Distance Question? - AVS Forum | Home Theater Discussions And Reviews
Old 02-13-2012, 09:36 PM - Thread Starter
cuthroatclark's Avatar
I am purchasing a 70in Sharp 733u and I was wondering from other people on here that have TV's of this size how far back they sit from the TV. I know about the charts and I checked says a good distance is between 9 and 10 ft. I have a 52 now and that is how far i sit currently. Just want to see if anyone has had it at a distance and changed ether closer or more further back. Just wondering the set up that other people use with a 70 inch set thanks!
cuthroatclark is offline
Old 02-13-2012, 09:43 PM
davyo's Avatar
I had the 70" and now have the 80", with both sets Im about 9 to 10 feet,,, perfect distance in my opinion.
Cheers
Davyo
davyo is offline
Old 02-14-2012, 06:25 PM
Rtings's Avatar
My rule is to sit as close as possible to the television, but far enough so I don't see the pixels, to have the maximum picture quality.
According to some studies, a normal 20/20 vision human can distinct something 1 arcminute apart (1/60 degree). For a 1080p 16:9 television, this equals to a distance roughly 1.6 times the diagonal length of the screen. So for a 70", this means 9.3' of distance.
Beyond that, you start loosing the full resolution advantage and closer to that, you will start seeing the pixel.
Rtings is offline
Old 02-14-2012, 11:50 PM
irkuck's Avatar
Quoted: 255 Post(s)
Liked: 148
However, this applies only for immaculate content. Practically it will be Blu-ray since even HD broadcast may show up artefacts from this distance. If there is SD in the mixture than closer to 12´ is better. Overall the rule is 3-4PH (pic height).
irkuck is offline
