The Official Sony KDL..EX620 Owner's Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-11-2012, 12:26 PM
anony73's Avatar
Originally Posted by marcster View Post
I have the 40ex620.. Mine doesn't exhibit any vertical banding, however when the screen is black I do notice light in the 4 corners of the tv...
First time owning an edge lit led, should I assume it's normal with these televisions?
I'm pretty sure it is, but some TVs are worse than others. If it doesn't bother you much then I wouldn't worry about it. It's more of an issue when that light spreads significantly, and the screen looks overly bright in areas and blotchy. I experienced some of this but my bigger concern was that it carried over to darker images, so it wasnt just visible on an all black screen.
anony73 is offline
Old 02-17-2012, 04:55 PM
zorobg's Avatar
I'm now on my 3rd EX621. The first one must have been defective panel as the last two did not suffer from the horrendously narrow viewing angles and blue tinge it had. They have however very distinct flashlight effect in the bottom corners have some clouding/screen uniformity the first one did not have.
zorobg is offline
Old 03-05-2012, 11:34 AM
amdspitfire's Avatar
Just picked up an EX621 and the picture/color seems very dull and just off. I tried Tconnors suggested settings as well as some of the settings for the EX720 but still doesn't look right.
Any suggestion on settings? I am mainly watching regular HD tv channels.
amdspitfire is offline
Old 03-05-2012, 11:40 AM - Thread Starter
Tconnors's Avatar
Double check your power savings and light sensor, they should be "off". That was the biggest change that was needed on mine out of the box. The picture was dull until then.
Tconnors is offline
Old 05-18-2012, 05:49 PM
chs4000's Avatar
By dull, do you really mean not bright enough? One usually compensates by raising the backlight to 9 or MAX. If that's still not bright enough for one's situation, then I can understand turning off the light sensor as it does seem to put an absolute cap on effective brightness that might be too dim for brightly lit areas.
chs4000 is offline
Old 05-30-2012, 11:27 PM
dipu_gct's Avatar
Hey Guys... I have 40EX620.. I just tried using the Media Remote App on iPhone.
Does anyone among you had any chance to playaround with that.
My phone is not at all listing my TV.
dipu_gct is offline
Old 06-09-2012, 05:25 PM
vronp's Avatar
Along these lines, is it possible to control this TV with a wireless keyboard or a laptop?
vronp is offline
Old 07-15-2012, 02:35 PM
dipu_gct's Avatar
SONY doesn't support wireless keyboards..
dipu_gct is offline
