Official Sharp 2011 LC-70LE632U Owner's Thread - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1471 of 1496 Old 02-11-2013, 04:04 AM
Peter_in_PA's Avatar
Originally Posted by HowieDoin View Post
@ Peter_in_PA
Any chance you might post your settings for us to try? I'm mostly pleased with the way hockey looks on my 632, but always looking to improve....
Sorry for not replying sooner. While I don't have the Post #s to share with you, I've been using settings DAGAMEPIMP posted elsewhere on this forum last year or maybe in 2011.
Leave the gun, take the cannoli ...
Peter_in_PA is offline
post #1472 of 1496 Old 03-07-2013, 03:37 PM
tential's Avatar
Quoted: 40 Post(s)
Liked: 51
I've had my 70LE632U for awhile now. I'm enjoying it a LOT but now I want some help calibrating. I been calibrating/setting up everything and I know I got some help here before on pulling the trigger but now I could really use some help. I'm getting a lot less contrast then other models. Colors are a little washed out. Colors seem more contrasted on samsung and smaller TVs. Maybe it's the size of the TV I'm not sure though. I know someone here was helping before that has this TV and they were VERY helpful. I could use some of that help now though lol.
tential is online now
post #1473 of 1496 Old 03-08-2013, 02:16 AM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
Try adjusting the Gamma to give more contrast -- then you can add color, if needed...
johnfull is offline
post #1474 of 1496 Old 05-20-2013, 11:21 AM
ace5000's Avatar
Quoted: 43 Post(s)
Peter,
I would connect a laptop directly to one of the TV's inputs, preferably HDMI if the PC has one. I use the monster all of the time with video from my PC and sound through the receiver.
ace5000 is offline
post #1475 of 1496 Old 06-12-2013, 12:39 AM
robertdunn1834's Avatar
I just got a aqous 70 LC-70Le632U. On my remote there is no apps button and I don't know how to get to the apps screen. I have my wifi on. Who've read through the manual and it says hit on of the A B C D buttons at bottom of remote but that doesn't work. Please help
robertdunn1834 is offline
post #1476 of 1496 Old 06-12-2013, 12:52 AM
Also there is no apps icon under menu
post #1477 of 1496 Old 07-20-2013, 12:42 PM
Twiztid1's Avatar
Hi. I was advised to make a post in this thread as it deals with a model very similar to mine (Sharp LC-70LE633U), which does not have its own thread/forum. I have forgotten the Secret Number (PIN #) and cannot figure out how to reset it. For some reason, this specific model does not seem to have a manual and reset methods for similar models do not appear to work (i.e., Hold down the Channel Up and Volume Up buttons simultaneously until a message appears). Additionally, I did a search here on AVSForums and didn't see anything already posted. Any guidance greatly appreciated.
If I have posted in the wrong place for this type of question, please let me know.
Many thanks in advance! Looking forward to your replies.
Twiztid1 is offline
post #1478 of 1496 Old 07-21-2013, 05:41 AM
myoda's Avatar
Liked: 57
Page 34 of the operation manual found here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&ved=0CFQQFjAD&url=http%3A%2F%2Ffiles.sharp.ca%2FDownloads%2FForHome%2FHomeEntertainment%2FLCDTVs%2FManuals%2FLC70LE733U-LC-70LE633U-LC60LE633U_us3_en.pdf&ei=LdXrUYW8JtHK4AP75oHgAw&usg=AFQjCNELU4QiNndSouWfVEssOcldUxOq6w&bvm=bv.49478099,d.dmg
You can set and change the secret number by using
0-9.
Yes: Changes or sets the Secret No.
No: The confi rmation screen to clear the Secret No.
appears when the Secret No. has been set. When the
Secret No. has not been set, the previous screen will
be displayed.
Secret No. Clear
You can clear your secret number.
Yes: Your secret number is cleared.
No: Your secret number is not cleared
If you can't clear it, call Sharp.
myoda is offline
post #1479 of 1496 Old 09-14-2013, 11:02 AM
ace5000's Avatar
Quoted: 43 Post(s)
Hello All - any new great calibration settings for this 70?
ace5000 is offline
post #1480 of 1496 Old 11-20-2013, 08:12 AM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
Mounting bracket question for this TV. I am looking to put mine above my fire place mantle with a downward swinging bracket. Has anyone done this? If so which bracket did you go with and how do you like it?
I was looking at this bracket which has some pretty nice features but at a price of $199 + S&H it is a bit more costly than I would like. Are there any other options?
http://www.mantlemount.com/
BrutalBodyShots is offline
post #1481 of 1496 Old 01-02-2014, 10:26 AM
Quoted: 353 Post(s)
Liked: 85
Update - I did purchase/install the mantle mount bracket for this TV and it works great if anyone is interested in it.
post #1482 of 1496 Old 03-13-2014, 12:34 AM
makaveddie81's Avatar
Quoted: 493 Post(s)
Liked: 277
After going through 3 calibration sessions, I believe I found the perfect settings that squeeze every ounce of performance out of this set. Although the black levels of this display are not very good to begin with, the picture quality it can produce if calibrated properly is quite amazing. Calibrating this set is quite difficult, as the CMS is not very good. Blue, red and cyan are the most difficult colors to get right and I believe I found just the right balance. I used an i1 display pro and colorhcfr software for the calibrations.
Your bluray player must be set to output ycbcr 422.
Mode movie (most accurate gamma and greyscale)
Opc off
Backlight -1 for 32ftl or -9 for 50ftl (I prefer 32ftl, gives it a plasma look)
Contrast 32
Brt 0
Color 0
Tint 0
Sharpness -1
Cms Hue
R -1
Y -1
G +13
C -3
B +6
M +2
Cms Sat
R 0
Y 0
G +18
C +11
B -2
M -7
Cms val
R +3
Y +3
G +9
C -6
B +12
M +3
Color temp
R lo 3
G lo 0
B lo -10
R hi 2
G hi 0
B hi -17
Motion enhancement off
Active contrast off
Gamma 0
Film mode off
Digital noise red off
Monochrome off
Range of opc
Max 1
Min 0
DevilDog151 likes this.
JVC DLA-RS4810
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-151FD
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #1483 of 1496 Old 04-24-2014, 08:04 AM
HowieDoin's Avatar
@makaveddie81
Over a month later for this reply, but if you could tell me what your lighting is like in the room?
HowieDoin is offline
post #1484 of 1496 Old 04-24-2014, 03:28 PM
Quoted: 493 Post(s)
Liked: 277
@makaveddie81
I have two giant windows to the right of the display. I calibrated to 32ftl since I don't watch it during the day anyways.
HowieDoin likes this.
JVC DLA-RS4810
post #1485 of 1496 Old 04-25-2014, 07:00 AM
HowieDoin's Avatar
Similar to myself...I'll try out the settings and post my results.
post #1486 of 1496 Old 04-25-2014, 05:48 PM
demroyer's Avatar
I mostly watch at night, but my kids watch during the day (or play XBox during the day). We have a giant sliding glass door to the left of the TV, but often close the blinds to reduce glare. If 32ftl is what you would use for nighttime watching, what would you opt for during the daytime? Is that the 50ftl you indicate in your calibration settings?
Demian
demroyer is offline
post #1487 of 1496 Old 04-25-2014, 05:50 PM
Quoted: 493 Post(s)
Liked: 277
Demian
Yes 50ftl for day.
JVC DLA-RS4810
post #1488 of 1496 Old 06-23-2014, 05:28 AM
ace5000's Avatar
Quoted: 43 Post(s)
makaveddi,
Those settings rock! Thanks for your hard work and post! Natural skin tones with no tint adjustment, just great. I do play with film mode and motion a bit because I like the 3D look, but overall a huge difference.
ace5000 is offline
post #1489 of 1496 Old 01-15-2015, 09:31 AM
DevilDog151's Avatar
Spoiler!
Thanks for the settings. Skin tones do look more natural. What setting are you using for color temp? I went with middle.
LG C6 / LG SJ8 / Oppo 203 / Sony PS4
DevilDog151 is offline
post #1490 of 1496 Old 01-15-2015, 10:21 AM
Erkme73's Avatar
Bad panel
I bought this set from Sam's Club on Black Friday in 2011 (11/26/11). About a year ago, I started getting a very intermittent faint blue vertical line (one pixel wide) about two inches from the left bezel. A slight push on the bezel at certain spots would make the disappear for a few days/weeks.
About a month ago, the line changed from faint blue to bright fluorescent red - an eye-magnet like no other.
I read up on these forums to find others with this model having similar failures, and it didn't look good - no one was able to find any resolution from Sharp - other than replacing the set. Apparently when this happens, the panel is deemed "defective", and with a panel replacement cost higher than a new set, it's the end of the road for the TV.
Nevertheless, I called Sharp and jumped through various hoops. After several emails and phone calls, I finally reached a department that deals with these kinds of things (out-of-warranty but known defect issues). There, the guy I spoke with offered me their 2014 equivalent 70" model (I forget the model number). Apparently, it has smarts and other features that make our model seem antique. Given my bad experience, he was offering to ship me the new model, white glove install, and take the old one, for $700.00.
At first that sounded like a reasonable offer - except that means I'm in $2700 (I paid $2k in 2011) for a 1080P TV. And, the replacement is a refurbished unit with a 90-day (!) warranty. As he talked, the offer seemed less and less attractive.
In the end, I opted not to proceed. Given that 4K UHD sets are now becoming affordable, the last thing I want to do is sink even more money into a brand that - so far - has had questionable reliability. Putting money towards a technology (1080p) that will soon be considered legacy, seems a bit short-sighted.
In any case, my search for a 70" UHD has begun. I suppose I should find a home for this 70" with the red line. My brother even suggested going through with the $700 exchange, and then selling the set to someone for a small profit. Have not really decided if that's the way to go.
If anyone out there is experiencing the same kind of lines, just know Sharp is apparently trying to compromise at this point.
Erkme73 is offline
post #1491 of 1496 Old 01-15-2015, 11:02 AM
Quoted: 493 Post(s)
Liked: 277
I sold the TV about a year ago (replaced it with a KURO ) but if I recall correctly, Color Temp was set to Low.
post #1492 of 1496 Old 01-15-2015, 11:08 AM
Quoted: 493 Post(s)
Liked: 277
What is the model number of the replacement TV?
It would be easier to make suggestions knowing the price of the replacement, but I think your brother makes a good point. At the very least, you can make your money back as someone will buy the replacement TV for you for the right price. In the meantime, you'll have a TV to hold you over until you find your UHD.
Was the guy willing to lower the price if you didn't want the white glove installation and only delivery?
post #1493 of 1496 Old 01-28-2015, 08:25 PM
Turboo2u's Avatar
Quoted: 95 Post(s)
After 3 years, I'm still pretty happy with this TV. It took awhile to get the picture dialed in but it can you give a very good picture. The Netflix app works good but only outputs 2.0 sound instead of 5.1
Turboo2u is offline
post #1494 of 1496 Old 04-03-2015, 06:39 AM
HowieDoin's Avatar
I just wish Sharp would continue to support this model. There has not been a new firmware update since July 2012.
post #1495 of 1496 Old 01-05-2016, 12:51 PM
Research-Ken's Avatar
Black Screen with Audio...
Hello all,
I've had this TV for 2 to 3 years now and I'm just now having some issues with it. If anybody has had similar problems to what I'm going to describe, please let me know how you fixed them or if it's even possible.
I have 2 HDMI inputs going into the TV. 1 from my receiver, and the other from a Google Chromecast. When I turn on the TV, the screen remains black for both of the inputs... however, the audio is still playing. Initially I thought that the lamp must be dying, but the weird thing is, that all of the options/menu screen text and navigation is still showing up when I mess around with them on the remote. I can see everything as far as, the TV's interface, selecting apps, switching inputs, etc. I also am able to stream video over DLNA with no issue. The picture displays fine, so I'm not sure why the panel isn't displaying video over the HDMI input.
What makes this situation even weirder, is that when I power down the TV a few times and turn it on, it randomly displays the video after a while. I basically have to do this to get the picture to display via HDMI on this TV. Has anybody know why this could be happening? There's not flickering going on when I do get the picture to display, and the picture is fine over DLNA, so I really do not know what the issue is. I am on the latest firmware as well.
Thanks in advance,
Ken
Research-Ken is offline
post #1496 of 1496 Old 02-01-2016, 11:11 AM
tehhippy's Avatar
Had no issues with this TV until recently - we'll just be watching and it'll randomly turn-off. No lights on front, no warning. TV turns right back on and has no issues. Turned off power-saving / auto-off mode and hasn't fixed it. Any other ideas?
tehhippy is offline
Reply LCD Flat Panel Displays
