Need advice on which 65" LCD TV to buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-07-2012, 04:14 PM - Thread Starter
mrtrance's Avatar
I need to replace my Toshiba 65" DLP and looking for an 65" LCD model. So my short of list of TVs are down to 4 models. I'd like to get the best bang for my buck right now and don't want to really spend to much if I don't really gain all any more and plus I'm not really too much into video settings, etc., but just need a new TV with great picture compared to my old DLP.
The 4 models are:
LG 65LW6500 - Best price is $2300
Toshiba 65UL610U - Best price is $2000
Samsung UN65D8000 - Best price is $3000
Sony XBR-65HX929 - Best price is $4200
So out of those 4 which would make sense to get right now based on price and good performance? I just need to find something that upgrades from a DLP and not really looking into all the ins and outs of black levels, shadow details, etc.
Any suggestions on which would be best for my situation?
I'm leaning towards either the Toshiba or LG one (the only problem with the LG is that it is like 1" bigger than the media niche opening that I have in my family room so it would be sticking outside compared to the other 3 models). If anyone has one of these TVs or have compared them at all if you can give your feedback that would be very helpful.
mrtrance is offline
post #2 of 6 Old 02-07-2012, 04:18 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
The 4 models are:
Any suggestions on which would be best for my situation? I'm leaning towards either the Toshiba or LG one. If anyone has one of these TVs or have compared them at all if you can give your feedback that would be very helpful.
this thread is de javu, but if you can get the 65hx929 for 4200.00 that would be the route i would go. only issue is the set may have some vertical banding..
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #3 of 6 Old 02-07-2012, 04:23 PM - Thread Starter
mrtrance's Avatar
But is it worth it to be paying almost double compared to the LG or Toshiba ones? I mean will I notice that much of difference in say HD picture quality between the Sony and the other two models? Is it like night and day difference?
mrtrance is offline
post #4 of 6 Old 02-07-2012, 04:58 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
if you don't value black levels all that much,then no. if you do and can afford it the 65hx929 is a killer set. night and day difference...black levels yes,overall pq from a great hd feed...no...however the 929 has a great vp.. by far the best of the bunch..
post #5 of 6 Old 02-07-2012, 05:49 PM - Thread Starter
mrtrance's Avatar
Thanks for your feedback. I'm wondering if off angle viewing will be the same for all of these sets or will one be a bit better though I doubt any of these come even close to a plasma set though.
mrtrance is offline
post #6 of 6 Old 02-07-2012, 06:15 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
all will have poor off-axis viewing...
Reply LCD Flat Panel Displays
