Samsung ue46c7700 water demaged. - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2012, 09:52 AM - Thread Starter
exbeing's Avatar
Hi all,
I have a samsung led ue46c7700. While i was wiping the screen with a wet cloth,
water must have seep in, and now half the screen is demage. There is a layer of color
appearing on one side of it.
I will like to know which component of the led is damaged?
is it to costly to get it fix?
thanks alot
exbeing is offline
Old 01-15-2012, 11:12 AM
YeuEmMaiMai's Avatar
I am pretty sure that is not water damage but some sort of chip failure. Replacing the approperiate board will fix that..
Turn the set off for a few days and turn it back on.
The eletronics that drive that set are behind the LCD......
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
Old 01-15-2012, 11:40 AM
HTguru3's Avatar
Originally Posted by exbeing View Post
Hi all,
thanks alot
I agree with the other poster as there is no way a wet cloth would cause anything like that to happen. Is it still under warranty? If not then try a reset by unplugging for 30 minutes and then seeing what happens. You can also try leaving it unplugged overnight as well. Good luck and keep us posted.
HTguru3 is offline
Old 01-15-2012, 11:03 PM - Thread Starter
exbeing's Avatar
thanks for the advice guys, actually this tv was not from me but from another owner adn that was what he told me. I am thinking of purchasing and fix it.
exbeing is offline
