55" LCD Recommendations - AVS Forum | Home Theater Discussions And Reviews
Old 01-24-2012, 11:01 AM - Thread Starter
ListedGuru's Avatar
I am looking for a 55" LCD (maybe an LED) with the following:
-Must have a matte finish screen.
-Max budget of $1,000 (less is better).
TV will be used for 90% watching HD cable and the other 10% watching blu ray. I'm not a gamer. I also want to make sure I can get rid of the soap opera effect as I'm not a fan
Any suggestions?
-Guru
ListedGuru is offline
Old 01-24-2012, 11:10 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You can get a 60" Sharp LC60LE6300U for that price at Best Buy this week. Unless you have space restrictions limiting your size, I would be looking at that. Otherwise I highly recommend the LG 55LK520.
Jay1 is offline
Old 01-25-2012, 04:02 AM
6athome's Avatar
Quoted: 455 Post(s)
Liked: 139
My son was looking at the 60 sharp and said Dad your Lg LV9500 led nano just rocks and make the sharp look like @@@t..
If you can find a LV9500, buy it!
6athome is offline
Old 01-26-2012, 08:41 AM
TerrenceQ's Avatar
find out Sharp 52LE810UN or bigger size with a little over your budget 60E78UN,
http://tv-compare.blogspot.com/2011/...c-60e78un.html
TerrenceQ is offline
Old 02-02-2012, 06:40 AM
sadmaker's Avatar
That set is roughly twice his budget. Your post wasn't the least bit helpful.
OP, if you arent concerned with a thin TV with all the bells and whistles, look into the Sony KDL-55BX520. IPS panel with a very nice picture. Saw it at Walmart recently for $998.
XBL Gamertag: RagingPhinsFan
sadmaker is offline
