Official 4:4:4 / Chroma Subsampling Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #451 of 559 Old 05-29-2015, 09:30 AM
RLBURNSIDE's Avatar
Quoted: 1539 Post(s)
Liked: 1217
If you think a 1080p TV showing a UHD Bluray is going to be sharper, you are seriously deluding yourself.
It is in fact you who has no idea how the eye works.
http://hyperphysics.phy-astr.gsu.edu...n/rodcone.html
"Current understanding is that the 6 to 7 million cones can be divided into "red" cones (64%), "green" cones (32%), and "blue" cones (2%) based on measured response curves. They provide the eye's color sensitivity. The green and red cones are concentrated in the fovea centralis . The "blue" cones have the highest sensitivity and are mostly found outside the fovea, leading to some distinctions in the eye's blue perception."
"The rods are the most numerous of the photoreceptors, some 120 million, and are the more sensitive than the cones. However, they are not sensitive to color. They are responsible for our dark-adapted, or scotopic, vision. The rods are incredibly efficient photoreceptors. More than one thousand times as sensitive as the cones, they can reportedly be triggered by individual photons under optimal conditions."
So, 7 million Cones = color sensitive vs 120 million Rods.
There are SEVENTEEN TIMES the number of luma-sensitive receptors than chroma-sensitive ones. And EACH rod is in itself FAR more sensitive to light than each cone is. Do the math.
This is why chroma subsampling works well and is based on sound science.
444 is foolish for anything except windows desktop.
Increasing the luma resolution from 1080p to 2160p is going to increase perceptual detail FAR more than increasing chroma resolution from 540p to 1080p.
I'm not going to debate this further, the science is not on your side. The industry is not on your side. Facts are not on your side, and neither is the marketplace for televisions, or the games industry.
The games industry is going to embrace HDR and wide color in a major way in the coming years, and they will have to do it through HDMI 2.0 since the chance of most TVs getting DisplayPort 1.3 is very low. And doing HDR through HDMI 2.0 is going to require dropping to 422 chroma subsampling to allow 12 bits to fit into 18gbps. That is just a fact. Yes, it would have very slightly better quality at 444, 12-bits, but you are going to have to choose.
You're entitled to play games forever on an 8 bit 1080p TV. Meanwhile, people are going to be jumping on HDR and wanting to take advantage of all the resolution UHD has to offer as well. And that means chroma subsampling.
HDR boosts sharpness in a major way for the EXACT same reason as above, because it takes advantage of not only the greater dynamic range of our rods, but the resolution and sensitivity advantage we have in luma detail due to the fact that we have 17 times as many of them.
Say it with me. 17 times more rods than cones. Let the truth sink in. Science. 'Nuff said.
RLBURNSIDE is offline
post #452 of 559 Old 05-29-2015, 09:54 AM
Quoted: 349 Post(s)
Liked: 59
I don't think you're understanding me, how many times do I have to repeat myself.
When you move closer to an object, the size increases.
It takes more space in your vision.
Our 20/20 vision is limited to a certain amount of space
It just so happens the 1080p-1440p spectrum fits perfectly in that space
4k is going outside the boundaries of our vision, and since it is flat and none of the content is properly adjusting the field of view.
The overall resolution is much lower, because the once 1080p image is now stretching beyond the ideal view.
So what happens? Playing video games with collectibles becomes difficult, because your overall vision is worse, you'll tend to miss a lot of details that you could see plainly before.
But wait there's more to it.
4k content is unlikely going to change at all, because if they change the angle it is effectively changing the aspect ratio making it incompatible with older displays which shortens the market.
The only hope to fix this issue is Oculus Rift, because it requires extensive field of view changes; once this implemented games will provide a field of view option which will make the 4k experience significantly better that blows 1080p out of the water.
Does this make sense?
You can't compare chroma subsampling on videos to videogames, chroma subsampling is much more noticable in rendered graphics particularly in anti aliasing; the difference isn't that noticeable at 4k because of the field of view issues, your own mind is blurring the differences in the peripheral vision.
Chase Payne is offline
post #453 of 559 Old 05-29-2015, 12:26 PM
NintendoManiac64's Avatar
Quoted: 848 Post(s)
Liked: 337
Originally Posted by Chase Payne View Post
I would just buy cards with the power vs dollar ratio, like the 970's give you the most graphic power for your money; much more than the other cards have in the past.
But then you have to deal with the silly 3.5/0.5GB memory partition thing.
NintendoManiac64 is offline
post #454 of 559 Old 05-29-2015, 07:19 PM
Quoted: 349 Post(s)
Liked: 59
Even then, it is still the best card you can gt with your money right now. It has the highest dollar for power ratio, I have 2 of them and have been very satisfied with it.
post #455 of 559 Old 05-29-2015, 09:01 PM
Quoted: 848 Post(s)
Liked: 337
Ehhh, SLI 970s for 4k is one of the main cases where the 3.5/0.5GB partition silliness can cause issues, so personally I'd still be very hesitant with that set-up for such a use-case.
post #456 of 559 Old 05-31-2015, 02:24 PM
Quoted: 349 Post(s)
Liked: 59
Never really had much of a problem, just make sure you're not using the last 500mb of memory. SLI isn't even using the full potential of memory anyway. When Direct X 12 comes out to mainstream, it will use the memory of both cards instead of just duplicating the load. Considering most games can run with less than 4GB of memory even at 4k on medium-high settings, this won't be an issue at all.
post #457 of 559 Old 06-20-2015, 09:20 PM
Squishy Tia's Avatar
Quoted: 14 Post(s)
Video games on computer @4k are directly rendered without any chroma subsampling, assuming the TV is in PC mode or whatever mode is required to defeat CS. Depending on the allowable texture size, your VRAM, and system RAM, you can get more detail out of 4k than you can in 1080p. Whether or not you can sustain good framerates is not part of the discussion and has no impact on the actual visible content. You'll often find small objects easier to pick out on 4k than 1080p unless you're nearsighted because they tend to have better contrast and/or are separated from the background and surrounding objects more clearly.
@RLBURNSIDE : For computer use, you definitely want to be able to defeat chroma subsampling. All you have to do is visit this page and check the last two lines in the first major image to see what I mean. The text will be very easy to read with CS disabled vs. CS enabled. In fact, CS will actually cause blurring on computer generated images that render in 4:4:4:4/8:8:8:8 colorspace. I can easily see the difference with forum text and in-game chat text by hitting a keyboard shortcut that changes my resolution from 1080p60 to 1080p24. At 1080p60 the TV is in PC Mode, and CS is disabled, thus text is very easy to read. In 1080p24 PC Mode is disabled and the TV's processing (and CS) are enabled and cannot be defeated even in Game Mode. Same image, same resolution, but chroma subsampling is the only difference, and BAM, unreadable text because everything is blurred. You get color bleed like crazy with CS enabled.
both of you: Sitting at the proper distance from any resolution display (1080p, 1440p, 2160p) such that you have at least a 53 PPD (pixel per degree) separation will give you the proper FoV for that resolution. That is why you have to sit further back at 1080p vs. 2160p to not notice individual pixels - the fewer pixels there are in any given space, assuming equal screen sizes, the easier it is to see differences. For current content, 4k simply makes it so that individual pixels are less easily discerned. For computer use, more detail can be implemented at 4k than 1080p, but that's because it is being directly rendered by the GPU, not upscaled like 1080p content would be on the same 4k TV. However, at proper ≥53 PPD viewing distance, 4k will appear sharper at equal screen sizes because you can't see individual pixels easily or at all.
If you don't use your TV as a computer display, CS won't matter much, if at all. But if you do, it's definitely going to affect far more than just the "windows desktop".
Edit: Because the "at" symbol is forcibly recognized as "mention" and screws up poster references. Bleh.
dandiego and NintendoManiac64 like this.
When a Priest says they're going to Flash you, it isn't for healing.
Squishy Tia is offline
post #458 of 559 Old 06-21-2015, 09:52 AM
RLBURNSIDE's Avatar
Liked: 1217
Ok let me clear up a few things.
I always maintained that you can tell chroma subsampling is being used for 1-pixel wide text and lines. This fact is not in dispute.
If you go back and read what I wrote, I said that when I was looking for a UHD TV to use as a PC monitor, that I wouldn't get one without 4:4:4 at 60hz.
HOWEVER, games and such do NOT render aliased 1-pixel wide text and lines, especially not at UHD resolutions like your windows desktop. The main text-heavy games like MMOs have scaled, antialiased text which, at UHD at least, probably are > 3 pixels wide at least, in order to be visible at a normal seating distance, meaning the chroma "bleed" is at most 25%, and even that is "antialiased" if you enable edge sharpening on your TV.
Tia, in your own post you even state that at UHD the increased resolution makes it so that if don't sit closer, you have 4x less pixel visibility, meaning if your chroma bleed is under 1/4 of what it would be at 1080p 420 vs 444. Yes, it's visible, but you have to get FOUR TIMES closer.
You guys and gals can stick to 444 all you want at UHD, but that means you are giving up 10-bit color which means no HDR, and no WCG for you.
You cannot tell the difference with chroma subsampling being used in anything but 1-pixel wide, high contrast content like text or lines, or unless you're walking right up next to your TV. The resolution charts that inform you about what your visual acuity are in terms of resolution refer to the luma resolution, not the chroma. The chroma resolution you are much less sensitive to, and that's a fact. You are entitled to your own opinions but not your own facts.
If you are sitting at a sufficient distance from your screen that you can't see the pixels, then you definitely can't see the color bleed from chroma subsampling at that same distance. Again, because of the science I cited, you have 120 million rods and 7 million cones, therefore 17 times the static resolution in luma information than chroma, and that's being generous because minute changes to chroma in absolute magnitude, not just resolution, make it even worse for chroma compared to luma.
Going up from a 1080p to a UHD TV means that chroma subsampling in practice becomes 4x less the non-issue it already is, for games that is.
Most (not all) Games do not use 1-pixel wide text, and if you're talking about an MMO with lots of scrolling text, then it's probably worth it to you to give up 10-bits for 444 (for HDMI 2.0 TVs you can't have both, you have to choose), but you can easily get around that by simply increasing your font size slightly and turning up edge enhancement. Giving up HDR and WCG for 444 is foolish if you ask me.
If you are asserting that you can tell the difference between chroma subsampling ON/OFF in a moving game scene, I will call BS on that, you can't. Period. No way.
First off, most LCD TVs have poor motion resolution, around 600 lines or so, even with BFI enabled. Forget about UHD, most LCDs can't even do FHD properly when frames are in motion, especially not at 60hz. 120hz would be a big improvement in sharpness and clarity during motion. Even then, you couldn't tell if chroma was being used.
Next, even on static frames, with decent upscaling chroma filters and a high enough resolution, I bet you any money that can't double-blind which is better, especially not at UHD.
The human visual acuity is simply not there. Your assertion is as baseless and unfounded as the idea that people can hear above 20khz or tell the difference between 16 bit or 24 bit audio in a double-blind test. If you're doing color correction and zooming in real close and editing per pixel, then yes, it matters. For lossy compression? Not so much. Sure, it would be better that they used JPEG instead of chroma subsampling for compression, but they didn't go that way.
At UHD how close do you have to sit to see individual pixels? If you aren't sitting that close, you CANNOT tell that chroma is used. Because if you don't have the visual acuity to tell 1 pixel from its neighbour, in LUMINANCE, then you definitely cannot tell the difference in chroma.
I make games for a living, and let me tell you, the era of static UIs with 1-pixel wide content and unscaled, non-antialised text is behind us. UIs are going in-game now, rendered just like the rest of the scene. We've done tests internally and using 422 YCoCg compact frame buffer people can't tell that chroma subsampling is used.
Anyway, you guys and gals do what you want. If you want to buy a TV with HDMI 2.0 on it that has HDR and WCG, and not use those features because you think 422 chroma subsampling being used to get 10-bits to your TV is the bane of your existence (it's not, scientifically speaking), then you are free to do that.
Meanwhile, all your HDMI 2 cards and TVs are subject to this bandwidth limitation. 8-bit color SUCKS for games. It's got tons of banding and other horrible artifacts, the worst of which is the fact that you need to quantize a fully HDR pipeline into 8-bit LDR through tone mapping unless your TV supports 10-bits in which case you can leave the firehose of beautiful dynamics open.
Trust me, when you see HDR in Unreal IV, you are going to eat your words. Currently the only way to get that to a UHD TV is to use 422 chroma subsampling, and that's a fact. Not using HDR because it requires subsampling is like racing your honda civic at Grand Prix because it has better mileage when you drive to the corner store. Different speeds, different needs.
Yes, desktop use should use 444, but games? Heck no. We already don't render many internal buffers at full resolution. That's what you're not getting. There is TONS of compromise being used all the time in rendering engines to keep things running fast.
post #459 of 559 Old 06-21-2015, 02:16 PM
Quoted: 848 Post(s)
Liked: 337
There are 10bit 4k monitors... with the standard reduced timings (full timings are only needed for CRTs), at least DisplayPort 1.2 has enough bandwidth to do this with 4:4:4 chroma at 60hz.
post #460 of 559 Old 06-21-2015, 02:43 PM
RLBURNSIDE's Avatar
Liked: 1217
Oh yeah, for sure. If you can get a TV with a Displayport, that's a smart move for PC use. Unfortunately that's not on the menu for most TVs in 2015.
DisplayPort 1.3 would be a great thing to have un a UHD TV that would do 120hz and 12 bit color and HDR and Freesync, all at 4:4:4. I just think it's absurd give up HDR and wide color gamut for 444 in a game, it's a dumb thing to do. The numerous 10-bit offers would massively outweigh the negatives of 422 vs 444.
I collected some PNG lossless screenshots at 2560x1440 of various games and wallpapers, including some that are super high detail and others that are more natural looking, and used GIMP to export it to 422 and 420 to compare.
The only time I could see the difference between original (RGB / 444) and 420 is when I put my eye closer than 6 inches to my LCD monitor. And that's on an image with super fine detail and no AA, like a worst case scenario. I'm using an ACER 1440p G-sync and yes, once you look really really close, 420 does lose sharpness. But, on more natural outside scenes there was no perceptible difference. I defy people to be able to tell any at UHD, even on static images, except for the very worst case scenario and only from very, very close up to the screen.
However, chroma subsampling actually looks like FXAA to me, or maybe TXAA. Some people don't like any AA, but that's foolish. Fine edge detail in games is more likely from aliasing than from any discernible or important high-frequency detail. The best I would describe 420 is like a very mild full scene antialiasing which is totally free. Not like, costs only 1ms, I mean 0ms extra cost since the TV does the upscaling and filtering.
At UHD resolution, you can probably even sit closer than I am to my monitor and not see the difference.
It's all about DPI at that point. But most of the detail that your eyes see is from high contrast changes in luminance information, that's why FXAA operates only on luma (at least in the compute shaders that I've seen recently that do FXAA quite well and cheaply). Although to be fair, 420 subsampling is indeed probably closer to TXAA of Unreal IV. I think it would the height of ridiculousness to even attempt to rationalize the need for hard 1-pixel edges in a game that uses any kind of edge AA. In between edges where there are no glaring luminance gradients, you definitely can't tell that chroma is being subsampled, even very close up. So we're only talking about high-contrast, edge detail. Detail which is probably already antialiased since it's rare for lines to be perfectly vertical or horizontal in a game, in anything but menu items which are probably not 1-pixel wide anyway.
I'd like to write up a script to spider google images for 1440p and UHD Pngs and auto-generate 422 and 420 versions of those, and flip the originals vs the subsampled versions (still losslessly encoded in the end, at the same final resolution), and get people to swipe left or right if they think there's subsampling going on. I bet you that people can't reliably tell the difference, and even that many people would prefer the subsampled versions.
During moving scenes though, there is ZERO chance that chroma subsampling is detectable by the human vision at UHD resolution, even from up close. There is just no way. Probably not even at FHD either. Static images of real game scenes do exhibit some loss of high-control very fine detail, but it's minor and totally undetectable after you are 12+ inches from the monitor or in more natural scenes involving AA already.
Any time you have AA operating on your pixels, you are blurring the edges. Edges are where high contrast details are visible, hence MSAA and FXAA focusing on the edges of geometry or in the final raster image. 420 to me looks like a form of TXAA. Lots of people don't like it. Anyway, it's up to the TVs now.
But 422 + 10 bit WCG + HDR is going to look insanely better than 8-bit SDR. Anyone arguing against that has not seen Unreal IV with Dolby Vision demo. It is STUNNING. That's why I stand by my assertion : if you want a good TV, get one with HDR and 444, but when HDR is available in-game, lose the 444 and pick HDR instead.
post #461 of 559 Old 06-26-2015, 12:14 AM
AgentHEX's Avatar
This is irrelevant because the center part that does most of the seeing (ie not peripheral vision) has high cone density. Also, human eye resolution is limited by diffraction limit posed by the pupils, not # of "sensors".
This is true in general for both resolution and color. The visual system (notice I don't say "eye") tends to work at a higher level anyway, and even for the pixel peepers more sensitive to source problems like encoding or various other artifacts.
AgentHEX is offline
post #462 of 559 Old 06-26-2015, 12:19 AM
AgentHEX's Avatar
BTW, are the current samsungs and maybe LGs still the main feasible desktop monitor replacements (ie 40-50 sizes, 444/full color)? I was looking at the JU6700 model but the low PWM backlight freq. gives me pause for someone who is going to spend a lot of time in front of it.
AgentHEX is offline
post #463 of 559 Old 07-08-2015, 01:10 PM
Quoted: 97 Post(s)
Quick question about chroma 4:4:4 at 60hz. Does it work at 1080p resolution? How about when a TV upscales to 4k any singal you give it? Do you lose the 4:4:4 at 60? Or does 4:4:4 at 60 only work with native 4k sources?
negru08 is offline
post #464 of 559 Old 07-08-2015, 01:59 PM
AgentHEX's Avatar
If the reason why 444 4k isn't supported is due to connection bandwidth, then 444 1080p can work. But the TV can still drop to 422 for internal processing so there's no way to determine with certainty beforehand. Many 1080p TVs do not work with 444 despite sufficient bandwidth so it could go either way.
AgentHEX is offline
post #465 of 559 Old 07-23-2015, 10:12 AM
AndrewK1's Avatar
Hey guys.
I just picked up a 48JS9000, and am having troubles getting 3840x2160 @ 60hz 4:4:4. 4:4:4 works fine at 30hz, and is viewable in the nvidia CP, but as soon as I bump up to 60hz, the options disappear and it switches to 4:2. Would there be a way to force this via EDID?
A few things I've tested:
- UHD color enabled/disabled
- Several different HDMI cables (all high speed)
- HDMI out, DP -> HDMI adapter out, DVI -> HDMI adapter out
- All HDMI ports on the OneConnect box (including HDMI/DVI)
- All Input Types on all HDMI ports, including DVI PC, PC, Game, etc.
- Several different nVidia drivers (350.12, 353.30, etc.)
- JS9000 firmware up to date
My rig has 3x780 classified's, and I've tested on my work laptop (HP Zbook 15 with a Quadro K1100M) with similar results every time - despite that card being able to theoretically push 4k @ 60hz 4:4:4 as well.
Any ideas?
AndrewK1 is offline
post #466 of 559 Old 07-23-2015, 11:21 AM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
@AndrewK1 it looks like the 780 is limited to HDMI 1.4 which means 420 is the max.
Sent from nowhere
Ph8te is online now
post #467 of 559 Old 07-23-2015, 11:46 AM
AndrewK1's Avatar
Sent from nowhere
It also has DP1.2 and DL-DVI, both of which should be able to put out 4:4:4 at 60hz. Users with 9xx series cards are also having similar issues, leading me to believe it's a driver issue. Is there a way to force it to attempt 4:4:4 with a EDID profile?
AndrewK1 is offline
post #468 of 559 Old 07-23-2015, 12:00 PM
Ph8te's Avatar
Liked: 3972
Unless your TV supports those then I believe you are SOL. I haven't seen any solutions that do DP or DVI to HDMI to successfully get 444 as you want it. While your card "may" do 444 over those connections the problem you'll have is getting the TV to recognize that.
Sent from nowhere
Ph8te is online now
post #469 of 559 Old 07-23-2015, 12:06 PM
AndrewK1's Avatar
Why would the TV recognize it at 30hz but not 60? It still doesn't look like a problem at the TV end, rather I just lose the options within the drivers.
AndrewK1 is offline
post #470 of 559 Old 07-23-2015, 12:14 PM
Ph8te's Avatar
Liked: 3972
HDMI 1.4 can do 4k@30 444, that is why. It can't do 4k@60 444, it is limited to 420 when displaying that resolution.
I know there are better links for detailed information this is just the quick and dirty one:
http://www.planar.com/blog/2014/12/8...i-20-standard/
Sent from nowhere
Ph8te is online now
post #471 of 559 Old 09-05-2015, 03:35 PM
Liked: 0
What about TV's that can do both.
Yes on 18 Gbps bandwidth you need to choose between HDR or 4:4:4, but won't it be better to buy a TV like JS9500/9000 which offers you the choice between HDR and 4:4:4, than making your choice at the start by buying a TV which can only do one of those things.
I understand that HDR could be more beneficial than 4:4:4 but what if you play games at 1440p coz your graphic card can't push 60fps on 4K.
Shubham Deshpande is offline
post #472 of 559 Old 09-05-2015, 03:39 PM
AgentHEX's Avatar
There's no actual HDR content anyway.
AgentHEX is offline
post #473 of 559 Old 09-06-2015, 02:19 AM
Quoted: 848 Post(s)
Liked: 337
And 4:4:4 is mainly important for PCs, and PCs are already planning on moving to DisplayPort 1.3 (read: enough bandwidth for 120hz 4k or 60hz 8k @ 4:2:0)
post #474 of 559 Old 09-06-2015, 08:19 AM
mboojigga's Avatar
Quoted: 588 Post(s)
Liked: 822
i average about 140fps now with Elite dangerous on one 980Ti card at 4k max settings on a "65 on HDMI.
The 5.0 is here
mboojigga is online now
post #475 of 559 Old 09-06-2015, 10:45 AM
RLBURNSIDE's Avatar
Liked: 1217
Of course, DP 1.3 is going to be a big advantage for PC use. Heck, even DP 1.2a would allow 10-bit (HDR or not) 444 at UHD 60, plus Adaptive Sync / Freesync which at UHD is something you really need to maintain smoothness, while we're talking about PC gaming of course, for which almost all modern video cards have DP 1.2a.
The big, big hope for me (and some other devs I've spoken to), is DP 1.2a / 1.3 over USB-C 3.1 becoming the norm on TVs, like MHL is now. Then we can potentially live in a world where you can have your cake (UHD 120hz + 12 bit HDR in RGB) and have it too (HDCP 2.2, 32 channel audio, Freesync) over a single connector that is already ubiquitous, just not to televisions yet. I mean, plenty of TVs have USB ports already but not for video signals. The second you can send Freesync signals over USB-C is the second it stands a chance of VRR actually taking off on TVs.
For now, the situation with 444 vs 10-bit (422) for PC use is mostly going to matter for 10-bit input accepting TVs, of which there are many.
As I said before, if you are a PC gamer and put on a fullscreen game, and you select 10-bit color (or set 10-bit 422 in windows 10 then play in fullscreen borderless), then you should see some improvement in banding, at least. Banding is horrible, terrible, shameful, and needs to die. We fight against it all the time.
post #476 of 559 Old 09-06-2015, 10:54 AM
RLBURNSIDE's Avatar
Liked: 1217
Btw, the new Sony 4K TVs have a special 120hz UHD mode that uses 420 chroma subsampling over HDMI 2. Ask me if I'd use it? Heck yeah. 2x framerate >>>>> slight blur at edges of high-contrast scenes. If anything, it's like a free fullscreen edge-antialiasing effect.
I hope Sony have the brains to realize that over 18gbps you could also similarly squeeze in 10-bits 96hz at 420 UHD, or 12-bits native at 80hz. That would be really something, imagine 96hz HDR + WCG over HDMI 2.0a. Sick, sick, sick.
One day people are going to look at standard dynamic range TVs and monitors and say, yuck, how did we ever live with such dim / fugly / tame / washed out images.
mboojigga likes this.
post #477 of 559 Old 09-09-2015, 09:14 PM
PC_
Liked: 1
is there an updated list? the list in post 2 seems a bit dated.
PC_ is offline
post #478 of 559 Old 09-09-2015, 09:28 PM
RLBURNSIDE's Avatar
Liked: 1217
There are also DP 1.2a -> HDMI 2.0 adapters that just came out. It's amazing, even the brand new AMD cards don't even have HDMI 2.0 outputs on them. For shame.
I think for UHD Bluray playback from the PC you'll need a new card with proper HDMI 2.0 or DP 1.3 outputs though. And not even AMD has DP 1.3 outputs yet. Again, for shame. They do a few things right, then turn around and stick their foot in it. Like wtf are they thinking releasing 700 dollar videocards in september 2015 that don't have HDMI 2.0 chips on them. Ridiculous.
post #479 of 559 Old 09-09-2015, 09:30 PM
Quoted: 848 Post(s)
Liked: 337
Well consider that even Intel's Broadwell and Skylake don't support HDMI 2.0...
I think Nvidia just pulled as many strings as possible to make it happen while AMD and Intel didn't see it as priority.
post #480 of 559 Old 09-09-2015, 09:50 PM
RLBURNSIDE's Avatar
Liked: 1217
And that's why I own a GTX 970. And probably also why NVidia has 75% market share. I used to always prefer AMD cards and actually endorse AMD's corporate culture (open standards compliance) better, but aside from them supporting async compute better than Maxwell cards, everything else is a net negative from my perspective. It's a wash in some ways, but I mean, I can't in my right mind justify or rationalize buying a card that has 10 year old output chips incapable of driving the latest TVs acceptably. It's complete and total fail. They could have paid the HDMI licensing or additional cost to get the 18gbp chips on the Fury cards but some corporate nitwit pointy haired guy probably screwed up. The big problem a lot of these companies have is that their middle management is run by people who are not really enthusiasts themselves, so they figure, "hey, what PC gamers want to play on anything but a monitor, like, say one of these fancy new UHD Televisions? Nobody I know, I play angry birds at home in between changing diapers"
Somebody screwed up, it's the only explanation. There is no reason that a 500+ dollar card shouldn't have it. I've had my GTX 970 for a long time now, I was waiting to see which company would come out with HDMI 2.0 cards first...then when AMD came out with Fury X without it I was very glad that I didn't wait.
Reply LCD Flat Panel Displays
Lcd Hdtv
