Official Sharp 2011 LC-70LE632U Owner's Thread - Page 23 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #661 of 1496 Old 01-31-2012, 09:25 AM
Jorge18's Avatar
Originally Posted by jarod7736 View Post
I just got this TV Sunday, and was trying to do some calibration/setup. Playing Netflix (True Grit) through my XBOX 360 resulted in the S.O.E., and I turned off film mode, motion enhancement, and active contrast. And I was still getting pretty serious SOE.
I modified the settings for the Film preset, as well as the User settings and it occurs in both modes. If I put the tv in game mode, it doesn't do it, but the color isn't quite right. The options for film mode, motion enhancement are blacked out in the 'Game' preset, but they aren't when i'm in 'Film' or 'User'. Are those things actually getting turned off?
Hm, that's pretty weird. Right now I'm in film mode with all of the settings turned off, and I don't get any SOE.
Have you tried any other source? Also, are you coming from a plasma?
Jorge18 is offline
post #662 of 1496 Old 01-31-2012, 09:41 AM
rbanez's Avatar
Mine is turned OFF and using Standard mode and SOE does not show.I turn it on and I get tons of SOE. I also have active contrast ON and Motion at 120hz HIGH but still no SOE if turned OFF. Not sure why yours is not turning off.
rbanez is offline
post #663 of 1496 Old 01-31-2012, 09:45 AM
waltaz's Avatar
Quoted: 20 Post(s)
That IS weird. I don't get any SOE at all, unless I turn on Film Mode. I use the Movie preset (which I think you guys are calling the Film preset).
As Jorge said, try your "normal" TV input, from a DVR or whatever, and see how that looks.
BTW, I don't like the Netflix streaming. PQ seems fine, but I don't get 5.1 audio.
waltaz is offline
post #664 of 1496 Old 01-31-2012, 11:25 AM
jarod7736's Avatar
I have 3 primary sources, Time Warner Cable box, Xbox 360, and AppleTV 2. Watching a movie streamed via iTunes on atv2 last night, i didn't get the effect, though AppleTV2 is limited to 720p. Most material from the cable box doesn't give the effect, though my wife said that a movie trailer was giving it this morning. I do get it via netflix on the xbox.
I'm coming from an older LCD 42". So this is blowing me away, but the SOE is very, very disturbing.
jarod7736 is offline
post #665 of 1496 Old 01-31-2012, 12:09 PM
Jorge18's Avatar
Well, like I said before, I have everything turned off and have no SOE, BUT there are some commercials that I watch that have it pretty badly. I'm assuming this is just the way the commercial is shot because it only happens on certain ones.
Jorge18 is offline
post #666 of 1496 Old 01-31-2012, 12:11 PM
jarod7736's Avatar
I guess the source material itself has a lot to do with it then? I'll have to try another movie via the xbox360/netflix and see if it does it as well.
post #667 of 1496 Old 01-31-2012, 12:25 PM
Jorge18's Avatar
Yea, I think it definitely matters. Try it out and let us know.
Jorge18 is offline
post #668 of 1496 Old 01-31-2012, 06:06 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
Get my wow disk tomorrow can't wait. Still messing with streaming having problems but the tv is great. Going to try my WD live this weekend
Holiday121 is offline
post #669 of 1496 Old 02-01-2012, 06:06 AM
Wedstuntpuller's Avatar
Just got one of these on monday. Turned it on this morning and everything had a deep pink hue to it. Reset picture settings and reset power and it went away. Turned the tv off, then on again an hour later and the pink hue is back, boo! Anybody experienced this or know what the issue might be?
Wedstuntpuller is offline
post #670 of 1496 Old 02-01-2012, 06:13 AM
JBUNGIE's Avatar
Having audio sync issues with PS3 Blu Ray...made sync adjustments with my Onkyo receiver, but its still there. Is it the TV?
My other sources look ok..
JBUNGIE is offline
post #671 of 1496 Old 02-01-2012, 06:30 AM
waltaz's Avatar
Quoted: 20 Post(s)
I have not experienced this at all, and haven't seen it mentioned. What's your source? Are you in Movie mode?
waltaz is offline
post #672 of 1496 Old 02-01-2012, 06:37 AM
Source is Verizon FIOS HDTV cable box. Film Mode was turned off, but yes I believe the first picture settings option was set to Movie. Even when the tv was reset back to default settings it still did it, though.
post #673 of 1496 Old 02-01-2012, 07:46 AM
waltaz's Avatar
Quoted: 20 Post(s)
Weird...could be a bad panel...?
waltaz is offline
post #674 of 1496 Old 02-01-2012, 08:24 AM
mdub100's Avatar
Did anyone (who bought this at costco) buy the extra warranty that they sell for $100? I am wondering if I should just pony up the extra $100 or if you think the standard costco warranty is good enough.
mdub100 is offline
post #675 of 1496 Old 02-01-2012, 08:44 AM
Good lord I hope not... Anyone else got any ideas??
post #676 of 1496 Old 02-01-2012, 09:01 AM
waltaz's Avatar
Quoted: 20 Post(s)
I bought my 632 at Costco, but skipped the warranty. I used my Amex there, so they double it or something, which is good enough for me. Though the $99 for three years IS a good deal, if you like those things...
waltaz is offline
post #677 of 1496 Old 02-01-2012, 10:32 AM
jarod7736's Avatar
It seems that it still happens on various material on nextflix on xbox360. True Grit does it, Tron Legacy, but 13 Warriors doesn't.
post #678 of 1496 Old 02-01-2012, 10:57 AM
robo24's Avatar
5 days after buying the clouding is totally gone. Got the Disney WOW blu-ray last night and it made quite a difference. I was having lip sync issues and couldn't get them right on my own. The audio sync part of the disc helped a lot, it needed to be set to delay 7 frames. As this was with a new Pioneer receiver, which has it's own setup, I thought it would figure out the sync on its own, as it did with my Olevia 747i. No matter, as it looks perfect now.
Before I had this disc I was getting pretty frustrated because it looked worse than my 5 year old LCD. Now it looks about as good. Something is still up with the bright ness and contrast since dark areas like black hair have no detail in them. I have OPC and active contrast on, but pretty much everything else off. I did not mess with any of the more advanced color adjustments. I had an old Video Essentials DVD, but I just couldn't get it looking right with that, so the Disney Wow was worth the purchase. The other thing that takes some getting used to is more fuzziness vs. my 47". I sit about 6' away, so of course the pixels are larger on the 70" and it looks less sharp at the same distance. Have sharpness set to 0 though since I don't want any artificial sharpening. I'm much happier with this TV than I was a few days ago. Stick with it until you can calibrate it with this disc.
robo24 is offline
post #679 of 1496 Old 02-01-2012, 11:49 AM
RobbinMerritt's Avatar
Try a different HDMI cable plugged into a different image source -- and plug the cable into a different HDMI port on the TV.
Robbin
RobbinMerritt is offline
post #680 of 1496 Old 02-01-2012, 02:53 PM
king_puma9's Avatar
just got mine in yesterday! I cant wait to check out some nice blu rays! now I just have to mount the monster on the wall. Mount should be here tomorrow!
king_puma9 is offline
post #681 of 1496 Old 02-01-2012, 03:04 PM
Jorge18's Avatar
Congrats man! Make sure you mess around with the settings with the settings posted previously and you'll love it!
Jorge18 is offline
post #682 of 1496 Old 02-01-2012, 03:51 PM
ace5000's Avatar
Quoted: 47 Post(s)
OK, they are delivering the beast tomorrow morning. I will need a good basic stand, and am considering the Mack Extended Warranty - $215.00 for 5 years total. I hate the idea of these things. BB wanted $399!
ace5000 is offline
post #683 of 1496 Old 02-01-2012, 04:24 PM
Jorge18's Avatar
I would look into the Squaretrade deal at Costco. It's $99 for 3 years.
http://www.costco.com/Browse/Product...=1&topnav=&s=1
Jorge18 is offline
post #684 of 1496 Old 02-01-2012, 04:40 PM
ace5000's Avatar
Quoted: 47 Post(s)
Interesting - I will look into this tomorrow. Worth buying a membership. Thanks for the tip!
"Costco's SquareTrade pricing is exclusive to Costco Members. You must purchase a SquareTrade Service Plan from a Costco Warehouse or from www.costco.com. Costco members may also purchase a SquareTrade Service plan to cover a new TV purchased outside of Costco from an authorized retailer in the US. Service Plan must be bought within 60 days of purchasing the TV.
*Excludes limited life consumables such as batteries and lamps."
3 Years
(For TVs Over $1,000)
2 Years Costco Concierge Plus 3 Years
Extended Protection = 5 Years Total
Item # 575686
$99.99!!
ace5000 is offline
post #685 of 1496 Old 02-01-2012, 05:42 PM
lifesun's Avatar
I just got the 60 inch 632 and OPC washes out detail, and active contrast crushes black pretty bad so detail is lost in dark scenes.......so I have both of those settings off.
lifesun is offline
post #686 of 1496 Old 02-02-2012, 02:48 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
Attachment 236037
How does she look
post #687 of 1496 Old 02-02-2012, 04:48 AM
ace5000's Avatar
Quoted: 47 Post(s)
Fantastic - congrats!
ace5000 is offline
post #688 of 1496 Old 02-02-2012, 05:07 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
thanks i love it get my wow disk today
post #689 of 1496 Old 02-02-2012, 09:44 AM
azb120's Avatar
I just ordered this TV , have to pick it up tomorrow . Any recommendations for a basic sturdy tv stand and where to get it (bb, costco, target etc) since it weights about 100 lbs. ?
-Thanks !
azb120 is offline
post #690 of 1496 Old 02-02-2012, 09:57 AM
mark62's Avatar
Liked: 88
-Thanks !
if you dont mind Ikea, they have a wide assortment at very reasonable prices.
mark62 is offline
Reply LCD Flat Panel Displays
