LED vs LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-08-2011, 05:09 AM - Thread Starter
vmalash's Avatar
Which one is better if it is 50" 3DTV? LCD or LED? Which display will last longer? Thanks, V.Malaszin... if you don't mind drop me an email please, vmalash@yahoo.co.uk
vmalash is offline
post #2 of 2 Old 12-08-2011, 06:26 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 780
This should be moved to the LCD forum (you posted in the Plasma forum), but an LED TV is still an LCD TV, it's just that the light source used to illuminate the LCD panel is a bunch of LED lights instead of the traditional CFL backlight. Almost all of the LED based LCDs are edge-lit which are cheaper to make, but they market them as if they're superior to a traditional CFL LCD TV. Edge lit does enable them to make a slimmer TV, but that also introduces adverse issues compared to a backlit CFL LCD. There are a few very high end LED LCD TVs that are LED Backlit (such as the Sony HX959 and Sharp Elite) but backlit LED TVs are very expensive.
Since you're in the UK, you're better off using the UK-based AVForums LCD forum - your TVs are very different than the American models discussed here....
http://www.avforums.com/forums/lcd-led-lcd-tvs/
Cheers
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Reply LCD Flat Panel Displays
