Samsung AnyNET and Onkyo Not Working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-06-2012, 08:45 AM - Thread Starter
wiz561's Avatar
Quoted: 16 Post(s)
Hi!
I'm trying to get the HDMI-CEC to work on my Samsung UN55B7100 LCD TV and my Onkyo NR5007 receiver. I've turned the HDMI-CEC on in the receiver and the AnyNet+ on the TV. When I "discover devices", it finds a "Receiver" in the discovery phase, but does not populate it in the found devices.
Does anybody have any suggestions or ideas on how to get this thing to work?
wiz561 is offline
post #2 of 9 Old 02-06-2012, 09:56 AM
sjchmura's Avatar
Quoted: 1355 Post(s)
Liked: 525
I have teh Onkoy 608B (2010 model) with HDMI 1.4a/3D.
The Anynet works fine wtih my Samsung PN58C7000. Volume control is fine.
Be sure you enable the HDMI funcations you want in the Receiver (volume/on off I presume).
In addition, you made need to start over, delete device, and plug in the HDMI in the HDMI-CEC order suggested.
I struggled until I read the manual and some posts. I think it is TV first -> plug in Onkyo OFF, Onkyo ON wtih HDMI -CEC. Enable Anynet -> SCAN.
I think the 5007 and the 608B should be similiar
DocACE911 on Steam, XBOX, PS4
"Kill Cancer or Die"
Custom Z9 Game Settings For SDR and HDR
Sony 75" Z9, Denon X4200, Definitive Technologies BP7002 + 9.1 ATMOS, PSV 18" sub
Loving Wife and 4 year old Son who tolerate this expense!
sjchmura is offline
post #3 of 9 Old 02-06-2012, 12:53 PM - Thread Starter
wiz561's Avatar
Quoted: 16 Post(s)
Thanks for the info.
For some strange reason, I enabled the CEC on the receiver again, then went into the TV and enabled it in there. It automatically found the receiver and added it. Strange stuff.
Is there a way to disable the Samsung onscreen menu for the volume control? I have the Onkyo receiver volume pop up at the bottom of the screen, but now it also pops up with...
"TX-NR5007 | "
Thanks for the response and the information.
wiz561 is offline
post #4 of 9 Old 02-06-2012, 03:35 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Everyday I read, it seems this HDMI thing was made half-baked.
I eagerly await the new Apple TV, I bet they can make something SEAMLESS that works every time.
MrBobb is offline
post #5 of 9 Old 02-06-2012, 05:18 PM - Thread Starter
wiz561's Avatar
Quoted: 16 Post(s)
I bought appletv a few years ago, but quickly found it wasn't meeting my expectations. I've since moved to XBMC and have been extremely happy with it.
There's lots of positives to HDMI, but I do wish things would work better. But like every new technology, it's deployed first and does not play well with others. Hopefully, over the years, things will be refined and work in harmony...
wiz561 is offline
post #6 of 9 Old 12-21-2012, 07:19 PM
sbonkyo's Avatar
1.HDMI ISSUES;working with samsung smart tv (with any net ).
first few days I dint understand how to get it(anynet/ARC) ,worried much that am unable to get sound from receiver for tv apps like netflix and USB movies.
SOLUTION-JUST GO TO SETTINGS-HARDWARE IN LIST-TURN ON HDMI/RIHD..SIMPLE
still u have problem mail me
sbonkyo is offline
post #7 of 9 Old 05-19-2014, 12:57 PM
krishnavarahan's Avatar
Hi
I have Onkyo TX-SR508 that worked perfectly fine with my old TV. I recently got Samsung UE-55F6340 and I am having a tough time to get audio via Onkyo. Video works perfectly fine and when i tried to configure AnyNet, it recognizes the device at the scanning stage and thereafter it does not appear in the list.
I have connected in HDMI2 which has ARC.
krishna
krishnavarahan is offline
post #8 of 9 Old 05-23-2015, 02:48 PM
Liked: 0
Im having the same issues. My 626 was working fine and automatically switching the inputs to sources that cut on and had no issues with ARC. Now I have to select different inputs and have a tough time with ARC including to have to connect a digital optical cable to get sound back from the TV. I have done a reset of moth units, upgraded to HDMI 2.0 cables with no luck. Any ideas?
Jamie Bertram is offline
post #9 of 9 Old 05-23-2015, 05:22 PM
Otto Pylot's Avatar
Quoted: 1578 Post(s)
Liked: 984
There is no such thing as HDMI 2.0 cables. If you purchased cables that were labeled as HDMI 2.0, they're bogus. HDMI 2.0 is the hardware specification, not the cable specification. Any certified high speed hdmi cable will work fine. The cables can be either passive or active (requires a little power for longer distances).
What you are experiencing is more than likely an incompatibility with ARC/CEC. Anynet+ is Samsung's version of CEC. Both require an HDMI connection so if there is an issue with one, it will probably affect the other. CEC (Consumer Electronic Control) is a great idea but the current iterations have lots of problems. The reason is simple. The CEC protocols are not standardized. Many are optional so the mfrs can pick and choose what they want to incorporate into their devices, and that leads to incompatibilities across product lines, sometimes even within the same mfr. There are no firmware upgrades or patches that will make incompatible devices play nice. And there is no way of knowing which devices will work correctly, and continue to work correctly, with each.
A lot of us gave up a long time ago and use an optical cable to receive audio from the tv to the receiver when using the internal ATSC tuner of the SmartApps and use a programmable remote, such as a Harmony, for simple, universal control of the HTS.
Once the fully implemented HDMI 2.0 hardware specs are finalized and incorporated into all newer devices, the CEC problems should go away because the mfrs will have to use a single set of protocols called CEC Extensions. However, that means that all of your connected HDMI devices will also have to have the finalized HDMI 2.0 hardware specs as well.
Otto Pylot is offline
Reply LCD Flat Panel Displays
