How do I figure, whether TV imported from US is 220V mains compatible - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-11-2012, 09:07 AM - Thread Starter
MindaLT's Avatar
Dear All,
I need some ideas.
How do I figure, whether TV imported from US is 220V mains compatible?
I have some indirect proof (posting on another forum) that it runs on 220V mains straight from the box, but I do not want to fry my new TV.
Any ideas (short of disassembling the TV) would be appreciated.
I have a multimeter and general understanding ot electrotechnics.
Mindaugas
MindaLT is offline
post #2 of 8 Old 01-11-2012, 09:18 AM
pete4's Avatar
This should be listed either in detailed technical specs or on the back of TV.
They used to list voltage ratings very clearly in manual and listed specs, but now often enough, this info is missing.
Me think either all the stuff is 100-220v compatible, due to global economy, or companies think consumers are too dumb, or don't care for this things to be listed.
There should be a label somewhere in back, close to power supply listing operational voltage and amperage. They used to have switch there to choose voltage, but I think most newer stuff is self sensing and if it says something like "110-240 volts" you're good to go, as long as you have plug adapter.
pete4 is offline
post #3 of 8 Old 01-11-2012, 10:30 AM
walford's Avatar
The odds are that the power supply is 1102/220 volts cinpatible. However that does not mean that it will handle 50cps power and 50 HZ programing.
walford is offline
post #4 of 8 Old 01-11-2012, 11:05 AM - Thread Starter
MindaLT's Avatar
It just says "AC Input" where the cord plugs.
On the back there is a label saying 110V 60Hz and that's it.
The TV is Sharp 80' LCD panel LC80LE632U.
It is pretty happy with 50Hz content - one of the forum members tested it for 50Hz content prior to my purchase and I can confirm this for sure. I am currently feeding it 110V 50 Hz mains and 1080p 50Hz from my HTPC.
MindaLT is offline
post #5 of 8 Old 01-11-2012, 04:51 PM
sitlet's Avatar
If that's what it says, then that's what it accepts. I highly would advice giving it any other voltage, whether or not other people say it works.
Just an FYI, you are feeding it 60hz 110v from the power of the wall outlet, not 50hz. The fact that you are feeding it 50hz VIDEO is completely different than feeding it 60 hz POWER.
sitlet is offline
post #6 of 8 Old 01-12-2012, 02:25 AM - Thread Starter
MindaLT's Avatar
I am in Europe and I am just downconverting 220V 50Hz mains to 110V 50Hz though a transformer. Thus, it certainly runs on 50Hz power.
There is no easy way to change the mains frequency and the difference is not that big anyway even for electric motors designed for 60Hz mains.
It says 60hz 110v on the general TV sticker, where the model is listed, etc.
MindaLT is offline
post #7 of 8 Old 01-12-2012, 12:16 PM
norml4721's Avatar
CALL THE MANUFACTURER
LOL
norml4721
norml4721 is offline
post #8 of 8 Old 01-12-2012, 01:13 PM
pete4's Avatar
60Hz or 50Hz AC frequency should not matter at all. Power supply downconverts everything to low voltage DC anyway. If it only says 110v on the back, I would not plug it into 220V without stepdown transformer in between. 50Hz/60Hz refresh rate that's another story, probably easiest way to test it in US would be with computer and see what options are there. I have no idea what frequency/encoding digital tuners use in US compared to Europe and if they're compatible. Does Europe still uses analog OTA systems? This could even differ between different European countries.
Probably US warranty is not valid in Europe?
Keep in mind, the same model could use different power supplies
pete4 is offline
Reply LCD Flat Panel Displays
