Refresh rate between Sony and Samsung - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-08-2011, 10:42 PM - Thread Starter
jyeh74's Avatar
I use to be a die hard fan of Sony XBR. But now since the Samsungs are more competitively priced, I am looking at Samsungs. Which is a better 65 inch TV below?
Can you compare the motionflow of Sony, who claims their 55 and 60 inch TVs are Motion flow 960 to the Samsung LED 7000 or 7050 series which are 720? Is that a apples to apples comparison?
What about contrast ratios?
Sony claims dynamic contrast ratio is INFINITE (what ever that means)
http://store.sony.com/webapp/wcs/sto...specifications
Samsung claims 25,000,000:1
http://www.samsung.com/us/video/tvs/UN65D8000XFXZA
jyeh74 is offline
post #2 of 8 Old 12-09-2011, 01:56 AM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
Comparing the two 65s, the Sony is definitely the superior set. That XBR is a full-array LED set with local dimming, the Samsung D8000 is edge-lit LED with ineffective pseudo-local dimming. As such it will have generally weaker black levels and more backlight distribution issues than the Sony.
As far as the motion handling, I don't think anybody really knows for sure what exactly Samsung's "Clear Motion Rate" numbers (480, 600, 720, 960 on the D8K) or Sony's MotionFlow ratings (XR240, XR480, XR960 on the HX929) are meant to represent. Neither company manufactures sets that have an actual refresh rate that exceeds 240Hz, but they're probably factoring in backlight scanning/strobing + black frame insertion systems to arrive at higher "perceived" refresh rates, hence the higher numbers...mostly marketing speak to pander to "spec sheet" buyers. Same for contrast ratio; the numbers mean nothing here.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is online now
post #3 of 8 Old 12-09-2011, 09:10 AM - Thread Starter
jyeh74's Avatar
how is this different? Its a lot cheaper and is same size and 3D. $1400 less than the XBR!!
http://www.crutchfield.com/p_15865HX....html?tp=35862
Is it last year's model?
They said the refresh rate of this is 480Hz (compared to the more expensive XBR which is 240Hz)
http://reviews.cnet.com/flat-panel-t...4532027-4.html
Must be a typo.
jyeh74 is offline
post #4 of 8 Old 12-09-2011, 12:41 PM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
The HX729 is a 2011 model. Look at the chart, the reason the 729 is cheaper is because it has a "dynamic edge LED backlight" while the xbrhx929 uses "full-array LED with local dimming." Not all LED sets are created equal. edge-lit sets are cheaper because they use fewer LEDS and cannot dynamically dim the backlight in indivdual zones depending on the content being displayed.
This article explains edge-lit vs backlit pretty well:
http://reviews.cnet.com/8301-33199_7...=featuredStory
post #5 of 8 Old 01-31-2012, 07:36 PM - Thread Starter
jyeh74's Avatar
I'm looking at the Samsung 60" UN60D7050VFXZA
Doesn't say if it is full array LED or edge-lit LED?
jyeh74 is offline
post #6 of 8 Old 01-31-2012, 10:36 PM
texasrattler's Avatar
ALL Samsungs are edge-lit. I have yet to see anything else by them in awhile. Its more cost effective to make edge-lit tv for Samsung than anything else.
They did have local dimming sets a year or 2 ago but all that is done for.
texasrattler is offline
post #7 of 8 Old 01-31-2012, 10:45 PM
From my understanding Clear Motion Rate and Motionflow DO NOT increase the refresh rate but it takes the hertz, resolution and other things into account to give you a better overall picture quality. Thats all it does. Does it really make a difference, maybe.
post #8 of 8 Old 01-31-2012, 10:46 PM
audio/videoman's Avatar
Check 'em out on the showroom floor. Get the remotes and adjust the picture settings to your liking. Watch. Compare. Report back.
audio/videoman is offline
Reply LCD Flat Panel Displays
