Is a 55 inch TV to big? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 02-17-2012, 06:02 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
If I sit 8-10 feet away? some people will sit 4 Feet away ?
RicFlair is offline
post #2 of 24 Old 02-17-2012, 06:09 PM
mark62's Avatar
Liked: 88
no it is not too big after you get it it will shrink and you will want a 70.
mark62 is offline
post #3 of 24 Old 02-17-2012, 07:19 PM
Blackened75's Avatar
agree about it shrinking.. I sit about the same distance away and I recently upgraded from a 42 to a 47.. The 47 looked huge at first, then as the weeks passed it looked smaller and smaller.. wish I would have gotten a 55.
Blackened75 is offline
post #4 of 24 Old 02-17-2012, 07:31 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
or a 80"..in which i sit at about 10'
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #5 of 24 Old 02-17-2012, 08:01 PM
PlasmaPZ80U's Avatar
Quoted: 2207 Post(s)
Liked: 663
Yes, it really does.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #6 of 24 Old 02-17-2012, 08:02 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
So a 46 too small ?
RicFlair is offline
post #7 of 24 Old 02-17-2012, 08:15 PM
Originally Posted by RicFlair View Post
So a 46 too small ?
my 47 actually does just fine from that distance, but bigger is always better
post #8 of 24 Old 02-17-2012, 08:16 PM
Liked: 663
So a 46 too small ?
55 would be better
post #9 of 24 Old 02-17-2012, 08:38 PM
davegow's Avatar
Location: In the glorious open countryside of Eastern Ontario.
The problem with posting a question like this is you always hear from the "never too big" crowd, but others often don't bother. Really the only one who can decide is you, and one way of knowing is go to a store (or someone else's home), see where you feel comfortable, and then calculate the ratio of TV size to viewing distance. Myself I don't like to sit closer than 2-2.2 times the screen diagonal, which means that at 9 feet a 55 inch would be as big as I would want, maybe even too big. But it's your money and your living room.
davegow is offline
post #10 of 24 Old 02-17-2012, 08:39 PM
8traxrule's Avatar
It's only too big when you have to raise the ceiling to fit it in your living room!
8traxrule is offline
post #11 of 24 Old 02-17-2012, 09:01 PM
AMartin56's Avatar
Quoted: 1709 Post(s)
Liked: 849
I like my 60 from about 12 feet. If I feel the need to go bigger I'll go to a movie theater.
Home Theater: Sony 45ES, Denon AVR-S920W, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S6500, Sony UBP-X800, and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #12 of 24 Old 02-18-2012, 08:20 AM
Phase700B's Avatar
Liked: 25
Bigger is not always better. Larger panels are heavier and yet the thickness of materials is still relatively the same so sometimes large LCD panels can have more screen uniformity issues, such as edge or corner light leakage, etc. Sometimes stress from shipping or just sitting in a warehouse will cause this and later as the TV is used, it will disappear or lessen . . . sometimes not.
Also, remember, a current LCD panel has the same number of pixels regardless of panel size. So pixels are larger on a 55" compared to a 40" - 47" screen. I don't quite understand the reasoning of wanting a Hi Def image. . . and then watch it either on a smart phone (can hardly see detail) or on an huge monster panel when pixels size starts to be visible? Granted. . . two conflicting extremes, but just sayin'. At close viewing the pixels size on a 55" is distracting to me. Much like the 720p plasma panel "screen door" effect.
Not to mention the weight of a 55" or larger. Stuff to think about. But each to his own.
Phase700B is offline
post #13 of 24 Old 02-18-2012, 08:39 AM
swolfcg's Avatar
I'm a practical gal, and don't consider myself one that would automatically gravitate towards "Bigger is Better" theory, but think most of the statements here are true. You do get use to the size after a time.
I recently upgraded my bedroom tv from a 20" tube to 37" LED tv. At first it was wow, now it's just really nice and maybe I should have gone one size bigger. But I'm still glad I went with the 37", b/c any bigger wouldn't have looked right in my room.
For my LR upgrade, I first wanted to upgrade from my 32" CRT to a 46", but I quickly squashed that and decided on 55". My viewing length is about 10'. After looking at 55" the last couple of months, that size seemed a tad too small as well. I know a 60" would be a awesome upgrade. I'm about finished on working on my new 60" center, and it would fit it perfectly.
I was worried about the PQ not being as good on the 60", but I haven't been able to discern the difference between the 55 and 60" tv of the same model. Actually, I thought the 60" looked a tad better, possibly b/c they were produced after the initial 55 launch. (Tvs are launched in order of their size mostly.)
However I did notice that the 60 or 65" D8000 looked way worse than the 55" (at least the one I saw).
swolfcg is offline
post #14 of 24 Old 02-18-2012, 08:40 AM
sloandsteady's Avatar
This.
sloandsteady is offline
post #15 of 24 Old 02-18-2012, 09:48 AM
Liked: 663
Another factor worth considering is what kind of content you typically watch. If you watch plenty of BDs, then sitting closer to a big screen will work quite well. If you watch more HD TV programming, then you'd want to sit a bit farther back to compensate for the lower resolution and compression. If you watch non-HD content like DVDs and especially SD TV programming, you'll want to sit much farther back to avoid seeing an ugly pixelated mess.
post #16 of 24 Old 02-18-2012, 10:06 AM
Phase700B's Avatar
Liked: 25
^ ^ ^ Those things go without saying.
And with the pixel size of 55" or larger, even with higher resolution Blu-ray material closer is not necessarily better.
Which is why some people also would stay with smaller screens besides viewing distance.
post #17 of 24 Old 02-18-2012, 10:41 AM
Liked: 663
The flipside to this argument is that a larger screen provides a more immersive home theater picture and you can better appreciate the full detail of 1080p resolution without compression found on BD (movies and TV programming). A larger screen at a close viewing distance provides a larger field of view.
http://www.thx.com/consumer/home-ent...r/hdtv-set-up/
http://en.wikipedia.org/wiki/Optimum...Optimum_ranges
post #18 of 24 Old 02-18-2012, 11:09 AM
Phase700B's Avatar
Liked: 25
More immersive? Maybe a sore neck from having to turn your head to catch all the action too!
Plus, viewing a TV at 4 or 5 feet is bad on eyes as mom always warned us!
I've read all about "optimum" viewing distances. There are always trade offs. . . and I don't necessarily agree with the methods of determining such things. As the Wiki article discloses, there is quite a range of what is considered ideal. Room attributes and esthetics also warrant consideration.
And, unless watching the TV totally alone, not everyone can fit into the "optimum" viewing position. We prefer watching in a casual and comfortable environment where guests can visit while watching and all can enjoy each others company!
I personally sit about 3/4 of the way back in a movie theater to get both the benefit of full surround sound and no neck/eye strain. Which brings up another issue. Sitting too close may compromise the best in the sound stage for total viewing enjoyment in most home living rooms where TVs are usually located. So other than a dedicated home theater where every detail may be controlled, for most people each to his own.
post #19 of 24 Old 02-18-2012, 01:01 PM
Liked: 663
myth, no science to back this up, especially on a 1080p set
post #20 of 24 Old 02-18-2012, 01:02 PM
Liked: 663
not possible with a 55" at those recommended distances and angles
post #21 of 24 Old 02-18-2012, 01:04 PM
Liked: 663
funny, this post reminds me of your viewpoint on various topics, including display calibration
post #22 of 24 Old 02-18-2012, 01:23 PM
myoda's Avatar
Liked: 57
http://www.youtube.com/watch?v=8oSTlTFLp00
Proper Viewing Distance
A shameless plug, but it does have some good info...
myoda is offline
post #23 of 24 Old 02-18-2012, 01:33 PM
Liked: 663
Assuming 10 ft for a 80", you get just under 7 ft for a 55"
For the record, I sit a maximum of 6 ft from my 42". Sitting 4-5 ft produces best results, with high quality sources.
post #24 of 24 Old 02-18-2012, 02:03 PM
gregzoll's Avatar
Liked: 33
We sit about 12 feet away from our 42". Bedroom is a 32", and watch from about the same distance. If you can afford a 55", I say go for it.
gregzoll is offline
Reply LCD Flat Panel Displays
