Help needed hooking up components to new TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-17-2012, 06:29 PM - Thread Starter
rayderz's Avatar
Hello
Im looking for some help with hooking up some components to my new 60" LG TV Model 60PV400.
Components include:
Pioneer surround sound receiver SX-315
Pioneer DVD player DVR231
Bell HD Digital receiver 6131
All components worked well with our old TV.
Cannot get the sound working for each component the way it used to.
Right now i have it rigged for sound from all components but it is definitely not the way it was or the way i want it
I have a vast assortment of RCA Red white yellow cables
HDMI Cables--single wire and triple wire.
I have PDF Files of the user manuals for all components if you need to look at them:
rayderz is offline
post #2 of 13 Old 01-17-2012, 08:58 PM
txrose's Avatar
We might be able to help if we could understand your problem. "Cannot get the sound working for each component the way it used to" is not a problem which we can solve. Could you describe how you had it connected before and the TV you were using. Then tell us how you have it connected now and why that is not satisfactory. The description should include what output is connected to what input including the connection type such as composite, component, HDMI, analog left/right audio, digital audio optical or coax, and coax RF for example.
If it isn't 720p or 1080i/p it isn't HD. If it is 720p or 1080i/p it may not be HD content.
txrose is offline
post #3 of 13 Old 01-17-2012, 09:35 PM
thepoohcontinuum's Avatar
Barring "the way it used to", if I had your components, I would hook everything up as shown in my attached pic. For your Bell receiver, make sure you have it set to send video-only through the hdmi connection, and audio through the optical connection.
thepoohcontinuum is offline
post #4 of 13 Old 01-18-2012, 04:46 AM - Thread Starter
rayderz's Avatar
Thanks for your reply...regardless of how it was hooked up before on the old TV, im just asking how you would hook-up the components involved using all the same cable types...RCA and HDMI.
Right now i have a red/white coming from the surround receiver going into an RCA "3-way Splitter" then i have the red whites from the splitter going to the components. I have to flip the switch on the splitter box everytime we want to watch and hear a different component DVD or PC
Hope that is a little clearer
Thanks Again
rayderz is offline
post #5 of 13 Old 01-18-2012, 04:48 AM - Thread Starter
rayderz's Avatar
Thanks for your reply to my issue.
I will have another look at the cabling this week using your schematics. I do not have or have ever used an optical cable...do you have another wiring plan using my existing RCA wires
Ray
rayderz is offline
post #6 of 13 Old 01-18-2012, 12:57 PM
Ray
The only other way I see it is to use the Red/White RCA audio connections between Bell and Receiver. However, this will only net you 2.0 stereo sound. Also, if using HDMI for video out (like my schematic shows), you might not get audio out from the Red/White RCA -- as that output might be tied to Yellow RCA or Component. Try it out and see if it works.
If the above fails, then you'll have to forego HDMI and instead use Component (to TV) and Red/White RCA (to Receiver).
post #7 of 13 Old 01-19-2012, 09:05 AM - Thread Starter
rayderz's Avatar
None of the suggestions seem to be working properly?
here is where i left off now after trying numerous combinations....
red/white rca from the surround receiver to the bell satellite box---HDMI FROM BELL box TO tv . Surround Sound works perfectly with this hook-up.
Add yellow rca from DVD player to the tv and single wire composite audio cable from dvd digital out plug on the back of dvd player to digital input dvd/dvr location on the back of surround receiver gets me ZERO sound with dvd (picture works--no sound)
if i plug a red/white from dvd player to the same location on back of suurround receiver that i used for the bell hook-up..i get proper sound from DVD player...i cant seem to find proper scheme to have multiple audio hooked up at the same time.
Does this make any sense to you guys...cause im more lost than ever now...LMAO
tHANKS
rayderz is offline
post #8 of 13 Old 01-19-2012, 09:33 AM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
we might be able to help if we could understand your problem. "cannot get the sound working for each component the way it used to" is not a problem which we can solve. Could you describe how you had it connected before and the tv you were using. Then tell us how you have it connected now and why that is not satisfactory. The description should include what output is connected to what input including the connection type such as composite, component, hdmi, analog left/right audio, digital audio optical or coax, and coax rf for example.
lol!
Reefdvr27 is offline
post #9 of 13 Old 01-19-2012, 09:41 AM
sitlet's Avatar
Quoted: 16 Post(s)
Surround sound will NOT work with just red/white stereo cables. To get 5.1, you need to use either an optical connection, or an hdmi connection, if your receiver has hdmi inputs and outputs.
You may just need to "turn on" the digital port on the dvd player.
sitlet is offline
post #10 of 13 Old 01-19-2012, 10:23 AM - Thread Starter
rayderz's Avatar
There is no turn on function for the digital port...but i figured it out.
With the same wiring set up as i listed above i have to switch the digital input on the surround receiver from tv to dvd when we want to watch and hear a dvd. I dug up the old converter for the surround receiver to do this.
Im guessing this is the procedure we used in the past with the old TV...who nows...i cant remember...i got a bad case of "sometimerz" happening lately.
I'll go with this setup unless someone points me to a better solution
Thanks for all your help
rayderz is offline
post #11 of 13 Old 01-19-2012, 10:26 AM - Thread Starter
rayderz's Avatar
Originally Posted by Reefdvr27 View Post
lol!
Not sure what kind of input you are offering with your comment??
Although you do seem easily amused.....
I'm pretty sure you spelled it backwards though....lol
rayderz is offline
post #12 of 13 Old 01-19-2012, 11:00 AM
topr's Avatar
what are you using for video input cables from your equipment to your TV?
topr is offline
post #13 of 13 Old 01-19-2012, 11:14 AM - Thread Starter
rayderz's Avatar
I am using a single piece HDMI cable from the Bell satellite receiver to the TV.
Using a 3 wire HD cable red/blue/green from the DVD to the TV Component1
Everything is working okay with me for now...have to use 2 converters to get the job done though...no biggie.
I just hooked up my laptop to stream movies to the TV.
1 single jack going into the laptop and other end of cable has 2 connectors red/white plugged into the red/white ports on the surround receiver. I have to switch the input on the receiver to VCR setting to get sound from the laptop flowing through the surround...works pretty good in my books
There are 2 more red/white ports on the surround receiver still not used...maybe hook up my grandsons X-box or something else for sound..who knows
rayderz is offline
Reply LCD Flat Panel Displays
