Official LG 47LW5700/55LW5700 "Passive 3D" Owners Thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #301 of 312 Old 11-02-2013, 03:17 PM
tommyla's Avatar
Hum, the display ratio option is not available in 3D mode. Seems like Fullscreen is mandatory in 3D. This sucks! smile.gif
tommyla is offline
post #302 of 312 Old 11-05-2013, 05:23 PM
sotodefonk's Avatar
Can anyone know how can I calibrate the color of the screen when using DLNA? everytime I play something using DLNA, the screen changes to default mode which almost immediately see because the black screen from my HDMI input goes to grey when switching to the DLNA input. Trying to change or pressing any button go to "This button is not available"...
Does ayone know if there is something I can do to calibrate or at least change the default settings used in DLNA input?
sotodefonk is offline
post #303 of 312 Old 08-03-2014, 07:49 AM
Drew Neilson's Avatar
Quoted: 29 Post(s)
Liked: 3
Question Is it possible to find out what refresh rate the screen is operating at?
When I am watching my LG 47LW5700, is it possible to find out what refresh rate the screen is operating at? The manual says that it supports different refresh rates. If I knew what refresh rate it is operating at, I would know whether I am watching a 1080p24 movie or TV show at 24 Hz or at 60 Hz.
Drew Neilson is offline
post #304 of 312 Old 08-03-2014, 11:14 AM
Ex_Brit's Avatar
Click the Info button on the remote, a banner should appear at the top telling you that and other information.
A lot depends on the source feeding the TV.
Peter
Toronto, Canada
Ex_Brit is offline
post #305 of 312 Old 08-03-2014, 04:47 PM
Quoted: 29 Post(s)
Liked: 3
It's not showing me the refresh rate when I press the "info" button. I tried pressing it while watching broadcast TV, then while streaming a TV show on Netflix, then while streaming a movie I own on Vudu, and then while the TV was switched to the "AV 1" input. With Netflix and Vudu I am using the TV's built-in apps.
post #306 of 312 Old 08-03-2014, 05:34 PM
Ex_Brit's Avatar
Then not too sure what else there is to do. Maybe someone will post.
Peter
Toronto, Canada
Ex_Brit is offline
post #307 of 312 Old 11-26-2014, 09:15 PM
pjamesh's Avatar
new firmware available
I see LG has posted a new firmware as of 11/21/2014.
Can anyone provide details or confirm that nothing breaks? (related to enabling 5600 features from the special service menu?)
pjamesh is offline
post #308 of 312 Old 11-27-2014, 06:47 AM
Ex_Brit's Avatar
Well I'm going to wait until it comes down the pipe through the TV's own updater as I can't for some reason get that particular update to work manually via USB drive.
There are 3 files BTW and each one is supposed to be done separately but numbers 002 and 003 wont extract for some reason.
That's not the first time their downloads haven't worked properly.
If you alter the drop-down to an operating system at the top it doesn't offer any F/W Update but does if you alter the choice to TV Firm, so I suspect that it's only available via the regular TV online updating method.
In other words, wait !!
Peter
Toronto, Canada
Ex_Brit is offline
post #309 of 312 Old 12-02-2014, 12:52 PM
Ex_Brit's Avatar
This update is certainly taking it's time to arrive...anyone actually received it?
Peter
Toronto, Canada
Ex_Brit is offline
post #310 of 312 Old 12-08-2014, 07:55 PM
Liked: 0
Hey just so you know I did the USB mode.
In the RAR form the 3 files are only parts of the one file.
click on any of the three files and it will unRAR it to a single folder and one file only. thats all you need.
follow instructions as the folder name is specific in order for the TV to find the file. I upgraded fine.
Folder name must be “LG_DTV”
CAPPYREGO is offline
post #311 of 312 Old 12-09-2014, 03:09 AM
Ex_Brit's Avatar
Interesting, I wonder why it has to be WinRAR that one uses and not 7-Zip etc? I had tried the latter and failed miserably.
Thanks. Updated and I don't notice any changes other than I had to log in to my Apps again.
Peter
Toronto, Canada
Ex_Brit is offline
post #312 of 312 Old 03-17-2015, 02:09 PM
Liked: 0
Long time reader (years!) on avsforum, but finally decided to sign up to see if anyone else has experienced this.
I recently bought a pair of powered speakers (Kanto YU5) to replace the current sound bar I have. I use the optical output from this TV, plugged directly into the speakers, and it mostly works.
From my PS4, or using the onboard Netflix app, everything is all cool, sounds awesome!
But I have an antenna plugged into the TV for OTA HD, and when I use these new speakers, all I get is screeching and squealing sounds. Same thing happens with some digital files when I have a USB drive plugged into the TV. These issues do not happen with my existing sound bar.
Has anyone else had similar issues with the optical output from this model of TV? I'm speculating it has to do with the format of those particular digital streams, but has anyone else has this issue? and maybe have a suggestion to fix it? maybe something in the service menu? (Tried turning Dolby on already).
MrCallahan is offline
Reply LCD Flat Panel Displays
Displays , Lg 55lw5600 55 Inch Class 3d Led Tv Full Hd 1080p With Basic Accessory Kit 2 Hdmi Cables 1 Rgb Cable , 3d Hdtv , Led Hdtv , Lg , Lcd Hdtv , Lg 55 Inch 3d Led Hdtv Smart Tv 55lw5700
