LG LCD TV service menu access? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-07-2012, 08:01 AM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
I have been unable to find any cod(s) or procedure to access the service menu for a 22" LG LCD TV.
The only two that come up after a search do not work (holding both menu or 'Ok' buttons on the remote & the front panel).
I did find this beyond belief procedure;
http://openlgtv.org.ru/wiki/index.ph..._menus_/_modes
But that is ridiculous.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #2 of 10 Old 02-07-2012, 08:13 AM
knobe's Avatar
Buy the LG Service Remote. : LG 105-201M
knobe is offline
post #3 of 10 Old 02-07-2012, 08:41 AM
aod
aod's Avatar
Good info
aod is offline
post #4 of 10 Old 02-07-2012, 09:37 AM
pete4's Avatar
Why is this ridiculous, I bought programmable remote that works for $3 and once you have that, it's just programing the proper code, but what are you planning to do once in service menu? You can easily brick your TV inside service menu, I hope you're aware of that?
pete4 is offline
post #5 of 10 Old 02-07-2012, 01:32 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
According to that site, it surely looks like there is more to it than programming a remote. Many TV's a simple button press sequence gets you there with no fuss.
You can do the same to a mother board with a bad flash also.
Out of all these 'ISF' adjustments many/most sets seem to have now, none of them (that I have seen so far) will fix a bad gray scale (which every set seems to have to one degree or another) which should be step one.
post #6 of 10 Old 02-07-2012, 01:35 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
aod; Thanks for the part number. At around $43 it might be worth it.
post #7 of 10 Old 02-07-2012, 02:50 PM
thepoohcontinuum's Avatar
If you have a harmony remote, you can use the directions here to get into the ez-adjust menu -- http://harmonylghack.wikispaces.com/ Edit: oops, this was already posted in the link you gave, nevermind.
If you want to look at the host diagnostics screen, you can use the standard remote and follow these directions -- http://www.lg-hack.info/cgi-bin/sn_f...pg=1&sc=20&x=0
thepoohcontinuum is offline
post #8 of 10 Old 02-07-2012, 02:56 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
There is a "LG hack forum"??? Sheesh.
Thanks for the links though I don't use Harmony remotes.
post #9 of 10 Old 01-10-2013, 10:48 PM
vysakhtb's Avatar
please help me to find service code of my LG LCD 32CS410. I need this service menu for activating video option on my Lcd . Waiting for reply
thanks
vysakhtb is offline
post #10 of 10 Old 05-24-2016, 06:41 AM
Liked: 0
Please PM me the service menu codes and info for the LG47LB671V-ZB
Thanks in advance.
mkinisa is offline
Reply LCD Flat Panel Displays
