Sharp Aquos LC60E79U and Optical Audio Out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-29-2011, 04:28 PM - Thread Starter
jjmpeters's Avatar
Does anyone know if this set downmixes audio using the optical out connection? I want a simple audio solution for my father in law (who just bought this set on Saturday) so he can change components just by changing the input on the TV itself so I hoped to connect it to this soundbar:
http://www.vizio.com/vht510.html
From the review I saw on CNet it said that many HDTV's downmix audio to stereo when you use the optical connection.
Any help would be appreciated. Thx.
jjmpeters is offline
post #2 of 12 Old 11-29-2011, 06:54 PM
chrpai's Avatar
FWIW, I find that a good Logitech Harmony makes everything simple. Even my 8 y/o knows how to push the Help button and answer a few yes/no questions when things go wrong.
I use a Sony HT-CT150 sound bar with HDMI switching so I can't directly answer your question.
chrpai is offline
post #3 of 12 Old 11-29-2011, 09:00 PM
atomic dog's Avatar
Quoted: 14 Post(s)
I am sure it does as other Sharp models do. You would only get 2.1 sound from optical from inputs other than antenna (ie. hdmi etc.)
atomic dog is offline
post #4 of 12 Old 11-30-2011, 03:55 PM
Borghi's Avatar
Quoted: 30 Post(s)
You can set the optical out to stereo or multichannel in the "digital settings" on top menu
Borghi is offline
post #5 of 12 Old 12-13-2011, 06:24 PM
rpacf808's Avatar
Not sure if anyone else has this issue. When I go to digital setup on the top menu all I have is software update. I do not have the Audio setup selection
rpacf808 is offline
post #6 of 12 Old 12-14-2011, 08:52 AM
awestley1980's Avatar
That makes two of us. I have an Xbox 360 which excepts HDMI. How do I get 5.1 with the HDMI into the TV and the Optical from TV to receiver..
BTW... LOVE LOVE LOVE this TV!
awestley1980 is offline
post #7 of 12 Old 12-14-2011, 09:38 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Been discussed numerous times...
optical outputs (from most all TV's) will only output PCM stereo from externally connected devices. Only the internal TV tuner will output a Dolby Digital signal.
If using a soundbar, I wouldn't sweat whether it's Dolby Digital or not. Just set the soundbar for Dolby Pro-Logic. It will sound better than TV speakers.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #8 of 12 Old 12-14-2011, 11:55 AM
Steve S's Avatar
Liked: 46
+1 That soundbar will do a faux surround with 2 channel sources and it will sound significantly better than the tv alone. If you're really interested in getting true discrete 5.1 sound a soundbar, even one as fancy as that Vizio, isn't the answer anyway.
Steve S.
Steve S is offline
post #9 of 12 Old 12-15-2011, 07:56 AM
For the 360, which only has a hdmi port. How would I achieve DD5.1?
post #10 of 12 Old 08-06-2012, 03:06 PM
sawyerthecat's Avatar
Share support says
Only FIRST goto Input Select and select TV that will add to the menu pulldowns for Digital Setup - you will have an audio selection - otherwise
When you go to digital setup on the top menu all you have is software update. You do not have the Audio setup selection
The Audio selection is PCM or Dolby Digital - just like the manual states at that point
My old Integra 6.4 has a display button that reveals what the input signal is. When I flipped the PCM output from the Sharp the PCM display appropriately disappeared. All my issues haven't disappeared as hoped using the single optical out from the TV.
I have some more investigating to do. But at least whatever Sharp does is now available to investigate.
sawyerthecat is offline
post #11 of 12 Old 12-05-2013, 07:28 PM
Robert Sergent's Avatar
I have just received a similar Sharp TV (LC-70LE550U) and my sound bar is a Yamaha (YSP-2200) with 3 HDMI in and one out. I have a PS4, a cable box and a computer all with HDMI out. With the TV I had before, I would connect my 3 HDMI components to the TV and the digital audio out from the TV to the sound bar and that worked fine. Now it does not work. :(
Since I have so many inputs on the sound bar my next attempt should be to get my 3 HDMI components into the sound bar inputs and connect the sound bar HDMI output to the TV (and do away with the digital audio cable all together) right?
I'm missing one HDMI cable so that is why I'd rather ask before heading out to buy more cables.
Robert Sergent is offline
post #12 of 12 Old 12-07-2013, 01:01 PM
Well, That worked. I'm some glad I had a sound bar with 3 HDMI ins and one out though... All is good :)
Reply LCD Flat Panel Displays
