AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   LCD Flat Panel Displays (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/)
-   -   vizio vf552xvt problems (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1391440-vizio-vf552xvt-problems.html)
JROCKZ28 02-01-2012 07:45 PM
Ok. So i took a chance and purchased a broke vf552xvt. the story is the house got struck by lightning. The TV would not power on or do anything. So i went ahead and replaced the power supply board. TV now turns on! however it does this white to amber sequence and eventually the screen comes on with a big V in the center. after about two minutes it powers off and goes back to white and amber sequence and repeats continually. I think i have a bad main (pc board). The TV was 100$ plus a 70$ power supply board. I think the TV is worth the 150 or so for the main board. My question is does anyone disagree? does anyone think its not the main board. by the way checked the three soldered on fuses on the board are good (damn! hopping for an easy fix).
8traxrule 02-01-2012 11:49 PM
It might be the main board since that tells the TV what to do. Don't know what the problem is but something's making it keep shutting down and re-starting. It does the re-starting thing when it gets "locked up", so sounds like it's always getting locked up right when it powers on.
JROCKZ28 02-02-2012 04:35 AM
Think so. Power supply is new and I get a screen so that should rule out an inverter board and x y board and the screen. That leaves the main board.
JROCKZ28 03-22-2012 07:29 AM
In case anyone was interrested. I put the video board in and the tv works great.
mtbruck 08-26-2014 05:13 PM
I have a VF552XVT...had it about 4 years and it has been wonderful, until now. About a minute or so after I turn it on, the screen goes black. I still have sound. I turn it off and it comes back on, but it does the same thing after a second or two. If I wait a day and try it I can have it last for a couple of minutes, then it is black again with sound and retries are on a second or two as before.
Does anyone have a solution or experience the same issue?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
