Looking for a new LED TV (26-32) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2012, 05:20 AM - Thread Starter
Polcius's Avatar
Hi,
I'll use it mainly for watching movies through a HTPC. I don't care about 3D or extra features, I just want picture quality. I know how to calibrate TV's (ISF cert.).
I sit at 5 feet, and have a dim ambient light behind the TV. I'll always use it in a dark room.
My budget is 500-550 USD.
For size, I'm thinking 26-32 inches.
I tried the LG26V2500 but returned it immediatly, absolutely rubbish image (even after calibration).
Polcius is offline
post #2 of 6 Old 01-27-2012, 06:26 AM
sjetski71's Avatar
32" is a safe size since it will definitely not use a TN panel, the max current size for TN panels are 28" so.
If you can sit within it's viewing cone the Samsung LN-32D550 comes highly recommended here for good blacks/contrast, overall image quality, performance and menu tweaking options. It is CCFL but the benefit of that is it will have even backpanel lighting compared to lower end edge-lit models.
There is also an official LN-xxD550 owner's thread floating around, but here's a thread dedicated to the 32" model: http://www.avsforum.com/avs-vb/showthread.php?t=1318336
sjetski71 is offline
post #3 of 6 Old 01-28-2012, 04:43 AM - Thread Starter
Polcius's Avatar
Ok, thanks.
What about these models?
Toshiba 32HL833G
Samsung UE32D4020
Sony KDL26EX320
Polcius is offline
post #4 of 6 Old 01-28-2012, 06:46 AM
sjetski71's Avatar
Originally Posted by Polcius View Post
Ok, thanks.
Toshiba 32HL833G
Samsung UE32D4020
Sony KDL26EX320
Not sure since they do not look familiar to me, you may have to try some EU based AV forums for those models.
They are not necessarily built using the same parts as their North American equivalents, especially Sony, so results will vary for PC use.
post #5 of 6 Old 01-28-2012, 07:42 AM - Thread Starter
Polcius's Avatar
Ok. Yeah, I live in Europe (Spain); didn't know the models were different, but it totally makes sense.
Polcius is offline
post #6 of 6 Old 01-28-2012, 08:37 AM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
If you want picture quality go with a CCFL lit LCD. I personally haven't see any low end LED's that don't suffer from blooming on bright scenes. Only full array LED's are worth considering if PQ is crucial IMO.
Digital Rules is offline
Reply LCD Flat Panel Displays
