TVs with 5.1 Passthrough from HDMI to SPDIF - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 211 Old 05-08-2014, 08:28 AM
Otto Pylot's Avatar
Quoted: 1577 Post(s)
Liked: 984
To clarify my OTA statement, we receive our tv audio and video OTA (Over the Air, antenna) using the internal ATSC tuner. The tv speakers are off so the video is displayed on the tv and the audio is sent to the receiver via the optical cable. If you use your internal ATSC tuner, or if you tv has SmartApps, this is the way to do it. Everything else, in our case, is connected to the receiver via HDMI so only video is sent to the tv and all audio is played thru the receiver.
Otto Pylot is online now
post #182 of 211 Old 05-08-2014, 08:58 AM
mcginnin's Avatar
OK thanks! If I stream netflix with my Blu-Ray player would it audio/video work via HDMI?
mcginnin is offline
post #183 of 211 Old 05-08-2014, 10:44 AM
Otto Pylot's Avatar
Liked: 984
It should. The audio would go to the soundbar and the video will go thru the soundbar and out to the tv via the HDMI out. The soundbar acts like a standalone receiver in that respect.
post #184 of 211 Old 05-08-2014, 11:23 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes. It would work just like playing a Blu-ray Disc. HDMI to the soundbar. The bar processes the audio and feeds video to the TV. If you don't have SmartTV apps or use an off air antenna and are feeding all sources through the soundbar, there's no use for the optical cable from the TV to the soundbar.
BIslander is offline
post #185 of 211 Old 05-09-2014, 03:51 AM
mcginnin's Avatar
You guys rock! Streaming netflix via my Blu-Ray works perfect. Now I m just ready to get my system beefed up abit more but with a baby on the way in about 20 days my wife says Home theater is on the back burner hahah. I have other questions regarding Blu-Ray is it ok to just ask on this post? While I have your attention?
BLU-RAY settings.
24p was selected as off. Should this be on?
Should I adjust any down mixing settings?
Same with DTS NEO6
And should I select PCM
I have them all at factory settings now.
mcginnin is offline
post #186 of 211 Old 05-09-2014, 06:48 AM
Rudy1's Avatar
Quoted: 1300 Post(s)
Liked: 1871
BLU-RAY settings.
Same with DTS NEO6
I have that soundbar, so I can answer your questions:
1. Set 24p to "ON".
2. No need to adjust downmix...the soundbar handles bitstreamed multi-channel audio just fine.
3. DTS Neo6 sounds better, IMHO, with large speakers so leave that off.
4. See item 2 above. No need to use PCM.
There are two types of people in this world: People you want to drink with, and people who make you want to drink.
Rudy1 is online now
post #187 of 211 Old 05-09-2014, 06:50 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
What player do you have?
Downmix handles the reduction of multichannel content to stereo by the player, so it doesn't matter in your setup.
DTS Neo:6 handles expansion of stereo content to multichannel, which also doesn't apply in your case.
I would not use PCM with your sound bar. But the correct setting there depends on the particular player you have.
24p depends on your TV.
post #188 of 211 Old 05-09-2014, 07:12 AM
mcginnin's Avatar
Set up is as follows
Blu-Ray is Panasonic DMP-BD89
Sound bar is Sony HT-CT370
Tv Panasonic TC-P60ST60
mcginnin is offline
post #189 of 211 Old 05-09-2014, 07:58 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Set the Dolby and DTS outputs to Dolby and DTS, which may be called bitstream. Set secondary audio to off.
post #190 of 211 Old 05-09-2014, 04:57 PM
mcginnin's Avatar
You guys are killing it!
My audio for Blu-Ray are like this now
dialog enhancer - off
dynamic range compression - off
downmix - stereo
dts neo6 - off
dolby d/dolby d +/dolby true hd - bitstream
dts/dts-hd - bitstream
bd video secondary audio - off
Also fooling with my sound bar
I selected AAV on and the sound improves ten-fold! I assume I should leave this on?
I feel like I should be paying you.
mcginnin is offline
post #191 of 211 Old 05-09-2014, 05:24 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
When you set the output to bitstream, none of the other settings matter. The only exception is secondary audio, which needs to be off so that the player sends the lossless TrueHD and DTS Master Audio versions of the soundtracks instead of the lower resolution lossy versions.
All of those other settings operate on PCM. But, when set to bitstream, the player simply sends the encoded track to the soundbar, which does the decoding to produce PCM and any subsequent processing such downmixing and dialog enhancements.
post #192 of 211 Old 05-10-2014, 02:23 PM
mcginnin's Avatar
What is the AAV setting that I turned on? Is this just a way to get a sound boost?
mcginnin is offline
post #193 of 211 Old 05-10-2014, 04:16 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Advanced Auto Volume. The manual describes it as a way to reduce the volume differences when switching between sources. Can't imagine why it would improve the sound ten fold. But, if it sounds better to you, then, yes leave it on.
post #194 of 211 Old 05-28-2014, 06:05 AM
hondabbq's Avatar
Originally Posted by davyo View Post
To my knowlege there are no brands of panels that will pass 5.1 thru the optical output on the panel with a device hooked to the panel via HDMI and that goes for all TV's, even the ones made in the last 2 years.
My new 70" and 80" Sharps wouldnt pass 5.1
May I ask how you "confirmed" that the brands you mentioned will pass 5.1 thru the optical ?
Cheers
Davyo
My Sharp lc70le757u will pass DD 5.1. I confirmed this through my new sonos system. On the controller you can see what signal the Playbar is receiving. That being said, It will pass DD 5.1 as long as the original device signal is DD 5.1.
hondabbq is offline
post #195 of 211 Old 05-28-2014, 10:23 AM
Otto Pylot's Avatar
Liked: 984
Do you actually hear discrete 5.1 thru all of the speakers?
post #196 of 211 Old 05-28-2014, 10:32 AM
hondabbq's Avatar
Otto,
I do not currently have the surrounds up and running ( or own them yet) as I just bought my Playbar and sub this past Sunday. I too had concerns about the TV passing the signal down to the Playbar so I didn't want to invest in them if there was only going to be a mediocre gain without DD 5.1.
I can sincerely state that there is a noticeable difference in the DD5.1 over the Stereo/pcm sound coming from the soundbar. It does have a distinguished sound field and replicates the sound quite well. This will only be enhanced by the addition of the surrounds.
I don't understand how anyone can not hear a discernible difference.
hondabbq is offline
post #197 of 211 Old 05-28-2014, 10:44 AM
Otto Pylot's Avatar
Liked: 984
Some tv's do in fact pass discrete 5.1 from either the internal ATSC tuner ( my tv does as an example for OTA) and some SmartApps via optical cable. If you use an external source that is not always the case. I don't know what your sources are. Pseudo-surround sound can sound very nice on higher end soundbars, which the Sonos is. All I'm suggesting is that even tho the display indicates that it's receiving a discrete 5.1 stream it may not be able to separate those tracks and push them to their respective speakers. The Sonos should be able to do that because you can add more speakers but maybe another Sonos owner who's invested in the speakers can confirm that.
post #198 of 211 Old 05-30-2014, 12:48 AM
drameddie's Avatar
Quoted: 23 Post(s)
Does the new M602I-B3 have the 5.1 passthrough?
I own the Vizio M602i-B3.
drameddie is offline
post #199 of 211 Old 08-28-2014, 10:19 PM
Liked: 0
Hi AVS,
New here and apologies for not going through the entire thread.
I just bought the LG 55LA7400 and needed to confirm:
1. HDMI ARC on this TV is Stereo pass through only ?
2. Optical out is DD 5.1 ? (but not DTS 5.1)
I need this info to weigh in my soundbar purchase.
Most likely looking at building a Core i3 HTPC capable of outputting DTS HD-MA/ Dolby TrueHD via HDMI. (or even using my Asus EPE 121 Table @ Core i5 427um)
What would be my connection options ? HTPC direct to soundbar and HDMI out to TV or HTPC to TV and out via ARC to Soundbar.
Would anything over a 2.1 soundbar be wasted ? Looking at the LG NB4540 (choices are limited here in SEA/Malaysia). The LG is approx USD400 here. Was looking at the Philips HTL 5120 previously but it's no longer selling. The more expensive HTL 9100 is though @ USD900 or so.
Would a more expensive Sony ST3 soundbar (which supports DTS MA and true HD) be overkill ? it is 4.1 anyway. The ST3 is approx USD600.
Not looking for a proper/full fledged 7.1 (or even 5.1) setup. I like the soundbar approach and can live with the cons.
Many thanks!
Eoma is offline
post #200 of 211 Old 08-29-2014, 08:54 AM
Otto Pylot's Avatar
Liked: 984
The best that ARC can do is discrete 5.1, just like optical. Neither one, ARC or optical, can send HD audio (DTS-MA, Dolby TrueHD, etc). HD audio does maintain a 5.1 core so if you send the HD audio stream, you should still be able to get the 5.1 depending on the capabilities of the receiver. However, ARC is not without it's issues because of the relationship that it has with CEC.
I don't have any experience with soundbars but they are limited in what they can do in comparison to a standalone receiver, which would be your best choice. There are some high end soundbars (expensive) that are more capable but you'd probably have to check out the soundbar specific forums for what they can, and can not do.
post #201 of 211 Old 10-12-2014, 09:15 AM
lufters's Avatar
Quoted: 67 Post(s)
Liked: 34
TV's Tested that will do pass through
Came across this article on cnet. Answers a lot of questions here.
http://www.cnet.com/news/20-tvs-test...o-a-sound-bar/
John
lufters is offline
post #202 of 211 Old 10-12-2014, 01:49 PM
Rudy1's Avatar
Liked: 1871
They should've done much more thorough testing. Over the last decade and a half, and using TVs from Sony, Toshiba, Samsung, LG, and Mitsubishi, I have been able to get Dolby Digital 5.1 via Toslink from a Comcast/Xfinity cable box connected to the display via HDMI. This includes models where the manufacturer stated in the manual that this was not possible. If you're using a Comcast/Xfinity cable box, first turn the unit off, then immediately press the MENU button on the STB remote. In the USER SETTINGS MENU, you go into ADDITIONAL HDMI SETTINGS and set AUDIO OUTPUT to PASS THROUGH. Though this will not work with signals from a Blu-Ray player or other similar device connected via HDMI, Dolby Digital from the cablebox is passed by the TV through its optical output to the AVR. The Comcast cable boxes I've used were all either from Pace or from Motorola...it is my understanding that Time Warner boxes do not offer these options for HDMI audio.
Rudy1 is online now
post #203 of 211 Old 10-15-2014, 01:24 PM
lufters's Avatar
Quoted: 67 Post(s)
Liked: 34
On my TW 8300 I set it to HDMI audio and 5.1 pass-through went from my Vizio to my receiver with no issues.
John
lufters is offline
post #204 of 211 Old 10-16-2014, 11:18 AM
Liked: 0
Does anyone know if the 2014 LGs ( LB6300 in particular) will send 5.1ch through optical from HDMI source, what about OTA or Netflix or other network source? It seems to be working but I want to confirm somehow.
My Onkyo receiver is showing a DD source light, but I have no idea if the channels are source or some sort of matrixed output.
blue_cheese is offline
post #205 of 211 Old 10-22-2014, 10:39 AM
micha019's Avatar
Liked: 0
Does the Sony KD-**X8505 TVs Pass through 5.1 from HDMI to SPDIF?
What current 4k TVs work?
micha019 is offline
post #206 of 211 Old 11-27-2014, 08:41 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
That is useful. I will note that my Samsung TV in the menu area has the 5.1 option grayed out, so it's clearly not available.
Karyk is offline
post #207 of 211 Old 12-25-2014, 09:45 AM
Zaim's Avatar
Quoted: 46 Post(s)
I've tried ARC And OPT on this tv and it will pass Dolby D 5.1 fine, anything above this and its PCM Stereo.
TV: Sony KD55XD9305, AV Receiver: Denon AVR-X3300w, Speakers/Sub: Tannoy Mercury V4i / v1i (Rear) + Tannoy Mercury VCi (Center), SVS PB-1000 (Sub), 4K Blu-ray: Sony UBP-X800
Zaim is offline
post #208 of 211 Old 02-08-2015, 01:23 PM
bigblk150's Avatar
Hi all, long time forum lurker, and new Vizio P702ui-b3 owner here. I'm having trouble with audio passthrough, and I'm hoping that I might be able to get some help or advice from the group.
First, here's my setup:
Pace RNG200N cable box
Vizio P702ui-b3, Firmware 1.0.0.14 (I've read reports of a 1.0.0.19, but don't have it yet)
Sony STR-DE935 receiver (an older DTS/DD 5.1 receiver, no HDMI)
Cabling is as follows, and fairly simple:
Cable Box --> TV via HDMI
TV --> Receiver via Toslink Optical
The problem:
With this setup, if I set the TV's Audio Output setting to "PCM", I get 48kHz PCM audio just fine. However, when set to "Bitstream" (which I assume is passthrough mode), I get NO audio at the receiver AT ALL. When "Bitstream" is enabled the receiver does detect that a multichannel stream is being provided, but there's no sound.
Note that I don't believe this to be a cable box issue, for two reasons:
- When I run a VIA app like Amazon or Netflix, I see the same problem as above.
- When I bypass the TV and connect the Toslink output from the cable box directly to the receiver, I get multichannel audio just fine.
Unlike many others reporting here, I'm not just getting random or spurious audio dropouts; when set to Multichannel, I get no audio at all, despite the receiver believing it's receiving a Dolby Digital stream. Although I could just use the output from the cable box, that doesn't help when I want to watch something using the built-in VIA apps.
Is anyone else seeing the same thing, and is there a fix/workaround? Thanks very much in advance for any help you all might be able to provide!
bigblk150 is offline
post #209 of 211 Old 09-30-2015, 01:22 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Apologize for resurrecting an old thread.
One thing that occurred to me is that maybe an HDMI Detective or Dr HDMI might solve this problem. They are devices which impersonate the EDID of an upstream device in order to solve handshake problems. I have a Dr HDMI connected between my downstairs AVR and LG TV because those could never handshake properly and I always got a blank display. The Dr HDMI has a number of presets including one that advertises every single audio and video format. Maybe it could be used to fool a device into thinking a TV supports pass through of all the audio formats.
Anyone tried this?
politby is offline
post #210 of 211 Old 05-18-2016, 12:27 PM
HaChayalBoded's Avatar
Liked: 0
Wanting one less usb port used and really wanting the TV remote to control the roku I picked up an MHL roku stick.
TV remote works great, it's a tiny bit faster than the 3500 HDMI roku stick.
and oh my god, I played a 5.1 file through plex and the receiver swiitched to 5.1 from the TV optical. I got immediately all giddy because my receiver only has 3 inputs and this means I can just use the TVs hdmi input.
I plugged the old roku back into that same port and double and tripled checked the audio settings, tried to play the same file and no dice on the 5.1 passthrough.
These are more or less the same roku sticks, one is a 3500 and one is a 3420 (same as 3400 just black and meant for the Canadian market)
Can this be that Canadain items to not have to or choose not to abide by HDCP? And thus 5.1 is not deactivated as a passthrough measure?
I always assumed the deactivation of 5.1 passthrough in the US market or a TVs optical port was due to the TVs own firmware and settings.
Either way Im very happy, the TVs remote works fine on the Roku, all but the * button which never actually gets used anyway.
And I have an old smart phone which has the roku app and controls the TV and receiver anyway. Plus the TV powers the Roku and I do not have to use the TV's USB port for power.
HaChayalBoded is offline
Reply LCD Flat Panel Displays
Lcd Hdtv , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Displays
