the polarization film and two, repair your laptop's LCD panel for the back lighting issue. Or, ideally, buy a new laptop.
post #19 of 38 Old 11-17-2011, 01:52 PM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
+1000
enough already
dm145 is offline
post #20 of 38 Old 11-17-2011, 01:52 PM
Where do you get those crazy ideas? Again, you most likely need a new LCD panel (and then be careful how you clean it), which may set you back $150 for parts & labor, but a new laptop would cost you a lot more than that ($300-350 tax minimum for an entry level laptop).
Btw, have you actually taken your laptop into a repair shop for a diagnosis of the problem? You may get lucky and just be the inverter which is a relatively inexpensive repair.
post #21 of 38 Old 11-17-2011, 07:27 PM
Extreme_Boky's Avatar
The above idea seems sensible; do it the moment you wake up.
Boky
Extreme_Boky is offline
post #22 of 38 Old 11-17-2011, 07:57 PM - Thread Starter
crunchor's Avatar
I don't really understand. I use the cleaner which is designed for cleaning computer monitor. How can it be bad for the screen? I heard and I think it is logical that normal water is bad for screen and screen is not designed to be cleaned by water.
How do polarization film gets damaged? Can it be because I use tissue to clean?
This happened right after my black-light has problem, you guys really think has no relationship with it?
post #23 of 38 Old 11-17-2011, 07:59 PM - Thread Starter
crunchor's Avatar
I bought a new inverter and it doesn't help. Now the back light would just on and off and sometimes just turn off even i turn to the lowest level, almost 100% sure it is the back light out of service.
post #24 of 38 Old 11-17-2011, 09:14 PM
Otto Pylot's Avatar
Liked: 852
I'm done. You guys can take over.
post #25 of 38 Old 11-17-2011, 11:05 PM - Thread Starter
crunchor's Avatar
seriously, I spent like $5 US dollars to buy professional monitor cleaner but water works better? And the cleaner damage the screen? I am open minded but I need something to believe that...
post #26 of 38 Old 11-18-2011, 05:41 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
There have been many threads regarding how to clean an LCD screen posted on this Forum in the past four years and the use of a microfiber cloth and distilled water is regarded to be the best solution.
I agree with those who think it's time to take your PC to a shop and have the problem professionally diagnosed or simply decide that it's time to buy a new one.
post #27 of 38 Old 11-18-2011, 07:55 AM - Thread Starter
crunchor's Avatar
Just google, you will find out most of the people in the world believe put some water your LCD screen is one of the fastest ways to destroy it.
post #28 of 38 Old 11-18-2011, 08:16 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
That's funny. If that's true, why would Samsung include a microfiber cloth with their TVs and say to use water, wiping in only one direction?
You do what you want. Like Otto, I'm done with this thread because...
I DON'T CARE ANYMORE!!
post #29 of 38 Old 11-18-2011, 09:07 AM - Thread Starter
crunchor's Avatar
Why don't you show us a samsung LCD manual and which page did they mention it? I am using a samsung 24: monitor as well, and I saw people in internet in my local area saying hat microfiber scratch monitor so I never use it.
post #30 of 38 Old 11-18-2011, 09:13 AM - Thread Starter
crunchor's Avatar
HERE:
Use a soft, damp cloth with a "monitorexclusive
cleansing agent" and wipe the
product with it.
from a new model Samsung LCD monitor manual
http://www.samsung.com/hk_en/consume...subtype=others
page 8
Reply LCD Flat Panel Displays
