Sony XBR-65HX929 vs KDL-65HX729 - AVS Forum
post #1 of 7 Old 01-25-2012, 10:22 PM - Thread Starter
jyeh74's Avatar
I did a compare on these 65" LED TVs. The XBR is $5400 and the KDL is $4000. They are pretty much the same features. What exactly is different? The XBR says it has Motionflow 960 while the KDL has Motionflow 480. I'm not sure what Sony means by this, it seems like they are both only 240 Mhz. Are they manipulating the numbers?
The XBR has stuff like Intelligent Presence Sensor and Presence Sensor with Face Detection, which I don't even really know what it does. The design features seems aesthetic to me. Can someone speak in layman's terms?
jyeh74 is offline
post #2 of 7 Old 01-25-2012, 10:46 PM
fatuglyguy's Avatar
Quoted: 12 Post(s)
Liked: 83
The HX929 is an LED-backlit LCD, while the HX729 is an LED edge-lit LCD, meaning the XBR contains a full array of LEDs behind the LCD panel, enabling a feature called local dimming. The TV is able to independently control clusters of LEDs grouped into zones dynamically based on on-screen content. This gives you the best available backlight homogeneity, especially in larger (e.g. 65") screen sizes, better brights and darks, and the deepest blacks available on LCD televisions.
The HX729 only features LEDs around the edges of the LCD panel and as such cannot feature real local dimming, although it does feature a poor man's version of it that in largely ineffective compared to the real thing.
ht Panasonic TC-P60ZT60, Monitor Audio: Silver RX6, RX Centre, Radius 90HD; Martinlogan Dynamo 700, Marantz SR5006, PS3, Oppo BDP-103D
2ch Marantz PM8004, Sony BDP-S1000ES, JVC T-X3 tuner, Monitor Audio Silver RX1, REL T3, Apple TV, Peachtree Audio DAC•iT
lr Panasonic 50ST60, Sony BDP-S5100
fatuglyguy is offline
post #3 of 7 Old 01-26-2012, 12:59 AM
rahzel's Avatar
Liked: 145
The HX729 is one of the better edge-lit LED TVs with local dimming. But the HX929 with it's full-array of LEDs is definitely superior, hence the price difference.
rahzel is online now
post #4 of 7 Old 01-26-2012, 08:22 AM
TerrenceQ's Avatar
XBR panel is by far more superior compare to KDL. however, KDL is edge-lit.
side by side spec comparison here, http://tv-compare.blogspot.com/2012/...r-65hx929.html
TerrenceQ is offline
post #5 of 7 Old 01-26-2012, 02:59 PM
karlmalone1's Avatar
Fatuglyguy hit it on the head. The 729 is a great tv, but the 929 is noticeably superior, and if i were spending 4K on a tv such as that, i'd spend the extra for what is considered one of the best tvs available.
karlmalone1 is offline
post #6 of 7 Old 01-31-2012, 06:27 PM - Thread Starter
jyeh74's Avatar
Does the full array LED really make that big of a difference compared to the edge-lit LED?
I just noticed on the Sony site, there is now 60 inch TV. I don't believe they are full array. Not sure why there is no XBR version of the 60 inch.
KDL-60NX720
KDL-60EX720
Not exactly sure what is the difference.
jyeh74 is offline
post #7 of 7 Old 01-31-2012, 06:56 PM
topr's Avatar
Instead of throwing spagetti against the wall IN ALL THREE OF YOUR THREADS why not just spend a little time doing research comparing models...full array vs edge lit, Sony vs Sammy. Just a little time in each of the owners threads would help you make a much more informed decision.
topr is offline
Reply LCD Flat Panel Displays
Sony Bravia Xbr65hx929 65 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wifi Black , Sony Kdl65hx729 240 Hz 65 Inch Class 64 5 Inch Diag Led Hx729 Series Internet Tv
