Wall Mounting - Samsung UN55D7000 & UN46B8000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-30-2011, 09:00 AM - Thread Starter
jlin615's Avatar
I've just mounted my Samsung UN55D7000 and UN46B8000 two weeks ago.
Using this mount: VideoSecu Tilt TV Wall Mount MF607B
Since both TV's have the recessed screw holes in the back, I had to use the longer M8 screws along with the black nylon spacers that came with the wall mount to put on the vertical arms.
After putting on the vertical arms, I find that the vertical arms have a tiny bit of play or wobble, it's not pressed tight against the black nylon spacers. It seems like the M8 screws are 1mm-2mm too long. Is this normal?
jlin615 is offline
post #2 of 2 Old 12-30-2011, 10:52 AM - Thread Starter
jlin615's Avatar
Should I just leave it as it is? It seems like the only things supporting the TV to the arms are the M8 screws.
Or should I add more 1-2 more washers or find M8 screws thats 1-2mm shorter?
jlin615 is offline
Reply LCD Flat Panel Displays
Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver , Samsung Un46b8000 46 Inch 1080p 240hz Led Hdtv
