Official 4:4:4 / Chroma Subsampling Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #91 of 582 Old 01-12-2012, 06:15 AM
WiFi-Spy's Avatar
Quoted: 521 Post(s)
Liked: 966
Panasonic is touting this on the 2012 VT50,GT50 series plasmas.
Attachment 233889
Tyler Pruitt - Technical Liaison - CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #92 of 582 Old 01-12-2012, 08:18 AM
pete4's Avatar
I don't see this, but I see this quote from article:
"If you choose to output 4:2:2 from your player to the display, then the display will need to do the scaling to 4:4:4 and then to RGB. If you output 4:4:4 to the display, the display will not need to do any scaling at all, but will need to do the conversion to RGB. If you output RGB to the display, then the display can avoid all conversion steps and send the signal right to the controller. No matter which you choose, the same conversion steps are still happening; all you are choosing is which device is performing the conversion."
which IMO would contradict your statement bellow.
Of course we do know for the fact, that a lot of TV's subsample signal to 422 and all I want to know is why and how to fix it. If it's hardware limitation, we kind of out of luck, if it's some software issue - to speed up calculations for frame interpolation in 120Hz TV's for example - I would gladly get rid of frame interpolation and all this 120Hz nonsense to get true full RGB pass through from computer.
Originally Posted by WiFi-Spy View Post
Relevant article by Stacy Spears and Don Munsil:
http://spearsandmunsil.com/articles/...olorspace.html
Most video processors in TVs convert everything to 4:2:2 YCbCr internally before they do any scaling/processing.
pete4 is offline
post #93 of 582 Old 01-12-2012, 11:51 AM
knutinh's Avatar
Originally Posted by Lessen View Post
You should use YCbCr output for Blu-ray and DVD; the encoded video is in YCbCr and a conversion to 8-bit RGB is slightly lossy. Better to let your TV do said conversion in its processing pipeline especially if it converts back to YCbCr internally.
A 8-bit native sRGB signal has a significant loss upon conversion to 8-bit 4:4:4 YCbCr (luma codes are preserved, however many of the chroma codes end up not being used.). I dont believe that conversion back again has this same issue.
-k
knutinh is offline
post #94 of 582 Old 01-12-2012, 12:56 PM
k9wazere's Avatar
Great thread!
Here are my results for the Samsung LE32D550. That's the European (UK) LE model. Turns out it's totally different to the LN (US) model.
Sadly, it does not pass 4:4:4. Using an nV card, I even applied the EDID override fix, and I'm using the correct HDMI port (labelled DVI/HDMI).
Unlike the US model, there is no "input" section in the TV's menu.
In this first pic, notice that underneath the red tick, to the right of the vertical black line, there are blue subpixels turned on.
You can quite clearly see between the exclamation marks that the colour is not the correct background colour (grey).
Fortunately for me, this TV has 3 dead pixels in the centre. I will be returning this one for a refund.
Lastly, it is insanely hard to find a 4:4:4 TV in the UK. Insanely hard!
k9wazere is offline
post #95 of 582 Old 01-12-2012, 01:56 PM
k9wazere's Avatar
And the modified Belle-Nuit:
k9wazere is offline
post #96 of 582 Old 01-14-2012, 09:23 PM
Ryzir's Avatar
I've picked up a Samsung 32LND550 (SQ04) and I can't seem to get 4:4:4 working.
I'm using a DVI to HDMI cable out of an ATI 6950 into the HDMI-1 (DVI) port and re-labeled it as DVI PC (tried PC also, appears to be the same). I've tried both EDID Override fixes. Here are some pics (Link) (Link)
If I turn the HDMI Black Level to Low it passes the Belle-nuit chart (Link) however text still looks bad. I believe turning the Black Level to Low just crushes all detail in dark areas. If you notice the pixels around the 20 you can only see the green subpixel. Shouldn't you be able to see all 3?
Ryzir is offline
post #97 of 582 Old 01-15-2012, 12:05 PM
52LG60FTW's Avatar
Quoted: 109 Post(s)
Liked: 43
S-IPS version. I'm using a DVI to HDMI cable + EDID override fix. [IMG] Uploaded with ImageShack.us[/IMG]
52LG60FTW is offline
post #98 of 582 Old 01-15-2012, 12:06 PM
52LG60FTW's Avatar
Quoted: 109 Post(s)
Liked: 43
S-IPS version. DVI to HDMI cable + EDID override fix. Used my smartphone to capture image.
post #99 of 582 Old 01-15-2012, 01:36 PM
sjetski71's Avatar
I PM'd AVS member Antipodes, he seems to know the Samsung D550 really well, and he also happens to own the LG LK450. Hopefully he can offer some clues or insight.
I'm also going to link the extended info you posted at the [H]ard forums in case anyone else is willing to dissect the problem you're having.
sjetski71 is offline
post #100 of 582 Old 01-26-2012, 05:47 AM
Impaque's Avatar
Originally Posted by thepoohcontinuum View Post
T6) I want to use a HDMI->HDMI cable (because I want HDMI audio), can I still get 4:4:4?
From my experience and observations, the answer is no. As mentioned previously, *something* relating to HDMI audio extensions causes 4:4:4 to fail. Only by disabling the HDMI audio extensions (via a DVI->HDMI cable and/or EDID Override) will 4:4:4 become enabled. I have yet to encounter someone that has 4:4:4 working over a HDMI->HDMI (w/ HDMI audio) connection.
I can confirm this.
On my LG 42LK450 and ATI R6870, first I tried using HDMI->HDMI cable.
ATI CCC itself offers 4:4:4 subsampling, but it doesn't work.
Then I tried disabling EDID extensions. ATI CCC detected the TV as a regular monitor, but the picture was still 4:2:2.
Then I used a single-link DVI->HDMI cable and it worked instantly.
PS: Previously, with HDMI->HDMI cable, "PC mode" did 4:4:4, but the sharpness and other controls were disabled on the TV.
With DVI->HDMI I get 4:4:4 on every mode.
Impaque is offline
post #101 of 582 Old 01-30-2012, 12:04 AM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
Just to chime in, the Sony KDL55BX520 does 4:4:4 over HDMI using Game or Graphics "Scene" modes. Verified with the test images.
Also supports HDMI audio at the same time as well.
Using this TV with my Mac Mini, which is connected to my Yamaha Receiver (HDMI to HDMI) which is then connected to my TV.
Getting 5.1 audio through VLC and PC games.
Cheers!
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #102 of 582 Old 02-02-2012, 11:17 PM
Racer_J's Avatar
I've made an extensive amount of posts recently over at [H]ard|Forum about the iSymphony LC32iF90 but, I wanted to share a condensed version here. Please make sure to add it to the avoid at all cost list.
I recently picked this TV up from Conn's for $279.99. Unfortunately, once I hooked it up to multiple PCs, I found out the native resolution is 1280x720p. This is in direct conflict with the box and specifications that the native resolution is 1920x1080p. Yes, it's true that you can tell Windows or the video card driver to change the resolution to 1920x1080p. However, you shouldn't have to do so and, any resolution over 1280x720p will force the TV to overscan which will cut off a great deal of the picture including your entire taskbar. The only way to correct the overscan is to use your graphics card's underscan feature which will result in it running at a lower resolution than 1920x1080p or whatever you set it to. There is no option in the TV settings to switch to a 1:1 pixel mapping as you can only change the TV to "wide (16:9) or "normal" (4:3).
In addition to this, text on the PC was multicoloured in any progressive scan resolution higher than 1280x720p. All interlaced resolutions above 1280x720p removed the multicoloured text issue but, they created a flicker when you would open/close programs or use a scroll bar. This TV also failed 4:4:4 chroma colour tests. It's not advertised as having 4:4:4 chroma but, it is crucial that a display being used as a PC monitor is able to run in the 4:4:4 chroma profile.
All of these problems existed over VGA to VGA (this will not go higher than 1280x720p), DVI to VGA, DVI to HDMI, and HDMI to HDMI signals. I tired multiple solutions and researched this issue extensively over the short period that I owned this TV. This is not an issue with the video card driver nor is it an issue with the monitor driver Windows installs as I tried multiple custom drivers and edits to them. It is an issue with the EDID which is contained inside the TV's hardware which broadcasts all the hardware information to your operating system. It states the following:
Monitor Asset Manager Report, generated 2/2/2012
Copyright (c) 1995-2011, EnTech Taiwan.
Monitor #1 [Real-time 0x0041]
Model name............... MTC26T42
Manufacturer............. Mitac
Plug and Play ID......... MTC0B01
Serial number............ 1001
Manufacture date......... 2008, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 700 x 390 mm (31.5 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.652 - Ry 0.333
Green chromaticity....... Gx 0.275 - Gy 0.595
Blue chromaticity........ Bx 0.143 - By 0.063
White point (default).... Wx 0.285 - Wy 0.293
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 14-91kHz
Vertical scan range...... 22-80Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.030 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #3....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #4....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #5....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 205MHz
Report information
Date generated........... 2/2/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0041
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,36,83,01,0B,E9,03,00,00,01,12,01,03, 80,46,27,78,0A,19,90,A7,55,46,98,24,
10,49,4B,01,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,C4,8E,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, C4,8E,21,00,00,9E,00,00,00,FC,00,4D,
54,43,32,36,54,34,32,0A,20,20,20,20,00,00,00,FD,00,16,50,0E, 5B,10,00,0A,20,20,20,20,20,20,01,9A,
02,03,22,72,4D,03,84,05,07,10,12,93,14,16,1F,20,21,22,23,09, 7F,07,83,01,00,00,67,03,0C,00,10,00,
98,29,8F,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18, 01,1D,00,BC,52,D0,1E,20,B8,28,55,40,
C4,8E,21,00,00,1E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E, 21,00,00,9E,8C,0A,D0,90,20,40,31,20,
0C,40,55,00,C4,8E,21,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E, 96,00,C4,8E,21,00,00,18,00,00,00,37
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI000 18.PCI0001C
00000000 = 01048086.20900006.06000009.00000000.00000000.00000000.000000 00.00000000
00000010 = 01168086.00900407.03000009.00000000.F7800004.00000000.E00000 0C.00000000
000000B0 = 1C3A8086.00100006.07800004.00800000.F7F0A004.00000000.000000 00.00000000
000000D0 = 1C2D8086.02900006.0C032004.00000000.F7F08000.00000000.000000 00.00000000
000000D8 = 1C208086.00100006.04030004.00000010.F7F00004.00000000.000000 00.00000000
000000E0 = 1C108086.00100007.060400B4.00810010.00000000.00000000.000202 00.0000E0E0
000000E8 = 1C268086.02900006.0C032004.00000000.F7F07000.00000000.000000 00.00000000
000000F8 = 1C498086.02100007.06010004.00800000.00000000.00000000.000000 00.00000000
000000FA = 1C038086.02B00007.01060104.00000000.0000F0B1.0000F0A1.0000F0 91.0000F081
000000FB = 1C228086.02800003.0C050004.00000000.F7F05004.00000000.000000 00.00000000
00000200 = 816810EC.00100407.02000006.00000010.0000E001.00000000.F00040 0C.00000000
00000300 = 08858086.00100406.02800067.00000010.F7E00004.00000000.000000 00.00000000
00000600 = 01941033.00100406.0C033004.00000010.F7C00004.00000000.000000 00.00000000
01040000 = 00FFFFFF.FFFFFF00.3683010B.E9030000.01120103.80462778.0A1990 A7.55469824
00000020 = 10494B01.08000101.01010101.01010101.01010101.0101011D.007251 D0.1E206E28
00000040 = 5500C48E.2100001E.011D8018.711C1620.582C2500.C48E2100.009E00 00.00FC004D
00000060 = 54433236.5434320A.20202020.000000FD.0016500E.5B10000A.202020 20.2020019A
01040100 = 02032272.4D038405.07101293.14161F20.21222309.7F078301.000067 03.0C001000
00000020 = 98298F0A.D08A20E0.2D10103E.9600C48E.21000018.011D00BC.52D01E 20.B8285540
00000040 = C48E2100.001E011D.80D0721C.1620102C.2580C48E.2100009E.8C0AD0 90.20403120
00000060 = 0C405500.C48E2100.00188C0A.D08A20E0.2D10103E.9600C48E.210000 18.00000037
I called the manufacturer after I called their parent company to get their number (800-710-7740) as their technical support line sends you directly to voicemail. I was hoping they could clear this matter up or provide a possible solution. Instead I was told that there is nothing they could do because, it "wasn't their TV". They didn't even understand the importance of the native resolution until after I explained it in detail. Even then I was told there was nothing that they could do because, they "didn't manufacture it". Once I told them that other TVs sold with a native resolution on 1920x1080p do not have this problem, I was told I couldn't "compare TVs to one another as they have different components". My response was that yes you could compare TVs as that is how comparative shopping works. Even if you ignored competitive shopping, there is still the issue that this TV is being sold as having a native resolution of 1920x1080p. When something is advertised as having a native resolution of 1920x1080p it has to actually have that as the native resolution on all of its input channels. This is an industry standard and all manufacturers are bound to it.
Even if you do not plan on using this TV for computer use, I advise you to not purchase it as you will not be getting what you payed for since the native resolution is 1280x720p and it is being falsely marketed as 1920x1080p by iSymphony. In addition to that the manufacturer refused to take any responsibility for the issue so they are far from reputable or trustworthy.
I would also like to point out that the TV is incredibly slow to respond to the remote control. Switching to a different input is also very slow and, you have to sit through an incredibly bright and painful "loading screen" that is white and then a very pale lavender every time you switch to a different input. To stress how bright this screen is, picture your contrast, brightness, and the backlight as high as they can possibly go. After the TV has successfully switched to another input, you can watch it "re-process" the image several times as the colour, contrast, and brightness will all change considerably multiple times. There is no way to turn this processing or any other processing off except for the cable clear one which does nothing. There is also no way to adjust the hue (R/G/B) which is the white balance and the TV's menu is incredibly limited as it is missing basic functions like a backlight adjustment. There is also no way to adjust sharpness over a VGA signal and that signal is in dire need of having it sharpness reduced.
I know the reviews here at Amazon speak very highly of this TV but, I suspect they haven't figured out that it is actually a 1280x720p native resolution TV. The one I purchased also had light bleed in the corners, cross talk during a viewing angle shift, and some minor clouding. The image also "washed out" very rapidly from a minor viewing angle shift and even looking at the TV in the center would leave the sides a bit "washed out". The colours and back levels were actually fairly nice but, you had to have the black levels a little gray or there is an excessive amount of "black crush" that will take place. However, the gamma is also incredibly high and, there is no way to get it at the correct level without introducing "black crush" and losing a lot of the colours on the lower end of the spectrum.
Again, I seriously urge anyone thinking of picking this set up to strongly reconsider doing so especially at it's typical price point of $349.99 as there are much higher quality TVs that are actually what the claim they are in this price range. I only payed $279.99 for it and, it was incredibly sub-par for even that price. I had high hopes for this TV based on the reviews (at another site) and specifications but sadly, it failed to meet any of those.
Conn's however made the return hassle free and even tried to find a comparable model or something that they could adjust the price on. Unfortunately there just wasn't anything available at this time. They may have "lost the sale" but, I would certainly shop with them again.
I decided to take pictures of the failed 4:4:4 tests and of a pitch black scene of video playback. I didn't take images of the multi coloured text because you can all picture what that looks like even if you have never seen it. Please forgive the crappy quality as the camera just refused to focus despite being in macro mode. You may not be able to see the light bleed image unless you shift your viewing angle and/or mess with your brightness/contrast. Just let me know if there is an issue viewing it.
4:4:4 test (1920x1080p) DVI cable (male to male) to HDMI adapter (female DVI to male HDMI)
4:4:4 test (1920x1080i) DVI cable (male to male) to HDMI adapter (female DVI to male HDMI)
The light bleed. Please note the light I see isn't blue (like it was on the camera) but, this was the best I could mimic it. I also want to point out that the area on the bottom left isn't really there. That's a result of the screen "wash out" from the angle shift. Likewise, a most of the lower right corner is also washout and not actually light bleed. If you move your eye level to either of those corners or their vertical sides, that area will darken. of course when you do this the middle of the screen will lighten (which is why I think this might be cross talk). The image also didn't show the light bleed in the top left corner but, it's almost identical to the light bleed in the top right corner. Speaking of the top right corner, it's a bit more "intense" than the picture would lead you to believe. This image was also taken with the brightness turned down much lower than it normally would be so that the bleed could be seen clearly without the actual movie "darkness" affecting it.
Racer_J is offline
post #103 of 582 Old 02-06-2012, 01:05 PM
Porter_'s Avatar
i've also been posting on [H], hoping someone can confirm my Samsung UN32D5500 is either passing or failing the belle-nuit test. pics taken with a low-quality camera.
UN32D5500 HDMI-HDMI (relabeled to PC), HDMI black level set to 'Normal':
it looks like the adjacent sub-pixels are dimly lit. this could be due in part to the low-quality camera but i'm not sure of that. based on the pic above is this considered failing or passing the test? all text looks equally clear to me whether it be black text on white background, red text on black background etc.
UN32D5500 HDMI-HDMI (relabeled to PC), HDMI black level set to 'Low' which crushes blacks:
looks like it passes but the blacks are being crushed based on some other non-formal testing. for reference the quick and dirty method which passes when the input is relabeled to PC:
UN32D5500 via HDMI relabled to PC:
UN32D5500 via HDMI not relabled:
edit: also does it make a difference that my subpixel layout is BGR instead of the typical RGB?
Porter_ is offline
post #104 of 582 Old 02-06-2012, 06:38 PM - Thread Starter
thepoohcontinuum's Avatar
Hi Porter. Since you're from [h], I guess you already saw the discussion from Ryz about the black level low setting / black crush / pseudo 4:4:4. I don't think there was ever a definitive answer that came out of it though.
Still, even if there is black crush, how's the severity of it? You can try lagom's black level test to see how bad it is -- link. If it isn't too bad, I wouldn't worry about it too much, since your magenta result looks perfect.
And subpixel layout doesn't matter.
thepoohcontinuum is offline
post #105 of 582 Old 02-06-2012, 07:04 PM
Porter_'s Avatar
yeah i saw Ryz's posts. the black crush is bad with HDMI black level set to Low.
Normal: boxes 2-255 are clearly visible
Low: boxes 1-15 are indistinguishable from the background, only boxes 20-255 are visible
no change in text clarity, text looks equally clear from one to the other. in the photo i posted above with it set to Normal, is that technically failing the test? i'm partially confused on what constitutes failing. for example can you explain what i should look for in Colmino's pic of his RCA 40LA45RQ which passes? there's clearly other columns of pixels dimly lit, not sure if that's along the same lines of my pic.
Porter_ is offline
post #106 of 582 Old 02-06-2012, 09:11 PM - Thread Starter
From Colmino's pic, the RCA does not pass 444. To the right of the bright red subpixels, you can see faded red subpixels.
When comparing your 'black level normal' pic with Ryz's results, it seems your blue subpixel is lit, whereas in Ryz's case his green subpixel is lit. What happens if you bump the test pic by one pixel vertically? Is the subpixel still blue or is it now green?
Also, there also seems to be a chroma anomaly where the red columns meet the blue columns -- where all subpixels are lit even though only the red subpixel should be lit. From my LD450 (link) and my laptop monitor, I don't see that anomaly.
And I don't know if its because of the quality of the pic, but the D550 / Samsung SQ04 panel seems to have an odd subpixel layout. It looks like each pixel is made up of 1 blue subpixel, 1 green subpixel, and 2 red subpixels... so it looks something like:
BR
GR
I need to check out some of those panel engineering spec sheets that Sjetski linked somewhere.
post #107 of 582 Old 02-07-2012, 02:10 PM
Porter_'s Avatar
how do i go about doing that? while connected via HDMI i have no screen adjustment option, they're only available when connected through VGA.
Porter_ is offline
post #108 of 582 Old 02-10-2012, 09:47 PM
Kohloe's Avatar
Samsung UE40D5000 supports 4:4:4 if input is labeled as PC or DVI PC on HDMI1 Port. Sound does not work.
However Sound works if you use another label for your hdmi port (like GAME, AV-RECEIVER, ....), but 4:4:4 wont work anymore.
Sound tested via Displayport-> HDMI Adapter on thinkpad x220.
Furthermore, delay time (input lag) is quite low. 30ms lower than my laptop LCD and my BenQ G2420HD. Pretty nice!
edit: sorry for bad picture quality (handy made). HA!
Kohloe is offline
post #109 of 582 Old 02-11-2012, 12:37 PM
RunswithAliens's Avatar
Can anyone confirm or deny whether all versions of the LG LK450 tvs support 4:4:4, or is it just the S-IPS panels?
RunswithAliens is offline
post #110 of 582 Old 02-11-2012, 04:51 PM
sjetski71's Avatar
The next quote is Josh's response to another person who asked about the two VA panel LK450's he owns:
Originally Posted by JoshZH View Post
I had two of them(32" and 42"), both passed 4:4:4 after i applied the famous EDID override fix.
Apparently both the S-IPS and VA panel types for the LK450 support 4:4:4.
Link to his post: http://www.avsforum.com/avs-vb/showt...5#post21441705
post #111 of 582 Old 02-12-2012, 08:37 AM
drogulus's Avatar
Cheers!
This is the only post so far that indicates 4:4:4 using HDMI to HDMI with audio. Furthermore the BX520 is a good performer testwise for a 60 Hz model. So, what's the catch? Is it lag, viewing angle, or what?
ernie
drogulus is offline
post #112 of 582 Old 02-13-2012, 08:20 PM
apoklyps3's Avatar
does anybody have LG LV4500 to test if it supports 4:4:4??
apoklyps3 is offline
post #113 of 582 Old 02-13-2012, 08:46 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
Actually, there's other TVs (by Samsung and Sony as referenced in the second post of this thread) that do 4:4:4 HDMI to HDMI with audio as well.
The catch on the BX520 I had was the black levels weren't that good, due to the panel being S-IPS.
I now have a KDL55NX720, but I returned my Mac Mini to Best Buy so I can't test 4:4:4 via HDMI on this new TV at the moment. I will be able to test it soon, though.
post #114 of 582 Old 02-17-2012, 06:53 AM
evan_fotis's Avatar
though this thread is populated with consumer displays, neither pro displays always support full chroma, as is the case with my 47LF20 Panny.
Recently needed to use for small text, we realized RED and BLUE channels are subsampled, whereas GREEN comes out sharp.
Connection: DVI to DVI driven by nvidia gfx, no scaling options.
Some samples:
http://s16.postimage.org/69tkgg5d1/DSC_5932.jpg
http://s7.postimage.org/j0zxho7ff/image.jpg
http://s17.postimage.org/hbi41f1nz/image.jpg
online text test:
B
http://s7.postimage.org/ciboihkm3/image.jpg
G
http://s18.postimage.org/opz6526nt/image.jpg
R
http://s7.postimage.org/gfyy7w7ff/image.jpg
W
http://s18.postimage.org/bps0md9h5/image.jpg
Magenta text:
http://s13.postimage.org/c5qpvgv7r/0...a_1280x881.jpg
Blue text
http://s9.postimage.org/rgwce6uq7/00...e_1280x881.jpg
Green/Red text
http://s9.postimage.org/vejm3lhjj/0002_G_R_1280x881.jpg
Any suggestion for workaround or hack into SM is more than welcome.
evan_fotis is offline
post #115 of 582 Old 02-20-2012, 04:15 AM
Ficnky's Avatar
Hi guys, I am not so into this issue but I bought a Pana 42gt30 Plasma Last week and found out that red Text looks a bit corrupted. I found out that the the Panel doesn't Support 4:4:4 or better 4:4:4 is being subsampled. Is there any Way for the me to get a Crystal clear Image from my computer by tweaking the driver changing the cable or is everything worthless with this Screen? Exept of this issue i Love this Screen.
Sry for the capitalised ones, my IPhone is freakin out.
Thanks in advance.
Ficnky is offline
post #116 of 582 Old 02-20-2012, 04:34 AM
evan_fotis's Avatar
Panasonic does not support full chroma in their 2011 consumer plasma series. Only in the LCD range or the upcoming GT & VT 50 series (pure color). No workaround
post #117 of 582 Old 02-21-2012, 03:48 PM
Soeuni's Avatar
is there a way to override EDID fix for Intel HD Graphics?
Soeuni is offline
post #118 of 582 Old 02-23-2012, 01:54 AM
Lord Humongous's Avatar
You should complain at the better business bureau (if there is one in USA), the LF-20 is marketed as a display for use with computers, not a TV, and should be able to display a desktop in full 4:4:4.
Lord Humongous is offline
post #119 of 582 Old 02-23-2012, 09:07 AM
evan_fotis's Avatar
...unfortunately i'm not in the US. Based in Greece, though this unit was purchased and shipped from Germany, complicating matters even more. Panasonic Europe has not even replied to a few mails I sent them, and the local tech department say, first, I'm only covered by Panasonic DE, then that they do not know what this might be, defective panel etc, heard some stories that Green pixels are placed on top, then the blue one and last the Red ones, that is why they come out blurry(!!) and that I should not look at it that close these displays are made to be viewed by a distance.. Hopefully a firmware update or hack can fix this though no high hopes here..
post #120 of 582 Old 03-01-2012, 10:12 PM
YeuEmMaiMai's Avatar
Originally Posted by Nevcairiel View Post
DVI actually supports audio just fine, most adapters just dont connect those pins, and most devices dont support it when receiving a DVI connection. HDMI is technically only DVI with a different connector (at least for most features, HDMI adds a few new ones)
Audio is not part of the original DVI spec......hence why it cannot handle audio.....
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
Reply LCD Flat Panel Displays
Lcd Hdtv
