LG 47 inch LW5300 Calibration question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-22-2011, 08:19 PM - Thread Starter
bgaviator's Avatar
Quoted: 27 Post(s)
Hello,
Please help me understand something with the calibration settings I obtained from Cnet's web site. We have a LG 5300 model, but I just did a search for the 5600 on Cnet and used those calibration settings since from what I can tell I have all the same parameters I can manipulate on the 5300. Supposedly Cnet's calibration is supposed to be pretty darn accurate, but in my opinion the picture is absolutely horrible! The screen is so dark (I think they set brightness to only 50%) and whites turn into this nasty cream color......maybe I'm just not enough of a video guru to understand, but how is this possibly any better??
bgaviator is offline
post #2 of 5 Old 12-22-2011, 08:58 PM
DrGonzo615's Avatar
could you post up your settings?
DrGonzo615 is offline
post #3 of 5 Old 12-22-2011, 09:00 PM
pete4's Avatar
First of all each TV should be calibrated individually, as they all have differences, even across the same model. You could use somebody else numbers as a starting point, maybe. Those are probably calibrated for watching in completely dark room? You probably need to adjust it for ambient light.
Did you miss anything? First thing I had to turn off on my TV was the energy saving (green button on remote) and I wasted good few minutes, looking for it in the menu (it's not).
Finally, try to use at least simple calibration disc (they used to have calibration section on old THX DVD movies, this forum supposed to have some free calibration disc as well? ) at least to verify you're in the ballpark, without crashing blacks/whites, gray gray etc.
At the end it's your TV, set it the way you like it, not the way somebody thinks it should be.
Good luck
pete4 is offline
post #4 of 5 Old 12-22-2011, 09:12 PM
pete4's Avatar
If he copied it from CNET, as he said, you probably could find it in the CNET review of LW5600 set.
pete4 is offline
post #5 of 5 Old 12-22-2011, 10:13 PM
CherokeeMan's Avatar
Quoted: 62 Post(s)
I dont like cnets either, try these from the 5600 thread:
Standard
Backlight 40
Contrast 90
Brightness 50
Sharpness 50
Color 54
Tint 0
Color temp 0
Dynamic contrast off
Dynamic color off
Clear white off
Skin color 0
Noise reduction off
Gamma medium
Black level low
Eye care off
Real cinema off
Color gamut wide
TRU motion off
Led local dimming on
Energy off
CherokeeMan is offline
Reply LCD Flat Panel Displays
